POV-Ray : Newsgroups : povray.binaries.images : A method creat uniform thick shell Server Time
8 Apr 2026 06:50:00 EDT (-0400)
  A method creat uniform thick shell (Message 26 to 35 of 45)
Subject: Re: A method creat uniform thick shell
Date: 25 Jul 2018 05:30:01
Message: <web.5b584307dce0719a5341e80e0@news.povray.org>
Paolo Gibellini <p.g### [at] gmailcom> wrote:
> And wrote on 24/07/2018 14:36:
> > "And" <49341109@ntnu.edu.tw> wrote:
> >> I have written a macro which uses above technique to make an isosurface thin
> >> shell. I post it below. But I found that it is only for a small thickness or it
> >> don't have a constant thickness result. Furthermore, for many functions its
> >> result is not expect.
> >> So, don't take too much expect with it.
> Nice effect.
> Now, I'm curious to see the jar filled of water.
> Paolo
The rendering is very slow. I 'd rather sculpt one using mesh than using this
method.
Date: 25 Jul 2018 07:02:23
Message: <5b5858bf$1@news.povray.org>
I like it very much. As always, I shall note down the macro for future
reference/use.
Date: 25 Jul 2018 08:20:00
Message: <web.5b586a43dce0719a5341e80e0@news.povray.org>
> reference/use.
> Thomas
Oh, it's nice
Date: 28 Jul 2018 09:48:22
Message: <5b5c7426$1@news.povray.org>
I am trying to do the same, but am having trouble toning down the
reflections. I can barely see through the glass, and the finish is
reflecting too much and too brightly.
Mike
Download 'offset_surface_save_01.png' (229 KB) Download 'utf-8' (4 KB)
Preview of image 'offset_surface_save_01.png'
Date: 28 Jul 2018 09:53:08
Message: <5b5c7544@news.povray.org>
> Mike
just a guess .. diffuse and / or reflection too high
Date: 28 Jul 2018 10:23:27
Message: <5b5c7c5f$1@news.povray.org>
>> Mike
Diffuse is 0. I can't judge properly how high reflection is.
#declare F_Glass5 =
   finish {
     specular 0.7
     roughness 0.001
     ambient 0
     diffuse 0
     reflection {
       0.2, 1.0
       fresnel on
     conserve_energy
Date: 28 Jul 2018 11:42:26
Message: <5b5c8ee2$1@news.povray.org>
>>> Mike
> #declare F_Glass5 =
>    finish {
>      specular 0.7
>      roughness 0.001
>      ambient 0
>      diffuse 0
>      reflection {
>        0.2, 1.0
>        fresnel on
>      conserve_energy
If you reduce the ior, then, the reflection will also go down.
The minimum reflection is to high at 0.2.
Try :
reflection{0, 1 fresnel}
or simply
reflection{1 fresnel}
Try this interior :
interior{
  ior 1.5
  dispersion 1.05
  fade_colour Col_Ruby fade_distance 0.1 fade_power 1001
Col_Ruby is the same as Col_Glass_ruby but without the filter component.
With this pigment :
pigment{rgbt 1}
Date: 28 Jul 2018 15:20:00
Message: <web.5b5cc18bdce0719a9cbeb2fe0@news.povray.org>
> #local h=0.00001;
> #local normalized_function =
> function(var1,var2,var3)
> input_function(var1,var2,var3)
> /sqrt(
> pow((input_function(var1+h,var2,var3)-input_function(var1,var2,var3))/h,2)
> +pow((input_function(var1,var2+h,var3)-input_function(var1,var2,var3))/h,2)
> +pow((input_function(var1,var2,var3+h)-input_function(var1,var2,var3))/h,2)
And, there is a macro in math.inc that can create the gradient function for your
denominator: fn_Gradient()
Here's how you can use it:
#include "math.inc"
SetGradientAccuracy(h)
#local GradientFn = fn_Gradient(input_function)
  function { input_function(x, y, z)/GradientFn(x, y, z) }
I suspect that this will be a little faster, since fn_Gradient() uses f_r()
instead of sqrt() and pow() and since the division by h (or 2*h in fn_Gradient)
is moved outside.
Here's the relevant documentation pages:
http://www.povray.org/documentation/view/3.6.1/460/
http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_9_1_12_3
Tor Olav
http://subcube.com
Date: 29 Jul 2018 09:36:03
Message: <5b5dc2c3$1@news.povray.org>
> Try :
> or simply
> Try this interior :
> interior{
>   ior 1.5
>   dispersion 1.05
> With this pigment :
> pigment{rgbt 1}
The dispersion really causes the render times to increase. I don't know
if I have the patience.
Mike
Date: 29 Jul 2018 09:59:00
Message: <5b5dc824$1@news.povray.org>
>> #local h=0.00001;
>> /sqrt(
> #include "math.inc"
> is moved outside.
> Tor Olav
> http://subcube.com
I don't understand the syntax.
I did not know one could pass one function to another in this manner. I
thought it was necessary to pass x, y, z instead. I.e.
#local GradientFn = fn_Gradient(x,y,z)
Mike
