POV-Ray : Newsgroups : povray.binaries.images : Seraglio (WIP) Server Time
27 Aug 2025 03:20:34 EDT (-0400)
  Seraglio (WIP) (Message 41 to 50 of 60)
Subject: Re: Seraglio (WIP)
Date: 31 Aug 2015 03:15:01
Message: <web.55e3fee9f1eaec47f1963b20@news.povray.org>
=?UTF-8?B?SsOpcsO0bWUgTS4gQmVyZ2Vy?= <jeberger@free.fr> wrote:
> On 08/30/2015 07:38 PM, Alain wrote:
> > Ouch!
> > When you add a manual bounding to an union, that union is no longer
> > splitted. That cause it to take MUCH more time to render as each ray
> > that hit the manual bounding box now need to be tested against each and
> > every components of the union. It's similar in effect to uselessly usin
> g
> > merge instead of union.
> > Also, as your manual bounding box is larger than the original union,
> > it's even slower.
>     Have you tried it? ;) According to And, adding the manual bounding
> box decreases the render time from 2m04s to 2s...
>         Jerome
> mailto:jeb### [at] freefr
> http://jeberger.free.fr
> Jabber: jeb### [at] jabberfr
That's true. And it's impressive.
Thanks for sharing the information.
Cheng Han Tsai
Date: 31 Aug 2015 03:40:01
Message: <web.55e403daf1eaec472aaea5cb0@news.povray.org>
> > > Ouch!
> > g
> > > it's even slower.
> >         Jerome
> Cheng Han Tsai
There may be a problem with the bounding on my floor tiles.  Each set of tiles
is parsed as a single prism, but there are a couple of unions and differences
that I could split and bound manually.
A.D.B.
Date: 31 Aug 2015 16:11:08
Message: <55e4b4dc$1@news.povray.org>
f tiles
rences
    Note that AFAIK automatic bounding of unions is already optimal.
Manual bounding of differences can improve things, especially if you are
removing a large chunk of the original object, but finding the optimal
bounding box can be tricky. It's only for intersections that automatic
bounding is blatantly wrong and that manual bounding can very easily
improve things dramatically.
        Jerome
Download 'us-ascii' (1 KB)
Date: 31 Aug 2015 23:30:01
Message: <web.55e51b12f1eaec4769dae6480@news.povray.org>
> And here is a picture it works with radiosity feature on:
I forgot a matter. We should use a light_source that it assigns fade_distance 0
in POV-Ray 3.71 to get a realistic result.
Download 'finish test2 6.png' (156 KB)
Preview of image 'finish test2 6.png'
Date: 1 Sep 2015 01:45:00
Message: <web.55e53ab1f1eaec4769dae6480@news.povray.org>
> f tiles
> rences
>         Jerome
Okay ~.
Date: 2 Sep 2015 09:47:36
Message: <55e6fdf8@news.povray.org>
Am 31.08.2015 um 22:11 schrieb Jérôme M. Berger:
Strictly speaking, that depends on whether the bounding of its elements
is optimal.
Date: 2 Sep 2015 09:49:36
Message: <55e6fe70$1@news.povray.org>
Am 01.09.2015 um 05:27 schrieb And:
I would recommend using a non-zero fade_distance, set to be equal to the
corresponding object's radius. That more closely mimicks the
characteristics of a non-point light source.
Obviously you'll have to adjust the light source's brightness accordingly.
Date: 2 Sep 2015 14:59:38
Message: <55e7471a$1@news.povray.org>
Is this true even for area_illumination with circular orient?
Date: 2 Sep 2015 16:49:46
Message: <55e760ea$1@news.povray.org>
Am 02.09.2015 um 20:59 schrieb Cousin Ricky:
Hum - that's a good question I've never thought about. But by extension
of what I said, if you model a single non-point light source as an array
of smaller light sources, then those smaller light sources'
fade_distance should be set equal to their radius, so for a highly
subdivided area_illumination light source the fade_distance should
indeed probably be close to zero.
Date: 3 Sep 2015 05:35:06
Message: <web.55e81349f1eaec47f1376bd90@news.povray.org>
That's true. If you would like to simulation an area/surface light, every
element light source of it should obey the inverse square law. So it should set
the fade_distance 0 when the area light resolution is enough.
I've researched this and I would like to share it. In fact, I even know the
formula between the light source color and the emission surface color. If you
have any lambertian emission surface that emit light and you do not want to use
the radiosity, you can put the corresponding light sources to simulate it(just
like the area light). The formula between them is:
(emission_surface_color) = (light_source_color) * pi * resolution /
(surface_area)
Notice that it must set spotlight and correct radius, falloff, and tightness in
the lightsource.
You can implement it like this:
//---------------the code start---------------------
#declare disc_radius = 1;
#declare disc_color = rgb<1,1,1>;
#declare resolution = 100;
#declare emission_area = pi*disc_radius*disc_radius;
#declare looks_like_obj =
disc{
<0,0,0>, z, disc_radius,
    texture{
        pigment{color disc_color}
        finish{ambient 0 diffuse 0 emission 1}
    interior_texture{
        pigment{color rgb<0,0,0>}
        finish{ambient 0 diffuse 0 emission 0}
no_shadow
no_radiosity
#declare light_seed = seed(13);
#declare light_source_obj =
union{
    #for(i, 0, resolution-1)
        #declare this_r = sqrt(1/2+i)/sqrt(resolution);
        #declare this_theta = rand(light_seed)*2*pi;
        #declare this_point = <this_r*cos(this_theta), this_r*sin(this_theta),
0>* disc_radius;
        light_source{
        <0,0,0>
        color disc_color*emission_area/resolution/pi
        spotlight
        radius 90
        falloff 90
        tightness 1
        point_at z
        fade_power 2
        fade_distance 0
union{
    object{light_source_obj}
    object{looks_like_obj}
