In 2009 some guys (Daniel White, Paul Nylander and others) developed a kind of
3-space version of the mandelbrot set by trying to simulate the operations
within the (two dimensional) complex numbers with polar coordinates. As I
understood their approach so far.
At the end of this year (2009) David Wagner (waggy) proposed an implemtation
with POV with isosurfaces using (illegal, but still working) recursive function
calls at the newsgroups. Tor Olav Kristensen was so kind, to give an iterative
alternative to the recursive algorithm. Both sources can be found at:
http://news.povray.org/povray.binaries.scene-files/thread/%3C4b2c7b3f%40news.povray.org%3E/
Now I found this old treasures and played a little bit around with them. The
main parameters I changed was the iteration depth and the treshhold of the
isosurface used, which proved the more interesting issue. Here is a first close
up. I hope you enjoy it like me. I used Tor Olav's (POV-legal) version for this
images.
The texture is a very simple slope-pattern so far. The direction of the slope
pattern is choosen as the direction from camera position to camera look at
which happens to be z in this case. red violet marks areas with normals opposing
z (slope=0), cyan marks areas perpendicular to z (slope=0.5), dark cyan is in
the middle of both (slope=0.25). In this situation slope values
above 0.5 are not visible.
Best regards,
Michael
Download 'tok_mjf_03_01.png' (2055 KB)
Preview of image 'tok_mjf_03_01.png'
Fascinating indeed. I wonder: has the mandelbulb code as used by Sam
Benge in particular ever been posted here? And how about those by Scott,
James Holsenback, or PM2Ring? Possibly those were not pure POV-Ray codes
but only rendered here. I don't remember.
> Thomas
Thank you Thomas. I'm just playing around. Works about mandelbulbs by James
Holsenback or Samuel Benge are unknown to me and Google (the search engine
within the newsgroups) yields nothing about mandelbulbs and their names. The
only other POV-code I've noticed so far is using df3-files as function pattern
within an isosurface (PM2Ring and others). But their df3 is generated outside of
POV. In fact I'm searching for a special view but I fear I can only tell after
I've found it.
Here is a fifth order mandelbulb using the positive z-component method as Paul
Nylander (a.k.a. bugman) put it. Lighting and background adopted from Tor Olav
Kristensen. I added only a little bit of radiosity. The texture is very simple
in this case (color Cyan).
Best regards,
Michael
Download 'mb_pow5.png' (842 KB)
Preview of image 'mb_pow5.png'
>> Thomas
> I've found it.
I have a collection of images made over the years by the POV community.
Unfortunately, I did not save the dates, only the maker's names, so I
cannot tell you /when/ mandelbulb explorations took place here. Maybe
Yadgar knows. He is a more complete collector than I am :-) However, my
feeling is that the mandelbulbs were not generated by POV-Ray.
Ah yes, the familiar shape. I like it.
Hi(gh)!
The earliest Mandelbulb posting in my collection dates from November 19,
2009 - a scene rendered by Scott...
See you in Khyberspace!
Yadgar
On 08/04/2015 15:28, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
I remember some discussion around about the time I was playing with the
code for a cubic Mandelbrot that Andrew posted. That was in 2005 and
2007/8. Going by the file dates.
As an aside. I thought that off topic posts expired after a short while.
But I can find posts as early as 2006 on the web interface.
Regards
> > Hi(gh)!
> Regards
> Stephen
Thanks to you all. So far as I learned the mandelbulb was invented around 2009.
But I think it was the end of a longer ongoing investigation labeled with this
name first in 2009. ATM I'm fascinated by this strange structures yielded from
such a very simple formula. In a way it takes me back over twenty years into the
past when I rendered the mandelbrot set with my amiga long gone.
Best regards,
Michael
And I was thinking of the Buddhabrot.
http://en.wikipedia.org/wiki/Buddhabrot
Regards
