POV-Ray : Newsgroups : povray.binaries.images : HELP REQUEST: Twisted Ropes of Ballista Server Time
2 Jun 2024 06:42:14 EDT (-0400)
  HELP REQUEST: Twisted Ropes of Ballista (Message 7 to 16 of 46)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: HELP REQUEST: Twisted Ropes of Ballista
Date: 2 Mar 2020 20:05:00
Message: <web.5e5dabfd5f4031dc2e40bb200@news.povray.org>
Hope this helps.
The vertical cylinder where the ropes go around has a diamter of 0.25 and a
height from < 0.0, 0.0, 0.0 > to < 0.0, 2.7, 0.0 >.
The arm separates from the middle of the cylinder#s height and has an own radius
of 0.2 there.
Excerpt:
 union // sling arm
  cylinder { < 0.0, -0.2, 0.0 > < 0.0, 2.5, 0.0 > 0.25 texture { TopColor rotate
< 90.0, 0.0, 0.0 > } }
  cone { < 0.0,  1.15,  3.0 > 0.15 < 0.0, 1.15, 0.0 > 0.2 texture { TopColor } }
  box { < 0.0, 1.00,  3.0 > < 0.18, 1.30,  2.5 > texture { RustyIron } }
  cylinder { < 0.0, 1.15,  3.0 > < 0.0, 1.15,  2.9 > 0.17 texture { RustyIron }
  cylinder { < 0.0, 1.15,  2.7 > < 0.0, 1.15,  2.6 > 0.18 texture { RustyIron }
  torus { 0.15, 0.05 translate < 0.18, 1.15,  2.75 > texture { RustyIron } }
  sphere { < 0.0, 1.15,  3.0 > 0.15 texture { RustyIron } }
  torus { 0.05, 0.025 rotate < 90.0, 0.0, 0.0 > translate < 0.33, 1.15,  2.75 >
texture { Rope } } //  // ropes around rings
  cylinder { < 0.33, 1.15,  2.75 > < 4.19, 1.275,  3.7825 > 0.025 texture { Rope
  rotate < 0.0, 55.0, 0.0 >
  translate < -1.5, 0.0,  1.32 >
The first cylinder is the vertical one (rope skein), and the first cone is the
arm.
The ropes need to have a cross-section radius larger tan 0.025, maybe 0.030 or
0.035 maximum.
Date: 2 Mar 2020 20:10:00
Message: <web.5e5dad415f4031dc2e40bb200@news.povray.org>
Examples...
Download 'details - 001.jpg' (229 KB)
Preview of image 'details - 001.jpg'
Date: 2 Mar 2020 22:15:00
Message: <web.5e5dcb9b5f4031dc4eec112d0@news.povray.org>
So, basically you want something like this:
Download 'romanballista.png' (67 KB)
Preview of image 'romanballista.png'
Date: 3 Mar 2020 12:15:00
Message: <web.5e5e8fe25f4031dc2e40bb200@news.povray.org>
Yes, to some extend, I like what I see. :-)
There are the ropes on the left side of the vertical cylinder, and those on the
right side. All twist around the horizontal arm. The ropes of the one side
(let's say left) are ABOVE the ropes of the right side.
Would you allow me to give you credit inside the scene file?
Date: 3 Mar 2020 13:20:01
Message: <web.5e5e9ee45f4031dc4eec112d0@news.povray.org>
So you just need to define a radius one rope diameter more for the second set in
order to arrange all the ropes the way you need them.
Sure thing - it's a lovely siege engine you've built.   :)
Let me know if you have any questions.
  #declare Ropes =
union {
#declare RopeR = 0.03;
#for (Y, 0, 2.5, 0.01)
 #local R = 0.25+RopeR;
 #switch (Y)
 #range (0.00, 0.95)
  #declare Theta = (Y/0.95)*pi;
  #declare X = R*sin(Theta+pi);
  #declare Z = R*cos(Theta+pi);
  sphere {<X, Y, Z> RopeR }
 #break
 #range (0.95, 1.35)
  #declare Theta = ((Y-0.95)/(1.35-0.95))*pi;
  #declare a = 0.2*0.2;
  //#declare X = 8*pow(a,3)/(pow(Y-1.15,2)+4*pow(a,2));
  #declare X = 0.1*sin (Theta);
  //#declare Z = -R;
 #break
 #range (1.35, 2.50)
  #declare Theta = ((Y-1.35)/(2.5-1.35))*pi;
  #declare Z = R*cos(Theta);
 #break
texture {Rope}
pigment {Green}
rotate y*25
#for (R, 0, 3)
 object {Ropes rotate y*R*10}
    rotate < 0.0,180, 0.0 >
Date: 3 Mar 2020 18:20:01
Message: <web.5e5ee4ee5f4031dc82f8fb090@news.povray.org>
Working on the ballista in the meantime, removing errors and adding detail
features...
Download 'sl - roman ballista 001.jpg' (676 KB)
Preview of image 'sl - roman ballista 001.jpg'
Date: 3 Mar 2020 19:50:01
Message: <web.5e5efa5f5f4031dc82f8fb090@news.povray.org>
>   #declare Ropes =
> union {
>  #switch (Y)
>  #range (0.00, 0.95)
>  #break
>  #range (0.95, 1.35)
>   //#declare Z = -R;
>  #break
>  #range (1.35, 2.50)
>  #break
>  #end
> #end
> texture {Rope}
> pigment {Green}
> rotate y*25
> #for (R, 0, 3)
> #end
Hi, thanks a lot! However, there is something missing from your code, it might
be something that would be above the "#declareRopes" statement at the very top.
The missing part would be on the same level like the "#for(R,0,3)" statement on
the bottom. can you check and add the missing code?
Date: 3 Mar 2020 20:55:00
Message: <web.5e5f09505f4031dc4eec112d0@news.povray.org>
Yep - sorry - that's just:
 union // sling arm
  cone { < 0.0,  1.15,  3.0 > 0.015 < 0.0, 1.15, 0.0 > 0.2 texture { TopColor }
                              ^^^^^ note 1/10 of original just for demo purposes
Date: 3 Mar 2020 23:35:02
Message: <web.5e5f2f685f4031dc82f8fb090@news.povray.org>
Big thanks once more - I am going to incorporate this into the file.
by the way, this here is not really a siege artillery, it is a naval artillery.
Was used on Roman battle galleys, thus the round platform which allowed to be
turned to all sides.
Siege artillery lacked that round platform as they were not needed to be
flexible, as fortresses not really moved around that much. :-)
Mounted on ships, during an ancient ship battle, the ships often changed
direction, sometimes quite abruptly, and so did their targets, too. Thus the
added flexibility of being able to turn around the Y axis.
For your pleasure, I am including now the latest version of the naval ballista.
3.65 MB
Download 'ballista 001v2.rar.dat' (3758 KB)
Date: 4 Mar 2020 00:55:01
Message: <web.5e5f42485f4031dc82f8fb090@news.povray.org>
This is the credit I am using, please let me know, if you're okay with that.
// Scene file developd by Sven Littkowski, C 2020.
// Credits for the twisted ropes go to BaldEagle
// a long-time member of the POV-Ray community.
Also adding the latest image.
Download 'sl - roman ballista 001a.jpg' (930 KB)
Preview of image 'sl - roman ballista 001a.jpg'
