POV-Ray : Newsgroups : povray.binaries.images : 3D images (for Mike Horvath) Server Time
20 Aug 2025 20:35:46 EDT (-0400)
  3D images (for Mike Horvath) (Message 1 to 10 of 22)
Subject: 3D images (for Mike Horvath)
Date: 7 Jan 2016 19:45:01
Message: <web.568f065bdb2619052b16ebf70@news.povray.org>
look at povray.general...
It's a StereoPhotoMaker screenshot to get *.jps files out of squeezed left/right
images.
I use normally two different camera locations and the same camera look_at
definition.
Norbert Kern
Download 'stereophotomaker.jpg' (792 KB)
Preview of image 'stereophotomaker.jpg'
Subject: Re: 3D images (for Mike Horvath)
Date: 8 Jan 2016 12:02:48
Message: <568febb8$1@news.povray.org>
> images.
> definition.
> Norbert Kern
I've never been able to do the "stick your nose on the screen and look
at each image with a different eye" 3D images. Maybe there is a homemade
solution using cardboard glasses?
Mike
Date: 8 Jan 2016 13:25:01
Message: <web.568ffecb282a0c73fcd2b62c0@news.povray.org>
> Mike
No, no - it's not such a simple solution. *.jps is one of the two most used 3D
image formates.
The software generates a jps out of two left/right images.
On most 3D TV-sets you can watch such images with glasses used in cinemas.
Much more interesting are 3D images you can pin on a wall (lenticular ->
"Wackelbilder" in german). For excellent effects you have to generate 20 to 40
images. Because of this I've generated only one source for a lenticular poster
(31 single images).
Norbert
Date: 12 Jan 2016 14:55:29
Message: <56955a31@news.povray.org>
>> Mike
> image formates.
> (31 single images).
> Norbert
Why did you "squeeze" the left/right images?
Mike
Date: 12 Jan 2016 16:42:23
Message: <5695733f@news.povray.org>
> images.
> definition.
That is the way I've done it. You could have posted the JPS file you
know. ;)
I spent a little while playing with stereograms when I got a 3d screne
about a year ago.
The image below seems to change eyes depending on the viewer I use. :(
> Norbert Kern
Regards
Download 'a_005b2_0sbs0.jps.jpg' (3225 KB)
Preview of image 'a_005b2_0sbs0.jps.jpg'
Date: 12 Jan 2016 17:03:59
Message: <5695784f@news.povray.org>
> images.
> definition.
That is the way I've done it. You could have posted the JPS file you know.
about a year ago.
Regards
Download 'a_005b_0000.jps.jpg' (1798 KB)
Preview of image 'a_005b_0000.jps.jpg'
Date: 12 Jan 2016 17:47:44
Message: <56958290$1@news.povray.org>
>> left/right
>> images.
>> definition.
> about a year ago.
This image is cross eyed and I can view it bare eyed.
If the viewer is expercting the roght image to on the left side, the
perspective is OK.
If the viewer expect the right image to be on the right side, then the
3D effect will be inverted.
Date: 12 Jan 2016 19:23:08
Message: <569598ec@news.povray.org>
>>> left/right
>>> images.
>>> look_at
>>> definition.
>> know.
>> about a year ago.
What do you know? So can I but I have to reduce it to about 20% in size.
> perspective is OK.
It is right image to the left but some of my software loads it right
image to be on the right side.
I've not used the s/ware for over a year so I am rusty.
Regards
Date: 13 Jan 2016 00:25:01
Message: <web.5695dea0282a0c73566b73360@news.povray.org>
I absolutely cannot do it if each image is more than 6 cm wide.  It's a mystery
to me how anyone can.  Is there a significant portion of the population with
double-jointed eyes?
If I narrow the browser window to 12 cm, I can merge the images with some
effort, but most of the detail is lost.  I get more satisfying results by
switching the left and right images and crossing my eyes instead.  That way, I
can view the images at a large size without eye pain.
Date: 13 Jan 2016 12:23:07
Message: <569687fb$1@news.povray.org>
This mean that your eyes are about 6cm appart, or you have some strabism
isue. For some other persons, it can be up to about 10cm appart.
You hit the limitation of parallel view: The image must be narower than
the spacing between your eyes.
Now, it must be notted that eyes spacing can vary quite a bit from
person to person, like around +-50%...
Why to you think the binoculars are articulated?
This mean that an image than can be viewed in parallel view easily by
the author may be impossible to view by many other persons.
