POV-Ray : Newsgroups : povray.binaries.images : RockTest.pov reference image Server Time
2 Jun 2024 13:14:08 EDT (-0400)
  RockTest.pov reference image (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: RockTest.pov reference image
Date: 13 Dec 2016 17:20:01
Message: <web.5850736067b6c8b61c3f31c90@news.povray.org>
> > "Cousin Ricky" <rickysttATyahooDOTcom> wrote:
> >> "[GDS|Entropy]" <nomail@nomail> wrote:
> >>> Here is an "angry" media sky output from the Sky macro.
> >> Cecil B. DeMille worthy!
> > Thank you. :)
> > My goal is to build a fairly comprehensive "Environmentals" macro set that is
> > both simple to use and nice looking. Given that they are designed to work
> > together it should take a LOT of the work out of creating natural scenes, and
> > hopefully inspire some scenes.
> > The Rocks macro is coming close to completion, for version 1 at least, and the
> > Terrain macro is close behind it. Next in the set is the Skies and Fogs.
> > The Fog is being a little weird, because Media without a container is only
> > visible when looking at the plane below it, and it vanishes above the horizon.
> > ?! Weeeird. Very counterintuitive.
> > Any idea why this is, and how to fix it? Is the only choice to bound the media?
> > I am guessing that this is because it is not reasonable to calculate media for
> > an infinite space, but I could be wrong.
> You are correct on this point. Media sampling can only be computed
> between two deffined points. When you reatch the background, the far
> point is undefined, making the computation impossible.
> Solution : Place a background plane behond the scene. Make it no_image,
> no_shadow, no_refection and no_radiosity.
> Alain
When I tried that, the media disappeared entirely, here is the plane I used:
plane
    z,
    100
    no_radiosity
    no_image
    no_shadow
    no_reflection
Did I miss something?
Thanks!
Ian
Date: 13 Dec 2016 17:51:20
Message: <58507b68$1@news.povray.org>
>>> Thank you. :)
>> Alain
> plane
>     z,
>     100
>     no_radiosity
>     no_image
>     no_shadow
>     no_reflection
> Thanks!
> Ian
Your plane is facing away from the camera, placing the camera /inside/
the plane.
Add hollow to your plane or reverse it's normal and offset.
plane{
  -z, -100 // Makes the plane face the camera
  no_radiosity no_image no_shadow no_reflection
OR
plane{
  z, 100
  hollow // allow media to exist "inside" the plane
You could also use inverse instead of hollow or revercing the plane
orientation.
Date: 13 Dec 2016 18:10:01
Message: <web.58507ecf67b6c8b61c3f31c90@news.povray.org>
> >>> Thank you. :)
> >> Alain
> > plane
> >     z,
> >     100
> >     no_radiosity
> >     no_image
> >     no_shadow
> >     no_reflection
> > Thanks!
> > Ian
> the plane.
> plane{
> OR
> plane{
>   z, 100
> orientation.
> Alain
That does make the media reappear [using either inverse or hollow], but also
retains the issue of the media vanishing above horizon. I must really be borking
this up lol! :)
Ian
Date: 13 Dec 2016 19:14:50
Message: <58508efa$1@news.povray.org>
Am 13.12.2016 um 22:15 schrieb [GDS|Entropy]:
Doesn't sound like something that should happen.
Care to share any details?
Date: 13 Dec 2016 21:35:00
Message: <web.5850afb167b6c8b61c3f31c90@news.povray.org>
Sure. :)
The plane in there seems to have no effect, commented or no, which seems to be
improper based on what Alain was saying. Here is a minimal scene which
reproduces the effect being discussed.
#include "functions.inc"
#macro RRand(RS, Min, Max)
    (rand(RS) * (Max - Min) + Min)
#declare Radiosity = true;
#declare AreaLight = true;
#declare globalFogActive = true;
#declare globalFogDensity = true;
#declare globalFogBaseValue = 0.1;
#local ScaleAmount = 120.0;   //    Was 60.
#local ScaleFactor = ScaleAmount / ((ScaleAmount * 2.50) * (log(ScaleAmount)));
#local ColorFactor = (((ScaleAmount * ScaleFactor) / (ScaleAmount)) /
(ScaleFactor * ScaleFactor));
global_settings
    assumed_gamma 1.0
    //max_trace_level 25
    #if (Radiosity)
        radiosity
            pretrace_start      0.08    //    start pretrace at this size
            pretrace_end        0.04    //    end pretrace at this size
            count               35      //    higher -> higher quality (1..1600)
[35]
            nearest_count       5       //    higher -> higher quality (1..10)
[5]
            error_bound         2.8     //    higher -> smoother, less accurate
[1.8]
            recursion_limit     6       //    how much interreflections are
calculated (1..5+) [3]
            low_error_factor    0.5     //    reduce error_bound during last
pretrace step
            gray_threshold      0.0     //    increase for weakening colors
(0..1) [0]
            minimum_reuse       0.015   //    reuse of old radiosity samples
[0.015]
            brightness          1       //    brightness of radiosity effects
(0..1) [1]
            adc_bailout         0.01 / 2
            //normal on                 //    take surface normals into account
[off]
            media on                    //    take media into account [off]
            //save_file "file_name"     //    save radiosity data
            //load_file "file_name"     //    load saved radiosity data
            //always_sample off           //    turn sampling in final trace off
[on]
            always_sample on
            //max_sample 1.0            //    maximum brightness of samples
#default
    texture
        pigment
            rgb 1
        #if (Radiosity)
            finish
                ambient 0.0
                diffuse 0.6
                specular 0.3
        #else
            finish
                ambient 0.1
                diffuse 0.6
                specular 0.3
#if (AreaLight)
    light_source
        0 * x
        color rgb <0.2734, 0.5078, 0.7031>
        area_light
        <100, 0, 0>
        <0, 0, 100>
        4, 4
        adaptive 0
        jitter
        translate <0,1000,-2000>
        photons
            refraction on
            reflection on
#else
    light_source
        0 * x
        color rgb <1, 1, 1>
        translate <-20, 40, -20>
        photons
            refraction on
            reflection on
        camera
         location <-5, 6, -18>
         up y * image_height
         right x * image_width
         look_at <0, 1.5, 0>
         angle 45
plane
    z,
    100
    no_radiosity
    no_image
    no_shadow
    no_reflection
    inverse
//    Global media.
#macro GlobalFog(base, useDensity)
    #if (useDensity)
        media
            method 3
            //samples 10, 100
            samples 1, 10
            scattering
                1, <1, 1, 1> * 0.01
            intervals 15
            density
                //granite   //    Very wispy.
                bumps     //    Smooth, evenly changing density.
                #if (ScaleAmount > 15)
                    scale 1 / ScaleAmount
                color_map
                    #local Kk = 0;
                    #while(Kk <= 10)
                        #if (Kk = 0)
                            [Kk * 0.1 rgb <Kk, Kk, Kk>]
                        #else
                            [Kk * 0.1 rgb <Kk, Kk, Kk> * (base + 0.1) /
ScaleFactor]
                    #local Kk = Kk + 1;
                    #while(Kk >= 10)
                        #if (Kk = 0)
                        #else
                            [Kk * 0.1 rgb <Kk, Kk, Kk> * (base + 0.0) /
ScaleFactor]
                    #local Kk = Kk - 1;
                turbulence 0.25
    #else
        media
            method 3
            //samples 10, 100
            samples 1, 10
            scattering
                1, <1, 1, 1> * 0.01
            intervals 15
#if (globalFogActive)
    GlobalFog(globalFogBaseValue, globalFogDensity)
#declare f_Height =
function
    0.5 * f_wrinkles(x * 0.4, y * 0.4, z * 0.4)
#macro Ground(Height, Extent)
    #local eX = Extent.x;
    #local eY = Extent.y;
    #local eZ = Extent.z;
    #local GroundSurface =
    isosurface
        function
            //(y - f_Height(x, -1, z)) / Height
            (y - (0.5 * f_wrinkles(x * eX, y * eY, z * eZ))) / Height
        max_gradient 2.0
        contained_by
            box
                <-400, -5, -400>,
                <400, 0.15, 400>
        accuracy 1e-3
    object
        GroundSurface
#local GroundExtent = <0.4, 0.4, 0.4>;
Ground(10.6, GroundExtent)
#macro DistributePoles(Extent, CameraLocation)
    #local RsA = seed(112080);
    #local Poles =
    union
        #local I = -Extent;
        #while(I < Extent)
            #local J = -Extent;
            #while(J < Extent)
                cylinder
                    <I, 0, J> * 2,
                    <I, 1, J> * 2,
                    0.25
            #local J = J + 1;
        #local I = I + 1;
    object
        Poles
        translate <Extent * 0.5, 0, Extent * 0.5>
#local Extent = 20;
DistributePoles(Extent, <0, 10, -10>)
Date: 14 Dec 2016 00:10:00
Message: <web.5850d3a067b6c8b69c5d6c810@news.povray.org>
> Sure. :)
'Official' and 'alpha' versions render differently so something changed, I guess
you're not using official 3.7? I get the black void in 3.7.1.1-alpha, while
official 3.7.0 shows oversaturation of media as would be expected.
If you add the following spotlight to your (1st) light, it can apparently create
a finite region for the rays. That is mentioned in the docs:
http://wiki.povray.org/content/Reference:Atmospheric_Media
  spotlight point_at <0,-1,1> radius 18 falloff 20
This could take some tweaking to get better, I just threw it in there, but there
didn't seem to be much range beyond that radius and falloff before it fails to
look okay again. Maybe with better point_at angle, just so it isn't directed
into infinity again.
Date: 14 Dec 2016 00:30:00
Message: <web.5850d83e67b6c8b61c3f31c90@news.povray.org>
> > Sure. :)
> Bob
You are correct I am using UberPov, but didn't think to include that information
because I had seen this before [above horizon cutoff] in other versions of Pov.
Ian
Date: 14 Dec 2016 00:44:32
Message: <5850dc40$1@news.povray.org>
Am 14.12.2016 um 06:07 schrieb omniverse:
>> Sure. :)
Actually, no, that's not what is happening.
Official 3.7.0 shows oversaturation simply because media sampling method
3 had always been buggy, showing somewhat wrong results wherever the
actual number of samples is low (such as in uniform media); this has
been fixed in 3.7.1.
With media sampling methods 1 and 2, POV-Ray has always (since 3.6.2 at
any rate) shown the very same symptoms.
To demonstrate that 3.7.0 sampling method 3 behavior /cannot/ be
correct, just notice how the oversaturation disappears close to the
horizon. With proper computations we should expect exactly the opposite
effect.
Date: 14 Dec 2016 01:18:06
Message: <5850e41e$1@news.povray.org>
 also
e borking
> this up lol! :)
	Don't make the plane no_image no_reflection, and instead make it fully
transparent (rgbt 1).
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Date: 14 Dec 2016 02:35:01
Message: <web.5850f58967b6c8b69c5d6c810@news.povray.org>
>  also
> e borking
> > this up lol! :)
Must be the no_image. I tried doing that, pigment {rgbt 1}, and it isn't needed
either.
Thanks Clipka for the media 3 explanation.
