POV-Ray : Newsgroups : povray.binaries.images : city building generator WIP Server Time
16 Mar 2026 07:38:53 EDT (-0400)
  city building generator WIP (Message 11 to 18 of 18)
Subject: Re: city building generator WIP
Date: 23 Jul 2017 07:47:23
Message: <59748ccb$1@news.povray.org>
On 7/22/2017 11:27 PM, Kenneth wrote:
> "omniverse" <omn### [at] charternet> wrote:
>> Main thing I was seeing was the cleanliness of the outer tops, especially
>> compared to the interior of roofs.
> Fixed!
> I also added some 'rain stains' under the windows, of the two most prominent
> buildings in the attached image.
> Currently, the buildings look too 'clean'. I'd *like* to add some overall subtle
> stains to the structural faces of the buildings-- but not to the glass windows.
> And that presents a practical problem, of how to go about it (due to the TILED
> nature of the window images.) Simply painting stains onto particular areas of
> the image tiles would end up looking too 'regular' and repetitive. The stains
> need to be larger and more random (like overlaying a subtle bump pigment onto
> the entire building face-- minus windows!)
> Hmm, I need to give this some thought...
Have you thought about using a proximity pattern? Norbert made one a few
years ago. Thomas used another one to good effect on a domed building.
Regards
Date: 23 Jul 2017 10:41:16
Message: <5974b58c$1@news.povray.org>
On 2017-07-22 06:27 PM (-4), Kenneth wrote:
> Fixed!
> [Snip]
On the building just right of center, due to the 3-D nature of the
architecture, it is obvious that you just used an image map.
Date: 23 Jul 2017 15:00:01
Message: <web.5974f054164bd7b0883fb31c0@news.povray.org>
Yeah; the buildings definitely need some 'dimensionality.' (I actually hadn't
planned on the camera looking at them so closely-- but the more I work on the
scene, the more I want the camera 'in and among' the buildings!) I've done a
crude heightfield test for the faces of one of the buildings, and the results
look promising; but my current scene code isn't yet set up for that. I
essentially need to re-write it-- I think--if I go that route :-(
Also, some of the image map tiles are of WAY too low a resolution for
close-ups... which I didn't plan for originally :-/ I may have to search through
my OWN hi-rez photos of building facades (that I've taken over the years) to
pick some better ones. OR try and write a complex 'facade generator' in POV-ray,
and use all procedural textures instead. More work!!
Date: 23 Jul 2017 15:25:01
Message: <web.5974f724164bd7b0883fb31c0@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> The bigger *main* problem I'm currently running into is that 'patterned
> textures' cannot have additional overlayed textures applied to them...
By the way: Because of this limitation, each building is actually TWO boxes,
scaled differently (by .0001 in certain dimensions) and *very slightly*
overlapped-- one box to show the front-back faces, the other for the left-right
faces. In other words, I couldn't use just ONE box with multiple textures like
this...
object{building_box
       texture{..front-and-back..}
       texture{..left-and-right..)
.... because those would be 'overlayed textures'-- and are not allowed.
But it wasn't a big deal to do-- and rather fun to code ;-) You can't see the
tiny overlaps unless you look REALLY closely at the buildings' edges (I hope!)
POV-ray can also apply uv-mapping to a box-- but I didn't consider doing that,
because of the crazy/complex nature of my tiled-image code, my 'boxed' pattern
and image_pattern use, etc. etc. Maybe when my brain power increases by at least
a factor of 2, I'll give that a try :-P
Date: 23 Jul 2017 17:40:49
Message: <597517e1@news.povray.org>
> this...
> object{building_box
Why don't you try the cubic pattern?
It allow you to give distinct textures to each faces of a cubic shaped
object. As your buildings are not cubes, you'll need to scale that
pattern to fit.
Date: 23 Jul 2017 20:45:00
Message: <web.5975421b164bd7b0883fb31c0@news.povray.org>
That's something I never thought of-- and have never used! I will definitely
take a look at it. Thanks!
Date: 24 Jul 2017 04:39:21
Message: <5975b239$1@news.povray.org>
Kenneth wrote on 21/07/2017 21:05:
> I've been working on a 'city building generator'-- part of my earlier post re:
> 'green gas cloud.' I put aside the media cloud for now...
> Currently, the buildings are just randomly placed. I've made no attempt to put
> them into a 'street grid' yet. (Perhaps real-world real-estate prices will be so
> high in the future that buildings will NEED to be overlapped by economic
> necessity, ha!)
I like them! I'm curious to see further evolutions of your generator.
Paolo
Date: 24 Jul 2017 17:35:00
Message: <59766804@news.povray.org>
Neither did I.
I think that it did'nt exist before version 3.7...
