POV-Ray : Newsgroups : povray.binaries.images : Road to radiosity perfection for patio_radio. Server Time
28 Jun 2024 22:07:13 EDT (-0400)
  Road to radiosity perfection for patio_radio. (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Road to radiosity perfection for patio_radio.
Date: 3 Feb 2016 08:00:11
Message: <web.56b1f9a0ff7ca2c7451ecd10@news.povray.org>
"Bruno Cabasson" <bru### [at] cabassoncom> wrote:
> Hello again.
> I revisited the patio_radio scene so as to try to reach perfection. For that
> purpose, I perform my attempts on high resolution images (1600*1200).
> For this attempt #1, it still remains :
>     -) some light areas in some corners
>        (to the left, on the floor, under the arches)
>     -) tiny splotchy zones by the arch half-rings,
>        at the top right of the image
> The fringe under the balcony seems correct.
> Render time : 1 hour and 10 mn on a quad xeon @ 3.7GHz.
> B.
Better with the image ...
Download 'patio-radio_37_bc_1.png' (959 KB)
Preview of image 'patio-radio_37_bc_1.png'
Date: 3 Feb 2016 09:07:15
Message: <56b20993$1@news.povray.org>
>> Hello again.
>> B.
One hour is pretty good for such a large image.
Mike
Date: 3 Feb 2016 10:29:43
Message: <56b21ce7@news.povray.org>
Nice design and decorations! Yes, some colors would be a nice addition,
like colorful fabrics as curtains, some early evening sky and some
colorful not too bright lights. Looking forward!
Date: 3 Feb 2016 11:10:00
Message: <web.56b225fdff7ca2c7451ecd10@news.povray.org>
The original scene is shipped-in with POV-Ray. The header of the file does not
mention
the author. Like most shipped-in scenes, it is intended to be for demonstration
purposes.
Date: 4 Feb 2016 01:18:59
Message: <56b2ed53$1@news.povray.org>
Well, it gives me some ideas for a nice oriental city scene. :-D
Date: 4 Feb 2016 03:01:47
Message: <56b3056b$1@news.povray.org>
>> Hello again.
Very good indeed. The artefacts you mention are hardly visible,
especially the second ones. The first ones are a bit more obvious.
Date: 4 Feb 2016 03:39:57
Message: <56b30e5d@news.povray.org>
> Hello again.
Don't forget you can always use the "no_cache" option (I think uberPOV
only?) to get a "reference" image. See attached, that took about 25 mins
on my machine using "count 10" and "recursion_limit 3". You'd obviously
need higher settings to get rid of the graininess, but at least then
you'd have something to compare the radiosity version with.
Download 'patio-radio_37.png' (3716 KB)
Preview of image 'patio-radio_37.png'
Date: 4 Feb 2016 03:45:02
Message: <web.56b30ed9ff7ca2c7451ecd10@news.povray.org>
> >> Hello again.
> Thomas
Here is another attempt. A bit better for the top right artifacts. Could not get
rid of the others. Anybody wants to give a try ?
Download 'patio-radio_37_bc_2.png' (991 KB)
Preview of image 'patio-radio_37_bc_2.png'
Date: 4 Feb 2016 04:00:00
Message: <web.56b312d8ff7ca2c7451ecd10@news.povray.org>
scott <sco### [at] scottcom> wrote:
> > Hello again.
Though I know about "no_cache" feature, I am not sure I know what it does
exactly. The point /IS/ to get rid of /ALL/ graininess and splotched, at high
resolution.
Date: 4 Feb 2016 05:57:50
Message: <56b32eae$1@news.povray.org>
> exactly.
It provides an "unbiased" result - meaning that (assuming you use enough
samples) there is nothing in the algorithm used that will give rise to
any error in each pixel value. Even with far too few samples (as in my
image) the error is purely random noise in each pixel, there are no
systematic errors possible like bright or dark splotches.
> resolution.
Use "no_cache" with a high number of samples and just let it run. With
traditional radiosity, even after a lot of parameter tweaking, there is
always the risk you have a bright/dark area somewhere that you don't
notice is there. That's why I suggested using "no_cache" to generate a
reference image to compare the traditional radiosity versions with.
Doing a "difference" in a graphics package should make it obvious if
there are any splotches of dark/light where there shouldn't be.
