POV-Ray : Newsgroups : povray.binaries.images : Having a try at light distributions Server Time
28 Sep 2024 19:37:02 EDT (-0400)
  Having a try at light distributions (Message 11 to 14 of 14)
Subject: Re: Having a try at light distributions
Date: 24 May 2019 09:48:12
Message: <5ce7f61c@news.povray.org>
On 5/15/19 10:04 AM, William F Pokorny wrote:
> On 5/13/19 7:29 AM, Jasper wrote:
> Hmm, I have to say I'm curious about the regularity of those black
> spots. The numerical issues I've hit are usually noisier - or completely
> black/invisible/something when a hard numerical limit is hit.
> Any chance I could get a smallish test case posted to one of the scene
> file groups? I'll stick it in my POVRay_Issues directory and at least
> take a quick look if not now a deep one.
I dug out some work I was doing early in 2018 where I was using a
user_defined functional pigment as the sphere's texture around the
light. At the time I was thinking it might be a good way to define
texture maps or even use use such 'noisy lights' in a scene instead of -
or in addition to - traditional materials. In particular I was thinking
about human skin. The set up is similar to yours except how the texture
is defined.
There was also recent discussion around user_defined cameras and
transforms and it hit me I'd never tested moving my user_defined pigment
around though I fully hoped that technique would work with simple
transforms. It appears it does not - see the attached image 1e5 column.
Not shown, but 1e3 results similarly corrupted and that movement well
away from numerical issues.
So, I got two issues for the price of trying to verify yours! Good news
is I now have a small test scene for both.
Bill P.
Download 'lightinspheretran1e6story.png' (694 KB)
Preview of image 'lightinspheretran1e6story.png'
Date: 24 May 2019 20:58:50
Message: <5ce8934a$1@news.povray.org>
Le 19-05-24 à 08:39, William F Pokorny a écrit :
> On 5/23/19 2:30 PM, Norbert Kern wrote:
>> William F Pokorny <ano### [at] anonymousorg> wrote:
>> Since you are asking directly - my problems were solved after this
>> special IRTC
>> round by deleting small normals at the normal section - what else....
>> No, it wasn't that easy, but anyway...
>> Since then I deleted small normals, when black spots occured. Of
>> course I'm
>> curious of the root cause, but my focus is more on the result...
>> But here I'm curious...
> If the normals are so small at the scene scale they cannot be seen, it
> makes sense compute resource wise to remove them no matter. In a strange
> way, seeing the black artifacts was an indication texture normals too
> small existed and we no longer have this in v38.
The normals can be very small intentionally. If you want some blurred
reflection, or refraction, one common way is to use normals deliberately
scaled very small and use anti-aliasing.
In this case, you really don't want to have them removed as your
object's appearance depends on those micro-normals.
Date: 25 May 2019 05:02:35
Message: <5ce904ab$1@news.povray.org>
>> strange way, seeing the black artifacts was an indication texture
>> normals too small existed and we no longer have this in v38.
Good point. What is meaningful with respect to texture normals depends
on the textures involved. Radiosity has its own dependencies when
normals are on/respected. The situation as a whole is complex. Further,
I both do not understand significant portions of the normal handling
code and know too with respect to warps there is code which looks to be
unfinished.
Norbert's problem normals were tangled in turbulence of some kind as I
vaguely remember.
Bill P.
Date: 25 May 2019 07:47:27
Message: <5ce92b4f$1@news.povray.org>
I looked more closely at the test case this morning and the issues for
me are all me... I suppose because you were lighting an x,y plane and
moving in x,y, I coded this in my scene:
//--- scene ---
#if (0)
    //camera { Camera00    }
      camera { Camera01y   }  // An orthographic camera.
      object { LightFxtr01 }
#else
      #declare ValTranslate = 1e6;
    //camera { Camera00    translate <ValTranslate,ValTranslate,0> }
      camera { Camera01y   translate <ValTranslate,ValTranslate,0> }
      object { LightFxtr01 translate <ValTranslate,ValTranslate,0> }
when the bottom part, given my scene is lighting a plane in x,z from y+,
should have been:
    //camera { Camera00    translate <ValTranslate,0,ValTranslate> }
      camera { Camera01y   translate <ValTranslate,0,ValTranslate> }
      object { LightFxtr01 translate <ValTranslate,0,ValTranslate> }
With movement at a constant height above the plane, I get identical
images from the origin all the way up to 1e6,0,1e6 in magnitude. I was
curious and moved orthographic camera +y by 1e6 and it still works - in
other words the camera to plane rays at 1e6 length are OK.
The numeric issue is moving the LightFxtr01 (point light and enclosing
textured sphere) off the plane by 1e6. In this case there are very long
shadow rays from the plane 'up' to the sphere and these will be
numerically wobbly at the sphere's surface. My guess now is you might
have done what I did in accidentally moving the light fixture away from
the plane, but perhaps it's something else.
Instead of posting an updated image of my test case, I'll just say an
updated one would be the left column of the previous repeated three times.
Bill P.
