POV-Ray : Newsgroups : povray.binaries.images : random-colored BRICKS Server Time
29 May 2024 04:38:06 EDT (-0400)
  random-colored BRICKS (Message 11 to 20 of 49)
Subject: Re: random-colored BRICKS
Date: 19 Apr 2018 12:00:00
Message: <web.5ad8bbde95b142bda47873e10@news.povray.org>
(in my the previous code...)
>            normal_map{
>        [1.0 quilted scale 1 bump_size 5] // This pattern doesn't
> // need the warp{repeat...} below, which affects it an odd and subtle way;
> // note the darker brick 'shadows' in every alternate row of bricks in y.
Actually, the warp{repeat...} IS needed for it, to look correct on the side
walls (in the y/z plane.) But it introduces the aforementioned odd 'shadow'
appearance on alternate brick rows. That's a mystery to me so far. It's not a
killer flaw, though. I like the quilted-pattern's 'bulbous'/rounded look on each
brick.
Date: 19 Apr 2018 12:45:00
Message: <web.5ad8c6fd95b142bd1b6c6b3a0@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> Five or six days now, I've lost count!
Looks well spent though! Personally I think your latest one might be a little
busy, but vive la difference, and I'm sure there's scope for variation.
> Bill P's code certainly looks less complicated! (I need to take a look at it in
> detail... after I take a coffee break!)
To be fair, it's not doing nearly as much as yours is, plus yours is a complete
scene, and also I have an ingrained 'short-code' mentality ;) Anyway it's a lot
more complicated now, here's another iteration (I'll have to tidy the code up a
bit if you want a peek under the hood).
This is all very productive, but I think I'm into diminishing returns to be
honest. For close up, I'll always plump for actually modelling the individual
bricks, and for distance shots the basic version is probably good enough :)
Download 'randbricks.jpg' (182 KB)
Preview of image 'randbricks.jpg'
Date: 19 Apr 2018 16:32:23
Message: <5ad8fcd7$1@news.povray.org>
Am 19.04.2018 um 00:53 schrieb Bill Pragnell:
> This is fun! I always meant to make some random bricks, so I've just had a go
> myself. I ended up with almost exactly what you've got (more or less) which is
> good. However, I don't think you need the oversized offset value - just 1.5 in x
> and z is fine.
> I've boiled it down a little. Here's a macro to insert a pigment - I went with
> the same principle of using the brick pattern for the mortar and the cells
> pattern for the bricks themselves.
> (BrickSize is a vector describing the brick dimensions, BaseCol and MortarCol
> are colour vectors, and MortarThickness is just the mortar float value.)
> #macro RandBrick(BrickSize, BaseCol, MortarCol, MortarThickness)
>   #local RBrick = pigment {
>    cells
>    color_map { [0 rgb BaseCol] [1 rgb 0.25*BaseCol] }
>    translate z*0.5
>    warp { repeat y offset <1.5, 0, 1.5> }
>    scale BrickSize
>   pigment {
>    brick
>    pigment { rgb MortarCol },
>    pigment { RBrick }
>    brick_size BrickSize
>    mortar MortarThickness
> #end
I never came up with the idea to use the cells pattern this way. But my
goal was not different textured bricks but rubble work. So i played a
little bit with the brick pattern (and still need some time to get a
better approximation). One of the most annoying issues was that I had
only two textures (mortar and brick). But now you gave me a new
direction to play a little bit more with something like this:
#declare BrickSize = <8,3,4.5>; // Default, but needed to scale the
cells pattern
#declare CellsStoneTex = texture {
    cells
    texture_map {
      [ 0.00 T_Grnt20 ]
      [ 0.25 T_Grnt7 ]
      [ 0.50 T_Stone21 ]
      [ 0.75 T_Stone10 ]
      [ 1.00 T_Grnt28 ]
    translate z*0.5
    //warp { repeat y offset <1.5,0,1.5> }
    scale BrickSize
    brick
    texture { T_Grnt1 finish { phong 0.5 } }, // Mortar
    texture { CellsStoneTex }
    mortar 0.2
    scale 0.1
    warp { turbulence 0.4 octaves 8 lambda 3 omega 0.5 }
Many thanks to both of you!
Best regards
Michael
Date: 19 Apr 2018 18:10:01
Message: <web.5ad9136095b142bd1b6c6b3a0@news.povray.org>
> and z is fine.
Haha, silly me, of course even 1.5 is unnecessary. <0.5, 0, 0.5> is fine. The
docs even say that about the built-in bricks pattern.
*rolls eyes at self*
Date: 21 Apr 2018 08:21:03
Message: <5adb2caf@news.povray.org>
The blackened area could indicate moisture and fungus or dirt, which is
a normal thing. But I see the dark area normally at the lower areas of
the bricks only, not so much on the sides and top. Gradient map.
http://www.avg.com
Date: 21 Apr 2018 11:38:25
Message: <5adb5af1@news.povray.org>
> http://www.avg.com
There can be some pigment segregation that happen before the bricks are
cooked. It tend to show more on the length that the other directions,
but it's still there. Much more notable on older bricks than modern ones.
Date: 21 Apr 2018 12:11:18
Message: <5adb62a6$1@news.povray.org>
Is there any way, to derivate a "deck planks" version from these bricks?
On my own, I am trying hard, since weeks, but not being successful yet.
The only problem is, to prevent (using WARP?) that the wood grain
continues from "brick" to "brick" (plank to plank). And i do not yet
understand the WARP concept fully, but at the moment I think, it can be
used only to transfer/shift textures on a regular pattern such as CELLS.
Bricks, on the other hand, are kind of intersected each 2nd line. That
is, where I fail.
http://www.avg.com
Date: 21 Apr 2018 12:57:21
Message: <5adb6d71@news.povray.org>
This is the code i have right now. Looks alright, just the grain
continues into each other "brick"...
#declare WarpScale = 0.3;
#declare MyDeckGrain = texture
 pigment
  wood
  warp
   turbulence 0.03725
   omega 0.65725
   lambda 2.425
  color_map
   [ 0.250 color rgb < 1.00000, 0.53373, 0.11665 > ]
   [ 0.350 color rgb < 0.66275, 0.28607, 0.00000 > ]
   [ 0.525 color rgb < 1.00000, 0.53363, 0.11715 > ]
   [ 0.600 color rgb < 0.66475, 0.28647, 0.00000 > ]
   [ 0.750 color rgb < 1.00000, 0.53353, 0.11565 > ]
   [ 0.850 color rgb < 0.66275, 0.28667, 0.00000 > ]
   [ 1.000 color rgb < 1.00000, 0.53143, 0.11795 > ]
  scale < 0.205, 0.225, 1.2 >
  warp { repeat x*WarpScale offset y*2.427 flip y }
 rotate < 0.0, 90.0, 0.0 >
#declare MyDeckLumber = texture
 pigment
  wood
  scale 1.01275
  turbulence 0.0435
  omega 0.65
  lambda 3.15
  color_map
   [ 0.200 color rgbt < 0.56695, 0.17347, 0.00000, 0.8250 > ]
   [ 0.350 color rgbt < 0.96471, 0.54510, 0.22753, 0.7710 > ]
   [ 0.400 color rgbt < 0.56341, 0.17547, 0.00000, 0.9150 > ]
   [ 0.615 color rgbt < 0.96472, 0.54510, 0.22553, 0.7590 > ]
   [ 0.700 color rgbt < 0.56671, 0.17687, 0.00000, 0.7920 > ]
   [ 0.850 color rgbt < 0.96485, 0.54510, 0.22453, 0.8975 > ]
   [ 1.000 color rgbt < 0.56478, 0.17247, 0.00000, 0.9750 > ]
  scale < 0.225, 0.2725, 1.0 >
  translate < -0.35, 0.095, 1.25 >
  warp { repeat x*WarpScale offset -y*0.321 flip z }
 normal
  wood 10.0
  scale 1.01275
  turbulence 0.0435
  omega 0.65
  lambda 3.15
 finish
  specular 0.3 roughness 0.12
  reflection { 0.001,0.1 fresnel }
#declare MyDeck2 = texture
 MyDeckGrain
texture
 MyDeckLumber
texture
 pigment
  bozo
  color_map
   [ 0.00 color rgbt < 0.71, 0.83, 0.76, 0.35 > ]
   [ 1.00 color rgbt < 1.00, 0.98, 0.87, 0.35 > ]
  turbulence 1.5
  scale 1.0
  translate < rand(MyRandom)*10, rand(MyRandom)*10, rand(MyRandom)*10 >
  rotate    < rand(MyRandom)*10, rand(MyRandom)*10, rand(MyRandom)*05 >
texture
 pigment
  brick
  pigment { color rgb 0.0 }
  pigment { color rgbt < 1.0,  1.0,  1.0, 1.0 > }
  brick_size < 7.5, 0.4, WarpScale*10.0 >
  mortar 0.01
 normal
  brick
  mortar 0.02
 finish { crand 0.1 }
 rotate < 90.0, 0.0, 0.0 >
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 21 Apr 2018 13:15:02
Message: <web.5adb70d395b142bda47873e10@news.povray.org>
> > in xand z is fine.
Throughout my (many!) experiments with this, I noticed a kind of repeating
diagonal pattern of the bricks, when using just <.5,0,.5> for the warp
'offsets.' I've attached an image to show this. Choosing <1000.5,0,999.5> (or
other similarly larger offsets) *seems* to make this pattern less noticable, or
shifts things around to be more random-looking. Or something. ;-)  Honestly, I
don't really know for sure why this appears to work. I *think* it shifts the
entire cells pattern in space, before the next brick is 'created.' My guess,
anyway.
However, I don't see this diagonal pattern in your own image.
Download 'using_only_one_half_offsets.jpg' (844 KB)
Preview of image 'using_only_one_half_offsets.jpg'
Date: 21 Apr 2018 13:50:03
Message: <web.5adb787695b142bda47873e10@news.povray.org>
> 'offsets.'...
The answer just occured to me!
1) The cells pattern is naturaly composed of cubes.
2) Those cubes have a thickness in all dimensions-- naturally!
3) The warp 'repeats' of <.5,0,.5> are apparently smaller than the cube
dimensions. So when the next row of bricks is created-- starting at y=0 --
there's a very good chance that the *same*-colored cube will be chosen for some
of the bricks in th next (offset) brick row. That is, until the <.5,0,.5>
offsets get to another differently-colored cube, spatially speaking.
To test this, I scaled the cells pattern to be much smaller in z, immediately
before the warp{repeat...} statement...
scale <1,1,.01>
warp{repeat y offset <.5,0,.5>
As expected, this eliminates the 'diagonal' pattern! On the FRONT face, that is.
The only problem now is that the SIDE walls of the brick building are scaled
totally wrong. (Likewise, trying to use scale <.01,0,.01> will mess up ALL the
brick faces.) So there's no easy way to eliminate the 'diagonal' pattern by
squasing the cubes-- except to keep them at their regular cubic shape and then
to make the OFFSETS much larger, as I did. Perhaps there's another more-involved
method which will work, but I can't think of one...
