![](/i/fill.gif) |
Sven Littkowski <I### [at] SvenLittkowski name> wrote:
> On 27.11.2017 07:20, Thomas de Groot wrote:
> > It depends of what you want. If it is a fading away of the clouds
> > towards the edge, you would need a cloud media using density
> > {cylindrical etc} to get the proper effect, in addition to the clouds
> > proper. Not entirely trivial to do, although I think it possible. I
> > shall try later when I get some time. Somewhat easier would be, I guess,
> > hiding the edge in a more opaque mist (also with cylindrical) but then
> > as an atmospheric effect. You know that you can layer media like you can
> > layer textures?
> Hi, thanks for your answer. I need both effects: fading cloud edges
> (density), and the distant fog that makes the cloud object disappearing
> at the horizon (please see the attached example image). It is actually
> that example scene, that triggered my decision to do something like that
> with POV-Ray. :-)
I used Thomas' scene to modify (maybe hack is the word) and had much trouble
with transparency of the media, especially when objects within it are backlit or
in shadow.
I finally got a result similar to the photo, but it took some serious trial and
error to get the colors. And I tried various extinction values, to name one
example. Just look at all the media color vectors and you will see what I mean.
I also used radiosity with it too, so I added sphere for ground. I had to widen
that to meet horizon edge better than simply have a shell of
cloud/fog/atmosphere, and sky disc of blue-white to try and make those cloud
colors interact with radiosity. Which was due to the reddened atmosphere,
otherwise it turned very yellow.
There was strange stuff about the atmosphere y-axis scale when changing index
values, but I shouldn't go into all that here. Just be forewarned that using
other index values might alter the haze layer (orange-yellow portion) in weird
ways. You will also notice I turned the media into spherical warps, and rotated
the atmosphere in attempt to get haze layer out of near distance.
Like I said, it's more a hack rather than modified with certainty of outcome.
I might be forgetting things, I was changing almost every aspect but luckily
Thomas got me to the starting point well enough. Scene follows:
//thomas de groot
//modified, bob
//cmd:+am2 +a0.1
#version 3.8;
global_settings {
assumed_gamma 1.4
radiosity {media on}
#default {
finish { ambient 0.0 diffuse 1.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
/*ultra_wide_angle*/ //angle 20
location < -35.0 , 11.0 , 0.0 >
//right x*image_width/image_height // not needed for v3.8
look_at < 0.0 , 5.0 , 0.0 >
// sun -------------------------------------------------------------------
light_source {
-z*9999//< 50, 100, -250 >*10e4
color 1//< 1.0, 0.62353, 0.46667 >*2
rotate <20,240,0> // altitude, azimuth, tilt
// sky -------------------------------------------------------------------
background { color rgb 0 }
sky_sphere {
gradient < 0, 1, 0 >
color_map {
[ 0.0 color rgb < 1.00000, 0.62353, 0.46667 > ] // Pink
[ 0.4 color rgb < 0.64706, 0.30588, 0.59608 > ] // Purple
[ 0.6 color rgb < 0.64706, 0.30588, 0.59608 > ] // Purple
[ 1.0 color rgb < 1.00000, 0.62353, 0.46667 > ] // Pink
scale 2
disc {0,y,1,0 hollow on no_shadow pigment {rgb <0.5,0.75,1>} scale 100 translate
y*100}
// ground -----------------------------------------------------------------
disc {
< 0, 1, 0 >, 0, 50
texture { pigment { color rgb < 0.24706, 0.38431, 0.058824 > *1.0 }
finish {diffuse 1.0 } }
rotate< 0, 0, 0 >
sphere {
0,1
pigment {color rgb 1}
scale <555,497,555>
translate -y*494
//---------------------------- objects in scene ----------------------------
#local Scale = 5;
#declare Clouds=
density {
ripples // controls the cloud formation
color_map {
[0.33 rgb 10]
[0.67 rgb 100]
scale <3, 1, 10>*0.5
warp {turbulence <2.5, 1.0, 1.6>}
rotate 45*y
//cloud layer:
//cylinder {
// < 0.0, 0.0, 0.0 > < 0.0, 0.45, 0.0 > 10.0
sphere {
0, 1
pigment {rgbt 1}
hollow
interior {
media {
samples 20
absorption <3, 4, 0.5>*1/(Scale*100)
emission <1.0, 1.0, 1.0>*0.5/(Scale*100)
scattering {1, <0.5, 0.75, 1.5>*3/(Scale*100) extinction 0.5}//
eccentricity 0.2}
density {
spherical
density_map {
[0 rgb 0.0]
[0.001 Clouds scale 1/100]
media {
samples 33
absorption <1.0, 1.0, 1.0>*10/(Scale*100)
// emission <1.0, 1.0, 1.0>*0.1/(Scale*100)
scattering {5, <1, 1, 1>*1.5/(Scale*100) extinction 1.0 eccentricity 0.2}
density {
spherical
density_map {
[0 rgb 0.0]
scale Scale*100
translate -y*494
//translate <0, 1, 0>
//atmosphere:
sphere {
<0.0, 0.0, 0.0 >, 1.0//10
pigment {rgbt 1}
hollow
interior {
media {
samples 20
absorption 0.5
scattering {5, <1.25, 1, 1.5,>*2/Scale extinction 0.67 eccentricity 0.2}
density {
gradient y
color_map {
[0.00 rgb 1] //base ground fog
[0.1 rgb <9,0.3,0.1>] //top ground fog
[0.3 rgb <0.9,0.3,0.1>] //top ground fog
[0.5 rgb <0.5,0.1,0.09>*0.1] //base atmospheric haze
[0.67 rgb <0.1,0.2,0.9>*0.1] //top atmospheric haze
[1.00 rgb <0.1,0.3,0.9>*0.001] //top atmospheric haze
rotate -x*15
warp {spherical}
scale Scale*2*y
//scale Scale
scale Scale*111
translate -y*535
//artefact:
union {
cylinder {< 0.0, 0.0, 0.0 > < 0.0, 8.0, 0.0 > 0.25}
sphere {< 0.0, 8.0, 0.0 > 0.25}
texture { T01 }
texture { T_Copper_1A }
// Planet:
union {
sphere {
<0.0, 0.0, 0.0> 7.0
difference {
cylinder { < 0.0, -0.00001, 0.0 > < 0.0, 0.00001, 0.0 > 20.0 }
cylinder { < 0.0, -0.00002, 0.0 > < 0.0, 0.00002, 0.0 > 10.0 }
texture {pigment {color rgb 1}}
scale 33
rotate < 20.0, -10.0, 4.0 >
translate <80.0, -2.0, 13.0>*33
//buildings:
#local S=seed(4132);
union {
#for (It,1,8,1)
#local xR=rand(S);
#local yR=rand(S);
#local zR=rand(S);
#local xR2=rand(S);
#local yR2=rand(S);
#local zR2=rand(S);
box {
0,1
scale <1+xR,8+yR*4,1+zR>/2
checker
color rgb 0.1 color rgb 0.9 scale 0.5
translate (-<xR*20,0,zR*20>+<xR2*40,0,zR2*40>)/2
rotate y*90
translate <-20,2,5>
Download 'test fog cloud.png' (121 KB)
Preview of image 'test fog cloud.png'
![test fog cloud.png](/povray.binaries.images/attachment/%3Cweb.5a1c8d859a2a53c19c5d6c810%40news.povray.org%3E/test%20fog%20cloud.png?ttop=421982&toff=50&preview=1)
![](/i/fill.gif) |
