![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> "Bill Pragnell" <bil### [at] hotmail com> wrote:
>> "Kenneth" <kdw### [at] gmail com> wrote:
>>> You've also solved the need for
>>> 'recessed' building sections on top of the 'main' buildings.
>> Do you mean the 'compound' buildings with the decreasing sizes? Those are
>> basically a specialised building type that just creates two or three
>> sub-buildings with different versions of the base polygon. Since the building
>> construction already offsets polygons extensively, it wasn't a lot of work to
>> add this.
>> ...there are indeed many ways to skin a cat!
> This as far as I got with my original code (and I made only a single small
> render, unfortunately.) The upper building sections are not 'correct' though.
> Then I changed the code, to try a different approach to those upper sections.
> *Then* I decided to go in a different direction entirely-- making the building
> faces as height_fields (which will require a re-work of my original
> city-building code.)
> Ah, the fun of it!
You have a problem with the roof structures : They often end outside the
roofs.
I can see at least 22 cases where beams are to long for the roofs.
It seems to only affect buildings where the top part is smaller than the
bottom part. The beams are sized for the bottom part.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Alain <kua### [at] videotron ca> wrote:
> > This as far as I got with my original code...
> roofs.
Yes, that is indeed the case. AND, the upper building sections are probably
slicing off some of the windows, at the building edges. But I stopped working on
this particular version of the scene, and began making the building faces as
height_fields... an entirely different approach. I'll go back to the original
scene code later, to try and fix the problems. Hopefully, the city will then
look more realistic!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Bill Pragnell wrote on 21/03/2018 15:25:
> Paolo Gibellini <p.g### [at] gmail com> wrote:
>> I like a lot both of them (and also I'm interesting in the process used...).
> Thanks!
> Broadly speaking, the core algorithm takes a list of straight line segments as
> input, then:
> - intersects all lines to find the connected graph
> - traverses the graph nodes to build polygons
> - discards polygons that are too small
> - splits polygons up until a threshold edge length or split count is reached
> - uses new polygons as basis for buildings.
> The splitting threshold is selected based on a block's nominal max height,
> imposed randomly in the images above. Building heights are randomly picked up to
> the block max height. Building type is selected based on their height. Buildings
> are made using simple vertical prisms with open sides or ends, combined into a
> single triblock per building, each with its own texture list. These are then
> written to a .inc file.
> The buildings were actually quite quick to make in SDL (even if the code was a
> little convoluted) - the real problem was keeping track of graph nodes and edges
> without going insane. Much easier with a bit of object abstraction! Plus the
> naive algorithms I'm using were far too slow for the SDL parsing.
> I'll post some more pictures at some point.
> Bill
Thank you. The results are excellent imho.
Paolo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
playing with height functions
Download 'blocks_hill1.jpg' (343 KB)
Preview of image 'blocks_hill1.jpg'
![blocks_hill1.jpg](/povray.binaries.images/attachment/%3Cweb.5abacea7653a98a11b6c6b3a0%40news.povray.org%3E/blocks_hill1.jpg?ttop=426429&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Very nice!
What I've noticed from looking at real city images (well, using New York City as
my guide-- a *mostly* grid type of layout), the street widths and their block
sizes are interesting: The main thoroughfares are wide and long, while the cross
streets are narrow. And the city 'blocks' between the narrow streets have only
two buildings back to back (of various ground plans, of course, along with an
alleyway), while the wider streets are much longer, with many more buildings
along their lengths. In other words, the street-isolated blocks of buildings are
not square, but rectangular. (Older thoroughfares like NYC's Broadway go in a
diagonal direction, but that's another matter!!)
That's my plan for my own city, anyway-- when I finally get around to coding it
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have had these exact thoughts :)
The lines I use as input for streets also have widths associated with them. I
have some convoluted magic that fairly reliably makes the resulting block
polygons with the correct gaps between them. When making buildings, there is
also a max alley width used to separate them. I've even gone as far as flagging
polygon edges that lie on street lines, which is carried through to the
buildings. This enables me to discard buildings that are hemmed in with no
street access (just about visible in the hill-downtown image), and in theory I
can make the 'blocked' building faces differently (e.g. fewer windows). If I set
the split parameters right, I can get back-to-back blocks, but you do see larger
blocks with empty interiors in real cities elsewhere in the world.
(I think I'm low-balling the street widths, because they're hardly visible in my
images here unless the camera happens to be aligned with them.)
And it's funny you should mention NYC - I actually have an approximated SVG
version of Manhattan that I hand-traced over Google Maps screenshots, each
street a single line. I've been using it for testing. I've only tried it once
recently - it took minutes to process and the resulting building geometry files
were > 250MB :o I'll have to try it again soon to see if I can get some
interesting images :)
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
