POV-Ray : Newsgroups : povray.binaries.images : Reflectance of 3D canopy Server Time
20 Jun 2025 11:15:02 EDT (-0400)
  Reflectance of 3D canopy (Message 1 to 10 of 20)
Subject: Reflectance of 3D canopy
Date: 20 Mar 2017 10:35:01
Message: <web.58cfe775bc9274bfcf0bfa9c0@news.povray.org>
from [povray.general]
Am 20.03.2017 um 11:38 schrieb muyu:
> Thanks. 1) Regarding my simulations, around 50% of the light is reflected in
> near-infrared. So physically the expected error should be much less than 1%.
> This should be neglible?
> 2) However, I found almost 10%  under-estimates compared with the reference
> using Monte Carlo method. What's the possible reasons for this? Should I
> increase the brightness or the light intensity?
No ideas at the moment. Maybe if you posted the resulting images, the
distribution of light within the canopy might give a hint.
You mentioned reflection above; did you also account for the transmitted
light?
Here it is the setting of the radiosity:
#version 3.7;
global_settings {
   assumed_gamma 1.0
   ambient_light 0.0
   adc_bailout 0.0
   max_trace_level 20
   radiosity {
      count 1500
      error_bound 0.01
      recursion_limit 20
      nearest_count 10
// light--------------------------------------------------------------
light_source{<0,36.397,100> color rgb<0,1,0> parallel}
// ground ------------------------------------------------------------
plane { <0,0,1>, 0
        texture{ pigment{color rgb<0, 1, 0>}
                 finish {ambient 0 diffuse 0.1590 0.0000}
               } // end of texture
      } // end of plane
// leaves----------------------------------------------
#declare leaf_text = texture {
pigment {color rgb<0.0,1.0,0.0>}
finish {ambient 0 diffuse 0.4957 0.4409}}
disc {<9.5780,-10.5050,0.6040>, <0.7070,0.1830,0.6840>, 0.0500
texture {leaf_text}}
diffuse 0.4957 is front diffuse, 0.4409 is the transmitted light? Should I set
rgbt or rgbf?
Is this the right way to consider the multi-scattering using Radiosity? I have
the impression that some processes are missing?
Thax in advance.
Download 'canopy_2_camera.png' (651 KB)
Preview of image 'canopy_2_camera.png'
Subject: Re: Reflectance of 3D canopy
Date: 20 Mar 2017 10:55:00
Message: <web.58cfece82e25eba1cf0bfa9c0@news.povray.org>
> light?
> #version 3.7;
> global_settings {
>    assumed_gamma 1.0
>    ambient_light 0.0
>    adc_bailout 0.0
>    max_trace_level 20
>    radiosity {
>       count 1500
>       error_bound 0.01
>       recursion_limit 20
>       nearest_count 10
> plane { <0,0,1>, 0
>                } // end of texture
>       } // end of plane
> rgbt or rgbf?
> Thax in advance.
Antialias = on
Antialias_Threshold = 0.1
Antialias_Depth = 2
Input_File_Name = "canopy_2_camera.pov"
width = 1000
height = 1000
Cyclic_Animation = on
Pause_when_Done = off
The reflectance of each pixel was calculated relative to the reference panel
with the same light source and camera setup
// the reference panel--------------------------------------------------------
plane { <0,0,1>, 0
                 finish {ambient 0 diffuse 1.0 0.0 conserve_energy}
               } // end of texture
      } // end of plane
Reflectance = (Simulation/Reference)^2.2
Is this calibration right? Thanks again.
Download 'ref_plane.png' (6 KB)
Preview of image 'ref_plane.png'
Date: 21 Mar 2017 10:12:14
Message: <58d134be$1@news.povray.org>
> #version 3.7;
> rgbt or rgbf?
> Thax in advance.
Not been following closely, but on seeing some images and code some a
few thoughts pop into my head.
Just a thought, but in play here is perhaps that the 'disc' object has
no thickness. This means rays which are nearly parallel with the plane
of a disc will resolve somewhat noisily (more light transport than
should be I suppose) and also that light will not attenuate/scatter in
the leaf's thickness(1).
Perhaps give us a short description of your Monte Carlo simulation
"standard." Is this also done in POV-Ray? A stand along program or?
Aside: I thought the second diffuse parameter required a proceeding
comma, but if working OK for you must not be the case... :-)
Bill P.
(1) - More accurate leaves could be modeled in POV-Ray, but suspect it
would be costly in terms of complexity and compute resource.
Date: 21 Mar 2017 20:14:34
Message: <58d1c1ea$1@news.povray.org>
Am 21.03.2017 um 15:12 schrieb William F Pokorny:
All commas in POV-Ray's scene description language are optional --
unless the second expression has a leading `+` or `-` sign, which would
be interpreted as a mathematical operation without a comma; it is
therefore a good habit to make liberal use of commas.
Date: 22 Mar 2017 18:50:00
Message: <web.58d2ff512e25eba18f08ce6d0@news.povray.org>
Thanks. Do you have any suggestions to improve the accuracy of radiosity
simulation? The back side diffuse is well taken into account in Pov-ray? Should
I improve brightness or light intensity?
Date: 23 Mar 2017 05:55:01
Message: <web.58d39b702e25eba1cf0bfa9c0@news.povray.org>
> > #version 3.7;
> > rgbt or rgbf?
> > Thax in advance.
> Bill P.
Thanks. The Monte Carlo simulation was generated by other softwares. I did not
know much details about it. But they were considered as the reference to
evaluate other methods.
1) Disc of negligible thickness...the same as in the Monte Carlo methods.
2) Now my simulations using Pov-ray radiosity were around 5 to 10% lower than
the reference even I set the recursion time as 20. I am wondering if Pov-ray
miss some physical processes or I can further improve the accuracy by tunning
some parameters. Brightness or light intensity etc...?
Thanks in advance.
Shouyang
Date: 23 Mar 2017 10:29:47
Message: <58d3dbdb$1@news.povray.org>
> Thanks in advance.
> Shouyang
Christoph (clipka) & others understand the light and color modeling in
POV-Ray far better than me. I know for example there are various diffuse
models, but not in detail how they differ. See for example :
http://news.povray.org/povray.unofficial.patches/thread/%3C57be5290%241%40news.povray.org%3E/
for a pointer to an alternate version of POV-Ray (uber) offering
additional methods.
Without knowing more about the standard simulation against which you are
comparing, we're of course doing a good deal of guessing as to what
might be different.
How much does POV-Ray itself vary run to run on changing the (random
within a container?) disc placements? Is this difference reflected by
the 5-10% range you mention or is this change due changes in other
"leaf" parameters?
Another thought. With your POV-Ray disc placement are you avoiding
collisions? If not, might the standard method be?
If I think of something else, I'll post.
Bill P.
Date: 23 Mar 2017 15:33:31
Message: <58d4230b@news.povray.org>
Am 20.03.2017 um 15:53 schrieb muyu:
>> light?
That's 0.9366 in total, which means that at each radiosity recursion
step, 93.66% of the light is /not/ absorbed.
Which means that after 20 recursion steps, 26.98% of the light is
/still/ not absorbed.
>> rgbt or rgbf?
Don't use `rgbt` nor `rgbf`, unless your similated leaves are supposed
to transmit a portion of the light unscattered.
> plane { <0,0,1>, 0
>                } // end of texture
>       } // end of plane
Are you using File_Gamma=2.2, or why is that exponent in there?
Date: 23 Mar 2017 19:15:01
Message: <web.58d454582e25eba14ebdc22e0@news.povray.org>
> >> light?
> >> rgbt or rgbf?
For each leaf, 0.4957 is scatted directly. 0.4409 is transmitted and scatted. So
as I understood, I should not use any filter. The two sides diffuse is the right
choice. Am I right? So it means 20 times of recursion is not enough? Is it
possible to set larger value.Now for me, the rendering time is still
acceptable.
> > plane { <0,0,1>, 0
> >                } // end of texture
> >       } // end of plane
Here I did not set File_Gamma = 1.0. But the result should be same if I use this
Reflectance = (Simulation/Reference)^2.2.
Thanks again.
Shouyang
Date: 24 Mar 2017 17:34:42
Message: <58d590f2$1@news.povray.org>
Am 24.03.2017 um 00:14 schrieb muyu:
> choice. Am I right?
Yes, you are.
> acceptable.
If building your own modified POV-Ray binaries is an option, you could
edit the definition of DEPTH_MAX in `source/core/lighting/radiosity.h`.
>>> plane { <0,0,1>, 0
>>>                } // end of texture
>>>       } // end of plane
Note that for most output file formats (including JPEG and PNG) POV-Ray
3.7 uses the sRGB encoding transfer function by default (and for those
where it doesn't, it defaults to linear output or the ITU-R BT.709
transfer function). For the power-law with an exponent of 2.2 to give
correct results, you should use `File_Gamma=2.2`. (Or instead apply the
sRGB decoding transfer function to sim and reference separately, and
then divide.)
Also, make sure the software you are using to compute the reflectance
does indeed operate on gamma-encoded values.
