POV-Ray : Newsgroups : povray.binaries.images : Example images for the related post: "Rendering an electromagnetic field an= Server Time
14 Mar 2026 21:38:06 EDT (-0400)
  Example images for the related post: "Rendering an electromagnetic field an= (Message 17 to 26 of 56)
Subject: Re: Example images for the related post: "Rendering an electromagnetic fiel=
Date: 27 Oct 2017 10:30:02
Message: <web.59f34270231a9fe3306cf3e40@news.povray.org>
.... here is the render with patterning showing the overlap problem ...
Download 'phc_and_excitation_enhancement.png' (254 KB)
Preview of image 'phc_and_excitation_enhancement.png'
Message: <web.59f342b4231a9fe3306cf3e40@news.povray.org>
.... and here is a zip with the scene again and the df3 files.
Download 'pov_scene_and_df3s.zip' (212 KB)
Date: 27 Oct 2017 11:45:00
Message: <web.59f353d2231a9fe3c437ac910@news.povray.org>
"cbpypov" <nomail@nomail> wrote:
> I further set the QD absorption to 0. as Bald Eagle suggested. I really like the
> arrow thing you posted, but somehow I could not figure out where the `Vector`
> function comes from? My povray does not know it and I could not find an .inc
> that defines it. Could you post more code that you used for the image with
> arrows?
That's from Friedrich Lohmueller's analytical_g.inc file, which I _think_ comes
with POV-Ray.
http://www.f-lohmueller.de/pov_tut/addon/00_Basic_Templates/85_Analytical_Geo/__index.htm
> In the next to posts I will attach an image of the _patterned_ version, which is
> not working yet because the boxes in which the field is defined overlap. How can
> I solve this problem?
difference {} away the parts that overlap?
Date: 27 Oct 2017 12:00:01
Message: <web.59f357f1231a9fe3c437ac910@news.povray.org>
I had that as part of a mental list to post, but it slipped off...
I was also thinking that if you wanted to represent an emission, you ought to
use the standard lambda-photon-sine-wave thing
like
https://physics.aps.org/assets/5f985b1a-28d8-4cb1-89f1-1ae7dedeac6f/e135_2_thumb.png
Just define it as an object that you can replace that quickie Vector () with.
And now I'm off to lunch.
Date: 27 Oct 2017 14:10:01
Message: <web.59f375c3231a9fe3306cf3e40@news.povray.org>
> like
So for the fast case I managed to get rid of the overlap by defining the field
directly in a prism that I scale to the unit cell size, like this
#declare Field_object = prism {
    linear_sweep
    linear_spline
    0., // sweep the following shape from here ...
    1., // ... up through here
    7, // the number of points making up the shape ...
    <0.,0.5>, <0.25,1.>, <0.75,1.>, <1.,0.5>, <0.75,0.>, <0.25,0.>, <0.,0.5>
     finish { diffuse 0 ambient 0 reflection 0 }
       colour rgbft <1.000,1.000,1.00,0.000,1.000>
    hollow
    interior{
     ior                 1.000
     caustics            0.000
     dispersion          1.000
     dispersion_samples  7.000
     fade_power          0.000
     fade_distance       0.000
     fade_color          rgb <0.000,0.000,0.000>
     // Red
     media {
       method     3
       intervals  10
       samples    1, 1
       confidence 0.900
       variance   0.008
       ratio      0.900
       absorption rgb <0,0,0>
       emission   rgb <1,0,0> * Field_brightness
       aa_threshold 0.050
       aa_level    4
       density {
         density_file df3 "efield_energy_in_superspace_R.df3"
         interpolate Field_interpolation
     // Green
     media {
       method     3
       intervals  10
       samples    1, 1
       confidence 0.900
       variance   0.008
       ratio      0.900
       emission   rgb <0,1,0> * Field_brightness
       aa_threshold 0.050
       aa_level    4
       density {
         density_file df3 "efield_energy_in_superspace_G.df3"
     // Blue
     media {
       method     3
       intervals  10
       samples    1, 1
       confidence 0.900
       variance   0.008
       ratio      0.900
       emission   rgb <0,0,1> * Field_brightness
       aa_threshold 0.050
       aa_level    4
       density {
         density_file df3 "efield_energy_in_superspace_B.df3"
     media {
       absorption 0.
    // Set proper size and position
    scale field_box_dim
    translate field_box_trans
But still a problem is that the "black" parts of the color map are not
transparent (maybe because the density is not exactly 0.0?). So there is a kind
of "box" still visible, which destroys the complete image. See the attachment.
Help! :)
For the emitter thing: yes that "standard lambda-photon-sine-wave thing" would
really be a great thing to have ... er ... how do I do that? :)
Download 'phc_and_excitation_enhancement.png' (250 KB)
Date: 27 Oct 2017 15:10:00
Message: <web.59f38477231a9fe3c437ac910@news.povray.org>
> Help! :)
Maybe there needs to be a t in one of your rgb statements?
I'll have to look at it when I get back home.
plot spheres:
http://www.f-lohmueller.de/pov_tut/calc/math_500e.htm
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5926c5ddec053131c437ac910%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.58b813187922eedfc437ac910%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5781842fa68f756e5e7df57c0@news.povray.org%3E/
Use a sphere sweep
http://www.povray.org/documentation/view/3.7.1/63/
(instead of points, do a loop with a function evaluating the sine of current
counter value)
parametric isosurface using spline
http://www.econym.demon.co.uk/isotut/more.htm
http://www.econym.demon.co.uk/isotut/splines.htm
I'm sure there may be other clever ways, but fast and simple is usually best.
If you want arrowheads, just define a vector by subtracting the penultimate
sphere from the last sphere to give you a direction, and then start a cone{} at
the last sphere and end at a multiple of that vector.
[That ought to be the correct way to do it...]
Though the arrow out to be pointing straight out...
Date: 27 Oct 2017 15:30:01
Message: <web.59f38849231a9fe3c437ac910@news.povray.org>
Oh, and I found a link to an Angewandte Chemie cover done with POV-Ray that uses
code to make a spring:
http://www.somewhereville.com/?cat=1136
Date: 27 Oct 2017 16:50:01
Message: <web.59f39b43231a9fe3306cf3e40@news.povray.org>
Hey, the spiral thing is really nice. I played around with it, the the result
attached (I added a sin() in the x-displacment of the spheres). But it is
getting rather confusing now :) Maybe I'll stick to the glowing...
Important: could you please post the code you used for the emitters that you
used? I still have the overlap problem, although I set absorption to 0. Since it
is working for you, it will be nice to have the code. Maybe this can also be
applied to field overlap problem...
Where could I integrate a transmittance in the code that uses 3 different media
for RGB (based in Stephen's snippet)? Should there be some kind of colormap?
An new question: how can I achieve a "corner rounding" for the hole? I tried to
subtract an hourglass-like `sor`, but without success :(
Download 'phc_and_excitation_enhancement.png' (453 KB)
Date: 27 Oct 2017 18:50:00
Message: <web.59f3b7a6231a9fe35cafe28e0@news.povray.org>
#version 3.71;
global_settings {
 assumed_gamma 1.0
#declare Aspect = image_width/image_height;
 location <0.5, 0, -5>
 right x*Aspect
 look_at <0, 0, 0>
#declare A = 0.1;
#declare R = 0.01;
#declare Freq = 10;
#declare Photon = union {
 #for (X, 0, tau, 0.01)
  // plot function
  #declare Y = A*sin(Freq*X);
  sphere {<X/tau, Y, 0>  R}
 cylinder {0, <X/tau, Y, 0> R pigment {Red}}
 cone {<X/tau, Y, 0>, R*3, <(X/tau)*1.1, Y, 0>, 0 pigment {Red}}
 pigment {Yellow}
object {Photon}
#declare Exp_decay = function {
    exp( -(pow(x,2) + pow(y,2) + pow(z,2))*80. )
#macro QuantumDot(Radius, Radius_aura, Intensity, Origin)
    // The actual quantum dot
    sphere{
        <0,0,0>, Radius
        texture{ Glass2 } // end of texture
        translate Origin
    } // end of sphere
    // The glowing aura
    sphere {
        <0,0,0>,
        Radius_aura*(1+Intensity)
        pigment { rgbt 1 } hollow
        interior
        { media
            { emission Intensity*5
              density {
                function { Exp_decay(x,y,z) }
                color_map {
                    [0.0 rgbt <0,0,0,1>]
                    [0.5 rgbt <0.5, 0.5, 0.7,1>]
                    [1.0 rgbt <1,1,1,1>]
            media
            { absorption 0
        translate Origin
//    #end // end of #for loop
#end // ------------------ end of macro
you have rgb for absorption and transmission - try rgbt.
Also - since you're juxtaposing all those shapes, it may the coincident / near
coincident surface problem.
You may want to do the object as a plane or box with holes, or a hexagonal
pigment pattern instead.  You can _really_ fake 3D CSG with well-chosen and
applied pigments and textures.
https://mscharrer.net/povray/bridge/
Step-by-step instructions:   :)
http://www.f-lohmueller.de/pov_tut/backgrnd/p_wat4.htm
Date: 27 Oct 2017 21:02:57
Message: <59f3d741@news.povray.org>
> "Bald Eagle" <cre### [at] netscapenet> wrote:
>> It seems the thing to do is model the hexagonal unit cell, union it as an
>> all-inclusive object, and then repeat it in a hexagonal arrangement.
>> I'm also thinking that you probably don't even need to go the df3 file route,
>> since you're already calculating your field.  You can just use that function to
>> _directly_ define the density of your media.
>> Likewise, you can use that function to map your colors, and according to the
>> Bourke site,
>> "The POVRay file is here: example.pov, note that the density in this example
>> just controls the emission in the media."
>> - so the emission brightness can be controlled that way as well.
>> Just normalize your function so all values are within the 0-1 range.
>> Hit F1 and type density
>> then go to the density, media section:
>> 3.7.2.4 Density
>> "The density statement may begin with an optional density identifier. All
>> subsequent values modify the defaults or the values in the identifier. The next
>> item is a pattern type. This is any one of POV-Ray's pattern functions such as
>> bozo, wood, gradient, waves, etc. Of particular usefulness are the spherical,
>> planar, cylindrical, and boxed patterns which were previously available only for
>> use with our discontinued halo feature. All patterns return a value from 0.0 to
>> 1.0. This value is interpreted as the density of the media at that particular
>> point."
> What you write sounds extremely reasonable to me! I am right now generating the
> field data (sorry for the delay, the hard drive of my PC at work crashed
> completely ... 1 month before the end of my PhD phase). So I will try to figure
> out the density mapping post my results later.
> Until then, could someone of you have a look on the things that I tried related
> to the emitters: I basically created this macro to generated small spheres with
> a glowing "aura":
> #macro QuantumDot(Radius, Intensity, Origin)
>      sphere{
>          <0,0,0>, Radius
>          translate Origin
>      } // end of sphere
>      // The glowing aura
>      sphere {
>          <0,0,0>,
>          Radius* (Intensity*5 + 1)
>          interior
>          { media
>                density { spherical
>                    color_map {
>                      [0.0 rgb <0,0,0>]
>                      [0.6 rgb <0., 0., 0>]
>                      [0.7 rgb <0.6, 0.6, 0.6>]
>                      [1.0 rgb <1,1,1>]
>          translate Origin
> Although it looks quite nice to me, there is the problem that the emitting
> spheres do not "overlap" properly (I'd expect that the intensity of the emission
> would add up!?). Moreover, I would want a smooth fade-out of the aura, but yet
> it is dependent on the intensity: with Intensity=1 it looks fine, while
> Intensity=0.4 rather looks like an additional sphere. Please see the attachment.
> Any comments greatly appreciated :)
The media container on the right never overlap the other two, while
there is a visual overlap on the left, and maybe also a physical
overlap. Those overlaping part are known to cause that kind of problems.
You should use a single container. When you have multiple medias within
a single container, they add up.
Multiple densities within the same media will multiply instead.
So, you should place the small spheres, then fill a box with your medias.
You may need to increase the number of samples.
The render time will increase as the number of medias increase.
