![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: assumed_gamma, overlapping textures and transmit.
Date: 18 Oct 2016 12:29:17
Message: <58064ddd@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
With the recent discussions related to gamma handling I thought I'd post
an image comparing how transmit behaves with respect to assumed_gamma in
a texture overlaid upon an image base texture. The behavior of transmit
at an assumed_gamma (ag) of 1.0 is something I like less well than its
behavior at an ag of 2.2.
In the attached image I am comparing ag of 1.0 to an ag of 2.2 in each row.
There is a base image_map texture on a plane. Over the top of that
texture is another with 5 columns of 4 colors (0,0.5,1.0,2.0) where the
5 columns have transmit values of: 0,0.5,1.0,1.5,2.0. One parallel light
source, camera orthographic, ambient 0, diffuse 1.0.
The non-linear behavior of transmit in the ag 2.2 case is often helpful
to the final appearance of layered textures - the gray out region is
tighter. When trying to map a 2.2 texture say from Norbert's collection
into my ag 1.0 working space, I start by converting any rgb colors to
srgb (bottom row), but that is usually not enough if the transmit value
in any part of the texture is not 0.0 or 1.0.
I usually end up thrashing around with colors and transmit values to get
closer, but truth is I'm often not able to match exactly the ag 2.2
look. Might be different if I started from scratch I guess.
Am I missing some technique? Are there proposals in the works - or
better available - which might help?
Aside: I have been wondering for a while about a more probabilistic
pixel based transmit mode for blending overlapping textures. Might such
an approach help with the dulling/graying of overlapping partly
transparent textures...
Bill P.
Download 'comparetransmitgammahandling.jpg' (876 KB)
Preview of image 'comparetransmitgammahandling.jpg'
![comparetransmitgammahandling.jpg](/povray.binaries.images/attachment/%3C58064ddd%40news.povray.org%3E/comparetransmitgammahandling.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: assumed_gamma, overlapping textures and transmit.
Date: 18 Oct 2016 14:36:06
Message: <58066b96$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 18.10.2016 um 18:29 schrieb William F Pokorny:
Your example uses very unsaturated colours; to get the full picture, you
should also try the same experiment with highly saturated colours. I can
imagine that you'll come to different conclusions there.
What do you mean by "probabilistic pixel based transmit mode"?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Quantum simulation of photons :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 19 Oct 2016 06:20:24
Message: <580748e8$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Will put it on the todo list - would suppose I'd notice the greying
transitions less in such an experiment. The image used was one where I'd
struggled with transparent textures and getting a "blend" between
textures that I wanted.
I have in mind some sort of sampling between textures weighted by the
transmit values involved. Suppose somewhat like the blending which
happened in the tilt shift image I posted recently. I admit though, I'm
thinking aloud.
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 19 Oct 2016 06:21:31
Message: <5807492b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
:-) With those new quantum computers, it will be easy.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 19 Oct 2016 07:16:14
Message: <580755fe$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 18-10-2016 18:29, William F Pokorny wrote:
> [snip]
Out of curiosity: what is a transmit value >1.0?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 19 Oct 2016 08:09:35
Message: <5807627f$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> [snip]
People use >1 sometimes to amplify colors or increase contrast.
I think Norbert used this technique for one of his recent,
http://www.tc-rtc.co.uk/, metal monster images.
It isn't the most stable technique as can be seen in the right part of
the posted images. I'd say use values in the 0 to 1 range as a rule.
Aside: I have a question rattling around in my head as to why the higher
values tend toward black.
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is the problem here though is that you're trying to solve this by
tweaking gamma? Maybe it works for this issue, but it's also going to
affect all the other lighting and colours in your scene.
The better approach would be to figure out how to achieve what you want
without changing the scene-wide gamma setting. What if you adjust the
gamma of the image and the "gamma" of your rgbt values (ie don't step in
equal steps for each column)? You might have to sit down and work out
the maths to get what you want without changing assumed_gamma.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 19 Oct 2016 13:18:33
Message: <5807aae9$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 19.10.2016 um 12:21 schrieb William F Pokorny:
Such a simulator already exists -- it's called Reality ;)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 19 Oct 2016 13:29:36
Message: <5807ad80@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 19.10.2016 um 12:20 schrieb William F Pokorny:
> thinking aloud.
You mean, something like using the "average" pseudo-pattern to textures,
but with the weight being modulated by the textures' "transmit" channel?
While that sounds interesting, a major drawback would be that the
"transmit" channel couldn't be used for its original purpose, namely
specifying transparency of the texture.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
