![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"LanuHum" <Lan### [at] yandex ru> wrote:
> Whether it is possible to make the universal scheme of transition from a curve
> to the n-gons?
It is possible. But most of the curve can not be represented by a polynomial.
Using isosurface will make rendering time very long.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > to the n-gons?
isosurface is other question.
polynom doesn't use boundby.
It is feature which can be used in different situations.
It is interesting to me because such it is impossible to simulate in Blender.
I have a program creating the picture for HeightField which will allow to
reproduce similar, but it will be not that.
Time of a render in this case isn't important.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Sorry!
> Example for my early post
Oh, you made it with programming process. It can be more flexible in a sense,
then you can creat a mesh. My technique is using the equation.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > Sorry!
I also need the equation. On a screenshot I only showed transition from hard of
7 segments to a smoothed curve
Interests me 3-10 and more, but it is universal
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Really?
> > > Sorry!
I can't understand what your word mean.
Well, do you understand equation?
If you do, then my equation should be simple.
I have rendered another picture to show what my method can do. Just answer your
question whether it is possible to make the universal scheme of transition from
a curve to the n-gons.
But the outcome which I drew can not fit what the blending shape drawn by your
method.
Because I saw that your shape is consist of many straight lines, and my shape is
not.
Download 'loft test2 3.png' (207 KB)
Preview of image 'loft test2 3.png'
![loft test2 3.png](/povray.binaries.images/attachment/%3Cweb.554f803f908ae421bad22bea0%40news.povray.org%3E/loft%20test2%203.png?ttop=413793&toff=250&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here is a similar shape that blend a circle into two circles.
Download 'loft test2 4.png' (226 KB)
Preview of image 'loft test2 4.png'
![loft test2 4.png](/povray.binaries.images/attachment/%3Cweb.554f8239908ae421bad22bea0%40news.povray.org%3E/loft%20test2%204.png?ttop=413793&toff=250&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Really?
> > > > Sorry!
> method.
> not.
I badly understand you, and you don't understand me
Example:
box{1,-1}
sphere{0,1}
you object{???????????}
????? - universal parameters:
up<x,x,x,x,x,x,x> //6 sides or up<x,x,x,x> //4 sides
down<bezier_spline> or down<x,x,x,x,x,x,x,x,x,x,x,x,x,x........>//1024 sides
Or, something similar to it
The main thing that up - smooth, and down - flat, or on the contrary
That the side appeared smoothly from a bottom to top, or on the contrary
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Example:
> box{1,-1}
> sphere{0,1}
Well, ...ok, so those are some programming grammars in blender?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In the Blender it will be mesh(fictitious, approximately similar), and will be
exported to Povray as your object.
For this purpose there will be special entry fields of necessary data.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And wrote on 10/05/2015 18.07:
There is a lot of potential: this object seems a half body of a cartoon
character.
Paolo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
