POV-Ray : Newsgroups : povray.binaries.images : Bezier-patch torus Server Time
18 Nov 2025 15:36:09 EST (-0500)
  Bezier-patch torus (Message 1 to 10 of 46)
Subject: Bezier-patch torus
Date: 29 Aug 2018 10:20:02
Message: <web.5b86aaca3b2779d1c437ac910@news.povray.org>
OK, after the initial inspiration by BGimeno, and some much needed assistance
from TOK, clipka, and jr,
I managed to make some significant headway, and then sat down for Round Two to
work out the intimate details of Theta, Phi, the parametric equations, the array
assignments, and the array-of-array assignments.
12x36 patches, 4 corners established by the parametric and f_noise3d(), then
vectors for the planes containing those corners calculated, then the remaining
12 intermediate control points for each patch interpolated from those.
I thinks there's still a wee bit of debugging to do, with regard to the vector
calculations, but it's sure "close enough" at this point to post.
Quite frankly, I'm amazed it even works at all, but here it is  :)
Download 'bezierstitching_test_2.png' (1230 KB)
Preview of image 'bezierstitching_test_2.png'
Subject: Re: Bezier-patch torus
Date: 29 Aug 2018 18:50:01
Message: <web.5b87227adc5d6572df3f16580@news.povray.org>
Good !
- but it needs a less confusing texture.
Did you create a 12x36 array of 4x4 arrays, where each 4x4 array contains the
control points for each bicubic Bezier patch ?
Tor Olav
http://subcube.com
Date: 29 Aug 2018 21:21:33
Message: <5b87469d$1@news.povray.org>
Looks like a circular turd if such things were possible.
Mike
Date: 29 Aug 2018 22:36:08
Message: <5b875818$1@news.povray.org>
Like a smoke ring? ;)
Regards
Date: 30 Aug 2018 14:36:47
Message: <5b88393f@news.povray.org>
Would be beter if the texture was UV mapped.
Date: 31 Aug 2018 09:14:21
Message: <5b893f2d$1@news.povray.org>
Am 30.08.2018 um 03:21 schrieb Mike Horvath:
You should see your doctor about the pigment and texture of your turds ;)
Date: 31 Aug 2018 10:15:01
Message: <web.5b894c3edc5d6572c437ac910@news.povray.org>
It would be, but usually people make sure the foundation and frame on a house
frame are right before priming and painting the trim.
Besides - since it's a network of stitched bicubic patches, I have to specify
the u/v vectors, and I don't know how to do that with procedurally generated
coordinates.   Yet.
Maybe someone can suggest a way to do this, or point me to a good reference that
I can read and get right on to implementing.
Date: 31 Aug 2018 10:35:59
Message: <5b89524f$1@news.povray.org>
Got an appointment Wednesday morning for that very thing. I'll mention
that you said I should.
Unless you want the job?
Regards
Date: 31 Aug 2018 14:15:06
Message: <web.5b89859cdc5d65725c907ee00@news.povray.org>
> Mike
As a nonspeaker english user is always useful to learn new ways of description
for my own code. I didn't knew the word and had to google it. What a mistake.
Still fighting with De Casteljau.
Bruno Gimeno
Date: 1 Sep 2018 07:00:18
Message: <5b8a7142$1@news.povray.org>
Probably a dumb question, but can only meshes be UV mapped?
Mike
