POV-Ray : Newsgroups : povray.binaries.images : The brick size in normals. Server Time
20 Jun 2025 23:37:12 EDT (-0400)
  The brick size in normals. (Message 1 to 8 of 8)
Subject: The brick size in normals.
Date: 8 May 2016 02:10:01
Message: <web.572ed7046734ae347a3e03fe0@news.povray.org>
Problem.
If I use custom brick_size I have the incorrect image.
#version 3.7;
#include "functions.inc"
global_settings {
    assumed_gamma 1.000000
    max_trace_level 3
    charset utf8
sky_sphere {
    pigment {rgb<0.050, 0.050, 0.050>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare Material = texture{
    pigment{color srgbft <0.8000,0.8000,0.8000,0.0000,0.0000>}
    normal{ brick 0.9000
        brick_size <0.2500,0.0525,0.1250> mortar 0.0100
        warp {planar z 1}
        translate <0.0000,0.0000,0.0000>
        rotate <0.0000,0.0000,0.0000>
        scale <1.0000,1.0000,1.0000>
    finish{
        diffuse 0.8000
        brilliance 1.8000
        crand 0.0000
        emission 0.0000
        ambient <0.0000,0.0000,0.0000>
#declare data_Plane_dec =
mesh2 {
    vertex_vectors {
    4
    <-1.000000,-1.000000,0.000000>
    <1.000000,-1.000000,0.000000>
    <-1.000000,1.000000,0.000000>
    <1.000000,1.000000,0.000000>
    normal_vectors {
    2
    <-0.000000,0.000000,1.000000>
    <0.000000,0.000000,1.000000>
    uv_vectors {
    4
    <0.000100, 0.000100>
    <0.000100, 0.999900>
    <0.999900, 0.000100>
    <0.999900, 0.999900>
    texture_list {
    1
    texture {Material}
    face_indices {
    2
    <1,3,2>,0,0,0
    <0,1,2>,0,0,0
    normal_indices {
    2
    <0,0,0>
    <1,1,1>
    uv_indices {
    2
    <2,3,1>
    <0,2,1>
object {data_Plane_dec
    matrix <3.003955, 0.000000, 0.000000,  0.000000, -0.000000, -3.003955,
0.000000, 3.003955, -0.000000,  0.000000, 0.000000, 0.000000>
light_source {
    <5.07,5.58,4.28>
    color rgb<1, 1, 1>
    fade_distance 25.0000000000
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-27.098163, 46.688390, -0.903519>
    translate <7.481132, 5.343666, 6.507640>
Download 'custom_brick_size.jpg' (102 KB)
Preview of image 'custom_brick_size.jpg'
Subject: Re: The brick size in normals.
Date: 8 May 2016 03:20:39
Message: <572ee8c7@news.povray.org>
> Problem. If I use custom brick_size I have the incorrect image.
 From http://www.povray.org/documentation/view/3.7.0/368/ :
"The bricks are offset by half a brick length on every other row in the
x- and z-directions."
   Thant means it will only look good on the x-y and z-y planes. If you
want it to show correctly on the x-z plane, you should rotate it (i.e.
rotate 90*x).
jaime
Date: 8 May 2016 04:40:01
Message: <web.572efa7ad3c58d897a3e03fe0@news.povray.org>
> rotate 90*x).
> jaime
The source code is written above. Turn, please, and show!
I already overwound everything. I tried to use uv_mapping, warp planar (x,y,z)
rotate(x,y,z,xy,xz,yz,xyz)
Date: 8 May 2016 09:34:04
Message: <572f404c$1@news.povray.org>
> The source code is written above. Turn, please, and show! I already
   I was wrong... you are already applying correctly the normal, but it
seems like the brick pattern isn't behaving correctly on a normal statement.
   Using this one:
     pigment{brick brick_size <0.2500,0.0525,0.1250> mortar 0.0100}
     finish{
         diffuse 0.8000
         brilliance 1.8000
         crand 0.0000
         emission 0.0000
   the pigment shows correctly.
   But adding a matching normal:
     normal{brick brick_size <0.2500,0.0525,0.1250> mortar 0.0100}
     finish{
         diffuse 0.8000
         brilliance 1.8000
         crand 0.0000
         emission 0.0000
   the result shows a mismatched normal. Don't know why... I think I used
this on the past and it worked fine.
jaime
Date: 8 May 2016 10:00:10
Message: <572f466a@news.povray.org>
Am 08.05.2016 um 08:04 schrieb LanuHum:
> Problem.
To compute normal perturbations for most patterns, POV-Ray samples the
pattern at 4 points in the vicinity of the surface point.
Obviously, the distance between those 4 sample points is not infinitely
small; as a matter of fact, it is in the order of magnitude of 0.02. As
you will notice, your brick_size parameters are close to that value.
To get the desired effect, it is sufficient to increase the brick_size
and mortar values, and instead make use of "scale" to get the desired size.
Date: 8 May 2016 11:30:00
Message: <web.572f5ab1d3c58d897a3e03fe0@news.povray.org>
> > Problem.
Your recommendations don't work. Please, give me the working source code for
study.
Date: 8 May 2016 11:41:52
Message: <572f5e40$1@news.povray.org>
Am 08.05.2016 um 17:26 schrieb LanuHum:
>>> Problem.
> study.
My recommendations *do* work; I know because I tested them. You may have
difficulty understanding or implementing them, that's all.
    #declare BRICK_SCALE = 10;
    brick_size <0.2500,0.0525,0.1250> * BRICK_SCALE
    mortar 0.0100 * BRICK_SCALE
    scale 1/BRICK_SCALE
does the trick.
Date: 8 May 2016 13:30:01
Message: <web.572f777ad3c58d897a3e03fe0@news.povray.org>
>     scale 1/BRICK_SCALE
> does the trick.
5 or 10: how I could guess?
#declare BRICK_SCALE = 4;
#declare BRICK_SCALE = 40;
Very small it is necessary to multiply for 1000 or 10000. :)
Thank you!
Download 'scale.jpg' (111 KB)
Preview of image 'scale.jpg'
