Download 'pfcg.jpg' (17 KB)
Preview of image 'pfcg.jpg'
> On Fri, 25 Apr 2014 20:07:55 +0200, LanuHum <Lan### [at] yandex ru> wrote:
>> Me all interests about Povray
>> http://atrey.karlin.mff.cuni.cz/~0rfelyus/
>> RBezier
>> This patch is the last in my series of patches for POV-Ray. It extends
>> POV-Ray
>> by ray tracing of trimmed rational Bezier surface patches using Bezier
>> clipping
>> (as described by Nishita, Sederberg and Kakimoto).
>> ftp://atrey.karlin.mff.cuni.cz/pub/local/0rfelyus/povray-3.02/examples/trims-b.png
>> I didn't find in Povray-3.7 opportunity to create bezier patch
>> Good idea for creation of leaves
> If I understand correctly this could have helped me when I made my bass
> for cutting the c-holes from the sound-box.
An electric bass guitar with a violin/celo body? That's new...
>>> RBezier
ds
>>> POV-Ray
er
>>> clipping
es/trims-b.png
ss
My design electro-acoustic bass based on a contra-bass.
I hand-coded the sound-box as a bezier patch. I CSG'd the C-holes out of
the soundbox but I couldn't add depth because I couldn't csg the sides o
f
the C-holes. I was thinking maybe this patch would make it possible.
-Nekar Xenos-
> of the C-holes. I was thinking maybe this patch would make it possible.
Could you not subtract the a scaled down version to create the resonance
chamber?
I am assuming that the thickness of the upper and lower surfaces need
not be detailed modelled to get a realistic sound body.
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
This email is free from viruses and malware because avast! Antivirus protection is
active.
http://www.avast.com
> chamber?
It just ends up looking like a shadow. I need to do the walls/edges of the
c-holes and they need to match.
-Nekar Xenos-
>> resonance chamber?
> the c-holes and they need to match.
Right now, the C-holes look like they are painted on...
How about replacing the patch with an hight_field?
Do a render of only the front face using an orthographic camera and a
black to white gradient. Use +fng16 on the command line when using
version 3.7.
Add some slight bluring to get some beveling/rounding. May be done using
some focal blur or by post processing.
Use water_level to remove the outside part.
As it may be to thick around the openings, you can now use a difference
around the C-holes to get just the correct thickness.
For the back face, you can still use the bezier patch, or you can use
another hight_field made without the openings.
> >>> RBezier
> ds
> >>> POV-Ray
> er
> >>> clipping
> es/trims-b.png
> ss
> f
> -Nekar Xenos-
What about putting a thin box inside the soundbox behind where the C-holes are
then simply cutting a hole in this box as well?
Seab
>> resonance chamber?
BTW why the C-holes? I could not find an example of a real instrument
that has them.
Mechanically they make also less sense as far as I understand the
physics behind the violin family.
And who is G Oosthuizen?
active.
>> resonance chamber?
I did not realize you used set of disjoint bezier patches. Now I see all
the mismatches where patches meet.
It is been a long time I used bezier in POV, I can not even remember if
you can make solids with them at all.
active.
>>>> out of
>>> resonance chamber?
You can't make a "solid" object with them as they have no defined
interior/exterior distinction, just the same way as the triangle and
polygon primitives. Those primitives are just surfaces with no thickness.
You CAN combine several of them to create a solid looking, ie closed,
object. That object can contain some media and can be used in an union,
but can't be used in a difference or intersection. The result with a
merge will still contain surfaces from other objects that are "inside"
the bezier patch object that you may expect not to be visible.
Untill version 3.7 and the introduction of the inside_vector, you had
the same limitation with mesh/mesh2 objects.
