POV-Ray : Newsgroups : povray.binaries.images : Eye experiment Server Time
30 Sep 2024 08:20:43 EDT (-0400)
  Eye experiment (Message 1 to 9 of 9)
Subject: Eye experiment
Date: 3 Nov 2009 23:45:02
Message: <web.4af105eeef48323c4726e92b0@news.povray.org>
Hi all, I modeled this basic eye shape in Silo today. I wanted to try for a
realistic look, building it at least *close* to accurate by using a separate
cornea w/pupil (just a flattened torus) actually set inside the bulge where the
lens would be.
I used an image_pattern to transition the transparent lens area around the
cornea into a solid eye texture on the eyeball itself. After a quick
fully-textured render I thought I'd have a go at doing a full close-up face shot
(since I'm trying to get better at UV mapping/texturing).
I remember admiring the close-up eye renders in a 3dRender.com lighting
challenge a few years ago so I went and found it online and grabbed the OBJ file
(http://www.3drender.com/challenges/). I brought it into Silo and deleted the
existing eye, inserted my eye, OBJ to PoseRay to Mesh2, and ended up with this
after about 6 hours of fiddling about with texturing and lighting and rendering
and gamma pre-correction of my UV maps and re-rendering (and thanks for the
gamma mini-tutorial yesterday Clipka and Alain, big help!).
No SSLT here, just a couple of layered textures using image_patterns to control
specular and reflection on the various areas.
Cheers,
Rob
Download 'eyeexperiment.png' (1625 KB)
Preview of image 'eyeexperiment.png'
Subject: Re: Eye experiment
Date: 3 Nov 2009 23:54:13
Message: <4af108f5$1@news.povray.org>
> lens would be.
> Cheers,
> Rob
Are you sure you did not post a photo by error? ;)
Only thing , it looks to me that the blod vessels are somewhat to
present, or to numerous.
Date: 4 Nov 2009 06:17:02
Message: <4af162ad@news.povray.org>
A M A Z I N G
I knew Pov was good, but that's a professional looking image that I'd
usually expect to see coming from Maya / PR Renderman or something... -well
done-!
Stefan Viljoen
Date: 4 Nov 2009 08:05:01
Message: <web.4af17b6bc237b99e4726e92b0@news.povray.org>
Heh, yes I agree - looks like she's been up all night and is now seeing the
sunrise.
Actually, the blood vessels gave me some trouble. In the end I used the roots of
a weed pulled from my garden and photographed against a concrete floor. I
tweaked them a lot in PhotoShop and ended up with a spherical projection.
Here's the code for the eye texture (and accompanying maps: top is the iris
mask, next is color, next is bump, iris [of course] on the bottom).
#include "eye.inc"
#declare Eye = object {Eye translate <0,-1,-0.076621>}
#declare T_Eye = texture {
   #if (Ambient_Occlusion)
      T_Ambient_Occlusion
   #else
      image_pattern { png "cornea_mask.png" interpolate 2 map_type 1 }
      texture_map {
         [0 pigment {Clear}
            normal {
               bump_map {png "eyeball_map_bump.png" interpolate 2 map_type 1 }
               bump_size 0.25
            finish { reflection {0.1, 0.35 fresnel} conserve_energy
               specular 1 roughness 0.001 brilliance 1
         [1
               image_map { png "eyeball_map.png" interpolate 2 map_type 1 }
            normal {
               bump_map { png "eyeball_map_bump.png" interpolate 2 map_type 1 }
               bump_size 0.25
      rotate x*90
      rotate -z*90
#declare T_Iris = texture {
   torus { 1, 0.5
      rotate x*90
      scale z*0.2
            T_Ambient_Occlusion
         #else
               image_map { png "Iris.png" interpolate 2 map_type 0 once }
               translate -0.5
            normal {
               bump_map { png "Iris.png" interpolate 2 map_type 0 once }
               translate -0.5 bump_size 1
            finish { specular 0.2 roughness 0.02 }
            scale 3.1
object { Eye
   scale 0.7
   texture { T_Eye }
   interior { ior 1.33 }
Download 'eyemaps.png' (906 KB)
Preview of image 'eyemaps.png'
Date: 4 Nov 2009 08:20:01
Message: <web.4af17ea0c237b99e4726e92b0@news.povray.org>
Stefan Viljoen <spa### [at] polardcom> wrote:
> A M A Z I N G
> done-!
Thanks Stefan, I'm trying :)
I find that most CG people underestimate the power of POV. When I exhibit my
prints at art festivals, galleries, etc, someone "in-the-know" will invariably
come and ask me something like, "So which did you use for these - Maya or 3d
Studio Max?"
"Neither, they're all done with POV-Ray" I'll reply.
A blank stare of disbelief often follows, as if they're waiting for the punch
line.
Date: 4 Nov 2009 10:41:58
Message: <4af1a0c6$1@news.povray.org>
"Robert McGregor" <rob### [at] mcgregorfineartcom> schreef in bericht
news:web.4af17ea0c237b99e4726e92b0@news.povray.org...
>> A M A Z I N G
>> something... -well
>> done-!
> my
> invariably
> 3d
> Studio Max?"
> punch
> line.
LOL! Excellent! Both your work and your real world tale.
Date: 4 Nov 2009 12:56:47
Message: <4af1c05f@news.povray.org>
very good, except the skin around the eyelids look like plastic.  Also,
too much veins for my liking.  Quit smoking, dude... :)
a game sig: http://tinyurl.com/d3rxz9
Date: 4 Nov 2009 14:10:00
Message: <web.4af1d178c237b99e5b81d0ec0@news.povray.org>
Looks fantastic!
The only change I'd make to the eyeball is to the sclera - it's not smooth like
the surface of the cornea, but a bit bumpy instead. It shows up in the
reflection of the environment.
Cheers,
Edouard.
Date: 4 Nov 2009 21:45:00
Message: <web.4af23bccc237b99e4726e92b0@news.povray.org>
LOL, well she's apparently been up all night drinking and maybe smoking too, and
who knows what else. It's no wonder she's looking a overly bleary-eyed and
plasticine (especially without any SSS).
Seriously, point taken, I'll see what I can do to fix it :)
