hallo everybody
I am absolutely newbie with povray, this is what I have realized in the last
4billions years of life.
I have post in scene-file the code
Download 'planet-norm-atmo.png' (1213 KB)
Preview of image 'planet-norm-atmo.png'
eticre wrote on 02/12/2014 23.39:
> hallo everybody
Well... a very long render, but a nice place to live, indeed ;-)
Paolo
> hallo everybody
Really newbie with povray? Good job! I notice some //*PMRawBegin
//*PMRawEnd comments in your code, and your textures are awesome (even
for a non-newbie), are they made by hand or with a software?
Lionel
<b>Do not judge my words, judge my actions.</b>
http://www.avast.com
On 2-12-2014 23:39, eticre wrote:
> hallo everybody
Excellent work! I can hardly name you a newbie, even less an /absolute/
newbie. Your textures are very well made.
Interestingly, I have been working for some time now (less than 4
billion years) on exactly the same thing but with some differences. My
latitudinal approach is similar to yours; however, I am using
height_fields for the topography and the texture is thus also altitude
dependent. I attach an example of the state of the art.
For the background I have used Chris Colefax's galaxy macros, which are
in need of some upgrade ;-)
http://reocities.com/SiliconValley/lakes/1434/galaxy.html
For the height_fields I use a little application called PlanetGenesis
http://planetgenesis.sourceforge.net/ and the clouds come from the Nasa
http://visibleearth.nasa.gov/view_cat.php?categoryID=1484&p=3
Download 'planetgenesis.png' (320 KB)
Preview of image 'planetgenesis.png'
> > hallo everybody
> Paolo
Hi Paolo
Italia?
I live near Varese.
FractRacer <lg.### [at] gmail com> wrote:
> > hallo everybody
> Lionel
active.
> http://www.avast
During my billions years of lonely wanderings
I came across this SOS signal
https://forum.kde.org/viewtopic.php?f=19&t=90952&hilit=kpovmodeler
I have spent many hours for reactivate this great piece of software abandoned by
kde devels, the result is not perfect but work nicely and allows everyone to use
povray.
> > hallo everybody
> Thomas
Thanks!
now I relax for 2000 or 3000 years, clouds and stars are my greatest difficulty.
I'm also looking for an approach via isosurface instead of normal using ridged
multifractal for terrain elevation, this is my best result
//*PMRawBegin
#version 3.7;
#include "functions.inc"
//*PMRawEnd
global_settings {
adc_bailout 0.0039216
assumed_gamma 1
max_trace_level 5
noise_generator 2
light_source {<0.135746, 7.68125, -8.30554>, rgb<1, 1, 1>}
perspective
location <-0.068982, 3.5117, -14.336>
sky <0, 1, 0>
direction <0, 0, 1>
right <1.7777, 0, 0>
up <0, 1, 0>
look_at <-0.10105, 1.7848, 0.094281>
#declare Dec_bump = pigment{bumps}
#declare F_bump = function{pigment {Dec_bump}}
#declare Dec_terrain_l = isosurface {
function { y - F_bump(x,y,z).gray/2 - (F_bump(x,y,z).gray * (f_ridged_mf(x,0,z,
0.2 , 5 , 7 , 1.6 , 0.1 , 2)*0.55) * 0.5) }
contained_by { box { <-15, 0, -15>, <15, 3, 15> } }
threshold 0.1
accuracy 0.0001
max_gradient 10
all_intersections
pigment {color rgb<0.745098, 0.745098, 0.745098>}
hollow false
object {Dec_terrain_l}
Download 'ridge-mf.png' (219 KB)
Preview of image 'ridge-mf.png'
On 3-12-2014 23:40, eticre wrote:
> Thanks!
Isosurfaces is an excellent alternative to height_fields indeed although
slower to render. I have not yet tried it for planets as I first wanted
the textures to be right, but ridged multifractals at the core would be
essential. I did a lot of experimentations with isosurface landscapes in
the past and would need to reactivate my memory (and my documentation) a
bit :-)
Hi(gh)!
>> Thanks!
>> difficulty.
>> using ridged
> bit :-)
Back in 2010 (as some around here might remember) I rendered a whole
planet ("Ghurghusht"), technically a somewhat Earth-like moon of a gas
giant ("Qais") based on a combination of various isosurface patterns, at
a resolution high enough to get semi-realistic landscapes even from the
viewpoint of a pedestrian standing on the surface, and using Bruno
Cabasson's atmosphere tool. Some views attached here:
1. an entire hemisphere of Ghurghusht
2. a "pedestrian view" of Rathjens Lacus on Ghurghusht
3. a "pedestrian view" of Centlivres Lacus on Ghurghusht
4. a "pedestrian view" of Schmidt Lacus with Sitara Insula (planned
location of Kandabul City)
5. an overflight view of a region at Ghurghusht's equator from about 35
kms height
6. a global physical map of Ghurghusht
7. a physical map of Schmidt Lacus region
and, finally, a link to an animation showing an entire day at Schmidt
Lacus: https://www.youtube.com/watch?v=qyN0zwTW0xU
See you in Khyberspace!
Yadgar
Download '2010-05-05 ghurghusht, global view centered on substellar point, take 5 (thickness 100, density 0.15, rayleigh factor 0.' (110 KB)
Download '2010-05-05 ghurghusht, rathjens lacus from 1.7 metres, looking east, take 6 (thickness 150, density 0.15, rayleigh facto' (46 KB)
Download '2010-05-05 ghurghusht, centlivres lacus from 1.7 metres, looking north, take 5.jpg' (55 KB)
Download '2010-05-15 ghurghusht, achakzai peninsula and sitara insula from 1.7 m, take 1.jpg' (37 KB)
Download '2010-05-23 ghurghusht, start point for ghurghust equatorial flight from 35,000 metres, looking east, take 1.jpg' (59 KB)
Download '2010-04-01 cylindrical map of ghurghusht, 5 pixels per degree, labelled.png' (1029 KB)
Download '2010-05-15 ghurghusht, context map of schmidt lacus, 450 pixels per degree, take 2, labelled.png' (178 KB)
Preview of image '2010-05-05 ghurghusht, global view centered on substellar point, take 5 (thickness 100, density 0.15, rayleigh factor 0.'
Preview of image '2010-05-05 ghurghusht, rathjens lacus from 1.7 metres, looking east, take 6 (thickness 150, density 0.15, rayleigh facto'
Preview of image '2010-05-05 ghurghusht, centlivres lacus from 1.7 metres, looking north, take 5.jpg'
Preview of image '2010-05-15 ghurghusht, achakzai peninsula and sitara insula from 1.7 m, take 1.jpg'
Preview of image '2010-05-23 ghurghusht, start point for ghurghust equatorial flight from 35,000 metres, looking east, take 1.jpg'
Preview of image '2010-04-01 cylindrical map of ghurghusht, 5 pixels per degree, labelled.png'
Preview of image '2010-05-15 ghurghusht, context map of schmidt lacus, 450 pixels per degree, take 2, labelled.png'
Yes indeed!
