![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"using the pigment as shown, I get the single decal but the other texture has
turned transparent and the droid looks like a weird mix of glass and (white)
emissive media."
<http://news.povray.org/povray.bugreports/message/%3Cweb.5de6653248df159ffeeb22ff0%40news.povray.org%3E/#%3Cweb.5de6653
248df159ffeeb22ff0%40news.povray.org%3E>
for this image I scaled the decal down to show the effect. it looks like much
of the 'finish{}' survives in 3.7.1, just not the colour.
Download 'a371.png' (107 KB)
Preview of image 'a371.png'
![a371.png](/povray.binaries.images/attachment/%3Cweb.5de77d609f95edabfeeb22ff0%40news.povray.org%3E/a371.png?ttop=443824&toff=550&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> emissive media."
That droid obviously have an interior that set an IOR. We see a fair
amount of total internal reflection.
When applying a decal, you should layer it over some other texture.
#declare textureWithDecal
texture{SomeBaseTexture}
texture{pigment{image_map png"Decal"once}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
> > emissive media."
> > ... > > for this image I scaled the decal down to show the effect. it looks like
much
in the eye glass, the only other ior I found is used in the ground plane!
(unsure why)
thanks. I opted (before reading your post) for a second, transparent cylinder
with the decal, and union'd with the body. for now I haven't used a texture
keyword. will have to play some more with different arrangements, perhaps
modify the Android code.
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> emissive media."
It's not just internal reflections; the individual parts used to
construct the CSG are being reflected. Try a merge rather than a union:
AndroidRobot_Posed (yes, HeadRotate, LArmRotate, RArmRotate,
LLegRotate, RLegRotate)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> hi,
>>> emissive media."
much
> (unsure why)
Setting an IOR is needed when you want to use fresnel reflection. Check
the finish of that plane. My bet is that you'll find something like :
finish{ reflection{ 1 fresnel } SomeOtherFinishComponent }
With no IOR set, it default to 1, witch effectively kill any reflection.
> regards, jr.
A texture{} contain a pigment and a finish, and possibly a normals
statement.
When you use a naked pigment or finish, you effectively apply the
default finish along with the pigment, and the default pigment with the
finish unless you also define the other.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
> >>> emissive media."
like much
> > (unsure why)
and you won. :-) used for the eyes only though, afaics.
thanks. asides like this are so valuable, even if they don't always "sink in"
at first.
Cousin Ricky:
yes, like a .. cuddly version of the infamous T1000. :-) will try a merge, in
fact, will probably end up reusing chunks of your code but modified to suit.
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
