Alain <kua### [at] videotronca> wrote:
> Le 19-02-02 à 09:23, And a écrit :
> > Thomas de Groot <tho### [at] degrootorg> wrote:
> >> On 1-2-2019 4:15, And wrote:
> >>> Remove media:
> >> Looking good. However, even better would be to (1) randomise the tracing
> >> a bit creating clearings and clumps, and (2) randomise the sizes
> >> allowing for larger and smaller trees.
> >> Thomas
> > Wrote a file to place object and avoid overlap.
> If you want to make a forest, then, avoiding overlap is not than
> important. You only want to prevent to much of an overlap.
Basically I store the position on a file. And apply a bit large tree model.
>>>>> Remove media:
>>>> Thomas
At this stage, I think the following might be of interest to you:
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.4ac2c552a7005b411322341f0@news.povray.org%3E/landscapetutorial.pov.txt
I have used code snippets tailored to my needs ever since Kirk Andrews
posted this.
Interesting.
There once was an include file for realistic sky/(fog?) based on media
that had proper absortion depending on the suns angle. Can't find it :(
Regarding tree placement, it would be nice if we could use voronoi
(crackle) some howe to determine how big the crown of a tree can be before
intersecting with the surrounding ones.
The centre of the cell would be the trunk. The size of the cell the crown
and the height of the tree.
http://math.lbl.gov/voro++/examples/ for inspiration,
ingo
nice cloud ;)
http://math.lbl.gov/voro++/examples/cut_region/
ingo
> Interesting.
> ingo
I have to do a bit of research, but my mind tells me 'Tek' (Tekno
Frannansa) and a scene called 'Dawn'. I have it somewhere. Also there is
Jaime Vives Piqueres who has produced realistic skies with LightsysIV. I
have used it quite often but have to look that up too presently; will
take a little time.
> Interesting.
> ingo
Too difficult .!
> Interesting.
> ingo
That's a rather brilliant idea. :)
I have a .pov file where I copied the POV-Ray source for the crackle pattern,
hoping to decode it / translate it into SDL, for use in such scenes where the
parameters of the Voronoi diagram are user-accessible, but I have a lot to learn
about C++ and mysterious things like operator overloading....
That said, there's the way to "fake" a Voronoi diagram with overlapping cones.
Perhaps there's a way to do something with an array of cone-axes, and either
brute-force "collision detection" (overlap within a given radius) or using a
quad-tree plus collision detection, difference{} away the surrounding cones, and
then use trace() to determine the radius of the inscribed circle.
This might help a lot too:
https://en.wikipedia.org/wiki/Delaunay_triangulation#Algorithms
in news:web.5c57285b6bbc5191765e06870@news.povray.org Bald Eagle wrote:
> Voronoi diagram
been tinkering with it today using the voro++ commandline programm and the
Tess python binding. Intersting stuff can be done with it and I have my
first voronoi forrest, albeit with a bit of scaling that should not be.
I'm in the process of writing a python file that outputs all possible data
in arrays. The boundaries/faces of each cell can be turned into polygons
relative easy.
The voro++ command line programm output nice POV-Ray files, but arrays are
handier.
The main problem so far is the interaction with the boundaries of the
'box' that contains the cells.
ingo
>> Interesting.
>> ingo
> Too difficult .!
Seconded!
in news:5c57e89b$1@news.povray.org Thomas de Groot wrote:
>> Too difficult .!
> Seconded!
is it?
ingo
Download 'forrest_spheres.jpg' (45 KB)
Preview of image 'forrest_spheres.jpg'
