POV-Ray : Newsgroups : povray.binaries.images : Tracing the path of streams Server Time
5 Apr 2026 12:18:50 EDT (-0400)
  Tracing the path of streams (Message 28 to 37 of 77)
Subject: Re: Tracing the path of streams
Date: 17 Feb 2017 13:50:00
Message: <web.58a7456bbd8ebaff102e48c00@news.povray.org>
"Kirk Andrews" <kir### [at] tektonartcom> wrote:
> To do this *right*, I'm thinking you'd have to do a full-blown physics
> simulation.
Hey Kirk,
I'm not sure if this is helpful or not, but if your computer has a GPU
supporting pixel shaders, check out this one I posted a while back:
https://www.shadertoy.com/view/XsKGWG
It approximates hydraulic erosion on a height map, using a sort of basin-filling
method as a key part of the process. It won't form rivers on flat plains, since
momentum isn't taken into account (would need to probably implement
Navier-Stokes equations for that, which would be difficult using Shadertoy since
a fluid sim needs to iterate over a certain operation some 30-50 times per
frame, to the same texture). Also, the lakes seem to be slightly sloped.
Sam
Date: 17 Feb 2017 15:55:00
Message: <web.58a762ccbd8ebaff66e1985f0@news.povray.org>
> > simulation.
> Hey Kirk,
> Sam
Wow! I'd never heard of Shadertoy. Is it possible to download the resulting
height map?
Date: 17 Feb 2017 18:35:00
Message: <web.58a7881bbd8ebaff102e48c00@news.povray.org>
> > > simulation.
> > Hey Kirk,
> > Sam
> height map?
It's possible, but will require editing the source code of the Image shader to
have it display only the height map (or water map, or both [hint: the landMap()
and waterMap() functions give this data]). You can then (in Firefox) right click
on the display window and choose Save Image As... Unfortunately this will only
get you an 8 bit image. For 16 bit data, you'll need to convert it over to the
red/green format (which POV-Ray supports) and then save. (For all I know saving
16 bit data from Shadertoy might be possible if you know Java.)
Better yet is to get your own shader program up-and-running using SFML or the
like. (Although the last I heard SFML would only support 8 bit textures, the
devs assuming anything else was unnecessary :P I was able to add 16 bit texture
support myself, but who knows how many versions ago that has been...)
Sam
Date: 18 Feb 2017 00:10:01
Message: <web.58a7d61dbd8ebaffd61e8dc40@news.povray.org>
> > simulation. But, I'm wondering if we can't get to a reasonable approximation
> > with some extra trace checks. Right now, it's only checking straight down from
> > above, but if we also checked across from the center point, maybe we could
> > eliminate points that didn't have a straight path from here to there. I
> > experimented with that idea some but I can't tell if it's really working yet.
> Or, I suppose it could be as simple as what paint programs do with the fill
> tool, and treat it more like square pixels.
really what pulled me into the world of programming, and I'm incredibly thankful
for that. In the years since I left off of POV, I've been doing more and more
coding, mostly in PHP and javascript. So it's a bit of a shock to jump back into
POV and try and code things in SDL, and realize all the things I can't do! It
definitely forces you to get creative. It also makes you think hard about
optimizing your code, since you know any inefficiencies will likely have
significant impacts in parsing time.
Date: 18 Feb 2017 03:10:10
Message: <58a80162$1@news.povray.org>
On 17-2-2017 14:29, Kirk Andrews wrote:
> That's looking really good, Thomas!
Thanks, yes, especially the second image, which indicates to me that a
well-behaving substrate does wonders for your little code ;-)
> Which software are you using for erosion? Now that I don't have a PC anymore,
> I've got to find something to run on my Mac.
I am afraid that most are Windows only.
There is Wilbur http://www.fracterra.com/software.html which does a very
good job in tracing river patterns but needs a very noisy substrate to
do it correctly so additional smoothing is necessary (in Wilbur or - as
I do - in another application);
Terrabrush http://www.cyberfunks.de/page/terrabrush/index.htm is another
program I use in between but not so good for erosional processes;
GeoControl (which now seems to be WorldCreator I discover)
http://www.world-creator.com/ is not a free program. It is the heart of
my height_field creation modules. It does a fair erosion job. I don't
know about its latest versions though;
World Machine http://www.world-machine.com/ you already know.
I also grabbed a free copy of Bryce 7 when DAZ made it available a few
years ago. It can generate some interesting height_fields to serve as
basis for deeper treatment later.
Interestingly, You can make fascinating height_fields with Apophysis
flames as basis https://sourceforge.net/projects/apophysis/ . Loaded
into GeoControl for instance, the pattern is transformed into an
interesting landscape.
Date: 22 Feb 2017 07:17:56
Message: <58ad8174@news.povray.org>
> https://www.dropbox.com/s/49nmnd5z1kzhms0/Water4.pov?dl=0
This version does interesting things, different from the previous one. I
am not entirely sure if it solves the problem and I need to investigate
further.
Download 'ka_water4.jpg' (210 KB)
Preview of image 'ka_water4.jpg'
Date: 22 Feb 2017 07:47:40
Message: <58ad886c@news.povray.org>
> further.
I think it is worthwhile to re-think the random starting point code as
the existing one has not a coverage including the complete terrain.
I use RRand() from rand.inc (to be included into the scene) in the
following manner:
First, add the following lines after the height_field making:
#declare Min = min_extent(Terrain);
#declare Max = max_extent(Terrain);
Then replace the line:
   #declare Pos = trace(ThisTerrain, <rand(r)-.55, 10*Flattening,
rand(r)-.55>*0.9*TS, -y);
by:
   #declare Pos = trace(ThisTerrain, <RRand(Min.x, Max.x, r),
10*Flattening, RRand(Min.z, Max.z, r)>, -y);
The result is shown in the attached image, searching for 100 streams I
commented out the black cones).
Download 'ka_water4.jpg' (186 KB)
Date: 22 Feb 2017 08:05:00
Message: <web.58ad8bc4bd8ebaffc437ac910@news.povray.org>
> following manner:
Can you also use VRand_In_Obj ?
What ..... stream are you using?   :D
Date: 23 Feb 2017 03:17:06
Message: <58ae9a82@news.povray.org>
>> following manner:
Yes, of course. It is a matter of taste imho.
Another interesting option would be to use a pigment_pattern, or an
image_pattern of a flow map, and only allow for streams to start from
the higher grounds. Hmm... going to have to implement that...
Date: 23 Feb 2017 07:15:12
Message: <58aed250@news.povray.org>
Overall, I think that version 4 is doing a good job and solves the
problem of version 3. The attached image demonstrates that. Never mind
the columns for supporting the sky ;-) Those are little troubles at the
height_field's edges.
Download 'ka_water4.jpg' (180 KB)
