POV-Ray : Newsgroups : povray.binaries.images : Gothic cathedral window generator Server Time
22 Mar 2026 04:42:57 EDT (-0400)
  Gothic cathedral window generator (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Gothic cathedral window generator
Date: 18 Jul 2023 00:10:00
Message: <web.64b6101237209b7fb5177e91dabc9342@news.povray.org>
> > Macro incoming...
> Here's the macro. It's not exactly easy to invoke, as you can see by the number
> of parameters. Be warned that the arch height cannot fall below the window
> width, nor can the window height be less than the arch height. (If that seems
> confusing, just play with the params.)
> Scroll below the macro definition to see how it's used (includes comments).
> #macro Gothic_Window(WW, AH, WH, WD, LT, ET, NA, PT, BW)
>  #local Eps = .0001; // a small value
>  union{
>   // -< window width, arch height, 0 >
>   #local P = -<WW, AH, 0>;
>   // arch circle center
>   #local CC = <.5*(P.x-P.y/(WW/AH)), -AH, 0>;
>   // arch circle radius
>   #local CR = vlength(CC);
>   // window box
>   box{<-WW, -WH+ET, -Eps>, <-WW+ET, -AH, WD+Eps>}
>   box{<WW-ET, -WH+ET, -Eps>, <WW, -AH, WD+Eps>}
>   box{<-WW, -WH, -Eps>, <WW, -WH+ET, WD+Eps>}
>   difference{
>    box{<-WW, -AH, 0>, <WW, 0, WD>}
>    intersection{
>     cylinder{<CC.x, CC.y, -Eps>, <CC.x, CC.y, WD+Eps>, CR-ET}
>     cylinder{<-CC.x, CC.y, -Eps>, <-CC.x, CC.y, WD+Eps>, CR-ET}
>   #local LT2 = .4 * LT;
>   // horizonals
>   cylinder{-<WW, AH, 0>, <WW, -AH, 0>, LT}
>   cylinder{-<WW, AH, LT>, <WW, -AH, -LT>, LT2}
>   cylinder{-<WW, WH, 0>, <WW, -WH, 0>, LT}
>   cylinder{-<WW, WH, LT>, <WW, -WH, -LT>, LT2}
>   // bottom horizontal, if there's enough room
>   #if(WH-AH > 16*LT)
>    cylinder{-<WW, WH-8*LT, 0>, <WW, -WH+8*LT, 0>, LT}
>    cylinder{-<WW, WH-8*LT, LT>, <WW, -WH+8*LT, -LT>, LT2}
>   #end
>   // fancy multiarch setup
>   #for(I, 0, NA)
>    #if(I<NA)
>     #local ArchPiece =
>      intersection{
>       merge{
>        torus{
>         CR, LT
>         rotate x*90
>         translate CC+2*x*WW*I/NA
>        torus{
>         CR, LT2
>         rotate x*90
>         translate CC-z*LT+2*x*WW*I/NA
>       plane{y, -AH inverse}
>       // use vertical cut for first item, otherwise use a cylinder
>       #if(I=0)
>        plane{x, 0}
>       #else
>        cylinder{<-CC.x, CC.y, -2*LT>, <-CC.x, CC.y, 2*LT>, CR}
>       #end
>     object{ArchPiece}
>     object{ArchPiece scale <-1, 1, 1>}
>    #end
>    cylinder{-<WW, WH, 0>, -<WW, AH, 0>, LT translate x*2*WW*I/NA}
>    cylinder{-<WW, WH, LT>, -<WW, AH, LT>, LT2 translate x*2*WW*I/NA}
>   #end
>   // fill the corners
>   sphere{-<WW, WH, 0>, LT}
>   sphere{<WW, -WH, 0>, LT}
>   sphere{-<WW, WH, LT>, LT2}
>   sphere{<WW, -WH, -LT>, LT2}
>   #local TexWindow =
>    texture{
>     pigment{rgb .75 transmit .85}
>     finish{reflection{0, 1 fresnel} conserve_energy}
>   // window pane
>   box{
>    <-WW+Eps, -WH+Eps, PT>, <WW-Eps, -Eps, PT>
>    texture{TexWindow}
>    inverse
>   box{
>    <-WW+Eps, -WH+Eps, Eps>, <WW-Eps, -Eps, Eps>
>    texture{
>     TexWindow
>     normal{
>     //pigment{ // debug
>      #local CX = CC.x;
>      #local CY = CC.y;
>      #local FA =
>       function{
>        min(
>         1
>         #for(I, 0, NA-1)
>          ,abs(sqrt(pow(x-CX-2*WW*I/NA, 2)+pow(y-CY, 2)*(y>-AH))-CR)
>         #end
>      function{
>       min(
>        1,
>        min(
>         FA(x, y, 0),
>         FA(-x, y, 0),
>         abs(y+AH),
>         abs(y+WH)
>         #if(WH-AH > 16*LT)
>          ,abs(y+WH-8*LT)
>         #end
>        ) / BW
>      bump_size 1
>      accuracy .003
>    interior{ior 1.5}
>    double_illuminate
>   // place object at y=0
>   translate y*WH
> #end
> // invoke the macro
> object{
>  Gothic_Window(
>   1.0,   // window width (total_width/2)
>   1.875, // arch height (>=WW & <=WH)
>   4.0,   // window height
>   0.75,  // window depth
>   .05/1,  // line thickness
>   .01,  // thickness of enclosure around window (window box)
>   3,   // number of arch pieces
>   .1,   // window pane thickness
>   .2   // window pane bevel width
>  pigment{rgb .75}
Nice Job! ...and thank you for the macro.
Mike
Date: 18 Jul 2023 00:20:00
Message: <web.64b6129537209b7f1f9dae3025979125@news.povray.org>
> > gothic/medieval window macro
> And here's an image showcasing the underlying geometry behind all this.
> Basically: for any given window width and arch height, find an appropriate
> circle to describe the arch.
I've wound up deriving that solution from scratch about a dozen times     :D
Nice macro.
- BW
Date: 18 Jul 2023 08:56:17
Message: <64b68bf1$1@news.povray.org>
Op 18-7-2023 om 02:27 schreef Samuel B.:
> Hi,
> Here's a piece of gothitecture I cooked up the last couple of days. It's a
> generic gothic/medieval window macro. Nothing too involved. The glass beveling
> is a simple surface normal, and everything else is just good old, traditional
> CSG.
> Macro incoming...
> Sam
Aaah! I love this! Can it do the typically English 4-centered arch? I
have been trying to write a macro lately but did not get very far.
Date: 18 Jul 2023 17:45:00
Message: <web.64b7078737209b7ff8c47d526e741498@news.povray.org>
> > Macro incoming...
> Mike
Thanks and np!
If you use it, keep in mind I failed to add a double_illuminate keyword and
interior ior to one of the boxes making up the window, so the glass won't be
physically accurate until fixed.
Sam
Date: 18 Jul 2023 17:55:00
Message: <web.64b7096b37209b7ff8c47d526e741498@news.povray.org>
> Nice macro.
> - BW
Isn't that just the way? So many times I've worked on a problem only to discover
that I had already solved it before, yet I somehow forgot! I think this was the
first time I figured out this particular problem, and the solution had me
stymied for a bit too long... but I had fun the whole time ^_^
Btw, what were you using this kind of geometry for?
Sam
Date: 18 Jul 2023 18:05:00
Message: <web.64b70c5a37209b7ff8c47d526e741498@news.povray.org>
> > Here's a piece of gothitecture I cooked up the last couple of days. [...]
> Thomas
Thanks, Thomas!
Just looked up the 4-centered arch, and no, it cannot make those. This macro
only produces arches with single circular segments, while the 4-centered arch
seems to require at least two. Or worse, it uses some sort of curve not composed
entirely of circles. I'll look further into it though, and possibly make a
separate macro.
I've love to make a single all-purpose macro to cover everything, but there
seems to be as many window/arch variations as there are stars in the sky. (Ok,
that's a bit hyperbolic, but with all the extra details architects used, there
are a lot of designs out there.)
Sam
Date: 18 Jul 2023 19:00:00
Message: <web.64b718e637209b7f1f9dae3025979125@news.povray.org>
Originally, I was using it to find the radius of the sphere I needed to subtract
from a (rounded) box to make a laptop keyboard key.
It's also useful for making any concave "cap" to a cylinder or a box.
https://news.povray.org/povray.general/message/%3Cweb.643317271ef881ca1f9dae3025979125%40news.povray.org%3E/#%3Cweb.643
I also needed this, or a variation thereof, to find the center of a very large
circle in order to model a sheet metal / screen development for making a
replacement globe for a vintage dual-fuel lantern I have.
Modeling software is great, since you can get the curve you need using the
actual center, since the entire workspce is virtual, but when laying out such an
arc IRL, one needs alternative approaches when either the center is inaccessible
or the radius makes scribing the arc wildly impractical.   There are several
such ingenious approaches.
- BW
Date: 18 Jul 2023 19:35:00
Message: <web.64b7213337209b7ff8c47d526e741498@news.povray.org>
> Macro incoming...
Second version of the macro.
Changes:
    * glass now renders correctly
    * can specify the position of the bottom horizontal frame member
    * various clarification of comments
The macro:
  WW, // window box width (total window width divided by two)
  WH, // window box height
  WD, // window box depth
  AH, // arch height (beginning from top [-y], should be >=window width and
<window height)
  HY, // y-position for horizontal cross member (beginning from y, will only be
used if there is room for it)
  FR, // frame radius (thickness of the frame)
  ET, // enclosure thickness (window box, should be qual or less than frame
radius)
  NA, // number of arch pieces
  PT, // number of arch pieces
  BW // window pane bevel width
 union{
  // window box
  difference{
   intersection{
  #local FR2 = .4 * FR;
  // horizontal frame at bottom of curved arch
  cylinder{-<WW, AH, 0>, <WW, -AH, 0>, FR}
  cylinder{-<WW, AH, FR>, <WW, -AH, -FR>, FR2}
  cylinder{-<WW, WH, 0>, <WW, -WH, 0>, FR}
  cylinder{-<WW, WH, FR>, <WW, -WH, -FR>, FR2}
  // bottom horizontal frame piece
  #if(HY<WH-AH)
   cylinder{<-WW, -WH+HY, 0>, <WW, -WH+HY, 0>, FR}
   cylinder{<-WW, -WH+HY, -FR>, <WW, -WH+HY, -FR>, FR2}
  // multiarch setup
  #for(I, 0, NA)
   #if(I<NA)
    #local ArchPiece =
     intersection{
      merge{
       torus{
        CR, FR
        rotate x*90
       torus{
        CR, FR2
        rotate x*90
        translate CC-z*FR+2*x*WW*I/NA
      #if(I=0)
       plane{x, 0}
      #else
       cylinder{<-CC.x, CC.y, -2*FR>, <-CC.x, CC.y, 2*FR>, CR}
    object{ArchPiece}
   cylinder{-<WW, WH, 0>, -<WW, AH, 0>, FR translate x*2*WW*I/NA}
   cylinder{-<WW, WH, FR>, -<WW, AH, FR>, FR2 translate x*2*WW*I/NA}
  // fill the corners
  sphere{-<WW, WH, 0>, FR}
  sphere{<WW, -WH, 0>, FR}
  sphere{-<WW, WH, FR>, FR2}
  sphere{<WW, -WH, -FR>, FR2}
  #local TexWindow =
   texture{
  // glass window pane
  #if(true)
   union{
    box{
     texture{TexWindow}
     inverse
    box{
     texture{
      TexWindow
      normal{
       #local CX = CC.x;
       #local CY = CC.y;
       #local FA =
        function{
         min(
          1
          #for(I, 0, NA-1)
       function{
        min(
         1,
         min(
          FA(x, y, 0),
          FA(-x, y, 0),
          abs(y+AH),
          abs(y+WH)
          #if(HY<WH-AH)
           ,abs(y+WH-HY)
         ) / BW
       bump_size 1
       accuracy .003
    interior{ior 1.5}
    double_illuminate
  translate y*WH
Macro invocation:
object{
  Gothic_Window(
   1.0,  // window box width (total window width divided by two)
   4.0,  // window box height
   0.75,  // window box depth
   1.875, // arch height (beginning from top [-y], should be >=window width and
<window height)
   0.375, // y-position for horizontal cross member (beginning from y, will only
be used if there is room for it)
   0.05,  // frame radius (thickness of the frame)
   0.01,  // enclosure thickness (window box, should be qual or less than frame
radius)
   0.01,  // window pane thickness
   0.125  // window pane bevel width
  // window box material goes here
  pigment{rgb .75}
Sam
Download 'gothicarchb0m_59s.jpg' (73 KB)
Preview of image 'gothicarchb0m_59s.jpg'
Date: 18 Jul 2023 20:35:00
Message: <web.64b72f8437209b7ff8c47d526e741498@news.povray.org>
43
> - BW
It looks like a good solution, but I must admit I can't quite comprehend a lot
of it. (I will keep trying, though.)
Speaking of solutions, I've been making an effort to not use the trace()
function so much since it just adds more complications when porting to another
context. And I just like knowing how something is done instead of relying on a
'black box' function. (Not that trace() is very black-box in theory, but
figuring out every intersection for every traceable object is not a small task.)
Did you ever post the dual-lantern model? I can't remember if it was you, or
someone else on another forum using Blender. /Somebody/ posted a lantern, that's
all I know!
I keep getting stuck figuring out things like intricate geometry, rendering
efficiency, or some other complicated implementation of things. And then I burn
out any energy I had producing the thing I was after initially! :S Drawing
things is much easier than rendering them. The devil is in the details...
distracting me, I guess.
Sam
Date: 19 Jul 2023 06:35:00
Message: <web.64b7bbfc37209b7f1f9dae3025979125@news.povray.org>
Apparently it is "the" solution, as I basically came across this exact equation
once when I was trying to save myself the trouble of re-deriving it.   :D
You have the "height" h of the arc, or depth that the circle/sphere pokes into
the object when it butts up against the edges.   Picture resting an oversize
ball in the mouth of a glass.
You also have the radius of the desired circle. r
We draw a chord perpendicular to the radius at height h, and use one half of
that as the leg of a triangle.  (L/2)  Drawing a line from the edge/circle
intersection to the circle center, we get the hypotenuse, which is just another
radius of the circle.
The other leg of the triangle is the radius minus the height of the arc.
Now you just do the Pythagorean theorem, and expand terms, simplify, and
rearrange to get r.
The diagram is messier because I used (L/2) instead of defining l = L/2, which
just makes the equation look a lot nicer.
Hope that helps.
