POV-Ray : Newsgroups : povray.binaries.images : Secret Passage WIP (TINA CHeP) Server Time
13 Mar 2026 19:51:54 EDT (-0400)
  Secret Passage WIP (TINA CHeP) (Message 91 to 100 of 106)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Secret Passage WIP (TINA CHeP)
Date: 5 Nov 2014 05:40:02
Message: <web.5459fd60cbb3d81597b9a8510@news.povray.org>
> I'm gonna guess that this is a max trace level issue...
Had a quick look at your light bulb source file and I think there are 2 possible
fixes for this issue if you want to keep the bulb shape.
1) remove the screw part of the lightbulb as it seems to be casting the shadow.
2) use an area_light for your bulb as below:
 light_source {
     <0, 0, 0> rgb <1, 1, 1>*0.4
        area_light
        <4, 0, 0> <0, 0, 4>
        4, 4
        adaptive 0
        jitter
        circular
        orient
  looks_like {
   union { object {Filament}
    sphere {<0, 3.5, 0>, 1.7 pigment {rgbf <1*Flare, 1*Flare, 0.5*Flare, 1>}
finish {specular 1} }
    translate <0, 0, 0>
Both seem to work with the simple demo file I created.
Sean
Date: 5 Nov 2014 06:26:17
Message: <545a0959@news.povray.org>
On 04/11/2014 23:37, Bald Eagle wrote:
> Stephen <mca### [at] aolcom> wrote:
>> What does it look like without the isosurfaces?
> There's not a single isosurface in the scene.  I figured it might have something
> to do with going through the bulb glass, then the lampshade glass, but I get the
> same effect when I just use a looks_like {sphere}....
It is your mention of Max_Trace that made me think of isosurfaces.
If you were thinking of Max_intersections. Do you know that PovRay
reports the current settings and maximum number of intersections in the
message window?
For instance:
Render Statistics
Image Resolution 1024 x 768
Pixels:           787456   Samples:         3341776   Smpls/Pxl: 4.24
Rays:            5439099   Saved:            359357   Max Level: 9/20
Ray->Shape Intersection          Tests       Succeeded  Percentage
Max Level: 9/20 means that max_intersections is set to 90 and 9 is the
largest number Pov found when rendering.
> I'm puzzled by this, though I am often thwarted by seemingly simple and
> otherwise-straightforward tasks....
Yes, well so was I. Until I did an experiment with an old scene of mine
that has some similarities to yours.
Your not per chance moving your lampshades to where the light source is,
are you?
When I did that I got the shadow effect. But when I left it at the
origin I get the desired result as attached. It is a quickly modified
old scene and not finished. The shade is declared but not called and the
light source is:
#declare Hall_Light =
light_source {
< 0.00, 0.00, 0.00 >, color rgb <1.000,1.000,0.769>*2.000
fade_power 2.000
fade_distance 100.0
media_attenuation off
media_interaction on
looks_like {Shade0}
translate <-34.36,100.00,-50.30>
Regards
Download 'looks_hall_l_01b_0000.jpg' (253 KB)
Preview of image 'looks_hall_l_01b_0000.jpg'
Date: 5 Nov 2014 06:28:36
Message: <545a09e4$1@news.povray.org>
Set to 20, I meant.
Regards
Date: 5 Nov 2014 10:25:01
Message: <web.545a40f7cbb3d8155e7df57c0@news.povray.org>
Thanks!
I made a new include file to construct a bare white room, the 2 ceiling
fixtures, and the lightbulbs.
It's not, as I had the screwbase commented out.
(I'm sure it DOES cast _A_ shadow - but not the one that's slaughtering my
scene.)
Delving into the simplified scene, I noticed that I probably thought that
declaring the light source at the origin and using a 3D filament that was
translated y*3.5 would give me some sort of light source that emanates from the
actual surface of the filament.
This is clearly not the case, and not the way looks_like works.
Declaring the light_source at <0, 3.5, 0>, as the point light sources originally
were, fixed the problem of blotting out the entire lower part of the scene, and
makes sense given the light sources' proximity to the supporting half-spheres of
the fixture.
I think that since the lights were positioned _just_ above the fixture, what
spreading them out to an area light did was move the edges of the light source
over the edge and allowed them to illuminate underneath.
I've just gotten the fixtures and a sphere to look reasonably like what I want,
so I'm going to play around with that for a while.
Download 'ceilinglamps.inc.txt' (12 KB)
Date: 5 Nov 2014 12:13:01
Message: <545a5a9d@news.povray.org>
>> something
>> I get the
> message window?
> For instance:
> Render Statistics
The Max Level entry is for max_trace_level and always apply. The
presance of any isosurface don't mather.
This mean that, in this case, a single ray can have up to 20 reflections
or refractions before POV-Ray gives up.
There are no messages regarding max_intersections.
max_intersections/all_intersections applys only to isosurfaces that are
part of difference/intersection.
Date: 5 Nov 2014 14:54:39
Message: <545a807f$1@news.povray.org>
My local copy of the help file (Ver 3.62) only gives one entry under
max_trace and that is for isosurface.
Using a modeller as I do adds another level of confusion. Thanks for
correcting me. :-)
Regards
Date: 5 Nov 2014 15:20:00
Message: <web.545a8616cbb3d8155e7df57c0@news.povray.org>
This helps me a lot.
It's far easier for me to understand a lot of what POV-Ray does in visual terms.
http://www.f-lohmueller.de/pov_tut/interior/interior_03e.htm
Date: 5 Nov 2014 15:32:42
Message: <545a896a$1@news.povray.org>
Indeed it does, for me too. Friedrich Lohmüller's site is a treasure trove.
Regards
Date: 5 Nov 2014 19:05:01
Message: <web.545aba9ecbb3d815a47478650@news.povray.org>
> scene.)
OK, on my simple white room with a single bulb commenting out the screw part
fixed the issue but I can see it may not be a fix for your scene.
I also did a simple test where I moved the light source up a couple of units and
that fixed the issue in my simple scene.
> the fixture.
Yes, the area_light idea was more of a workaround than a real solution.
Another thought would be to add no_shadow to any parts of the scene that are
casting this but I suspect that may end up looking unrealistic. I created a
lantern a while back which had a light source inside the lamp and that worked OK
so I am sure it is fixable. maybe if you can post the code to create the entire
light fitting I can have another go (once my PC has finished rendering my
current version of my tc-rtc entry).
Sean
Date: 6 Nov 2014 00:15:00
Message: <web.545b032acbb3d8155e7df57c0@news.povray.org>
I just ran that through my head a few times, and maybe unioning a no_shadow
object and one with an rgbf value would allow "dialing-in" the amount of shadow
it throws.  I don't mind the shadows, but perhaps softening them might have some
benefit.
> I created a
> Sean
Thanks Sean,
I'm getting the hang of working with this, though you're welcome to have the
fixtures to play around with.  No telling what you may come up with.  At some
point I'll get back to working on a mammoth WIP (approx. 400' x 400' facility) I
started a while back, and I'm probably going to need to learn about modeling
light fixtures and probably these "light groups" that I've yet to try....
Maybe radiosity without traditional light_sources is the way to go with that...
I'm looking forward to see where you're taking your interpretation of the topic
- I just today saw all the entries for Part 1.  It's inspiring, humbling, and
intimidating all at the same time.  :)   Hope you're making good progress and
getting the results you want.
I think the multiple layers of shadows in this are really cool - maybe I'll do
something that's composed almost entirely of shadows in the future...
Download 'ceilinglamps.inc.txt' (16 KB)
