POV-Ray : Newsgroups : povray.binaries.images : Eat my dust Godel, Escher, Bach Server Time
2 Jun 2024 03:27:21 EDT (-0400)
  Eat my dust Godel, Escher, Bach (Message 15 to 24 of 24)
Subject: Re: Eat my dust Godel, Escher, Bach
Date: 16 Nov 2008 21:05:01
Message: <web.4920d113625722e11695baba0@news.povray.org>
"Woody" <nomail@nomail> wrote:
> Warp <war### [at] tagpovrayorg> wrote:
> > Woody wrote:
> > > Comments? Suggestions? Constructive Criticisms? Apprehensions? Coagualtions?
> >   Why aren't the objects illuminated by the same lights that are
> > illuminating the surrounding walls?
> Answer to save face:
> That was part of the illusion intended.
> Answer demonstraing ignorance:
> I couldn't find a way to illuminate all sides of each cube (see attached).
> I suppose in retrospect i could of put a light source within the larger blocks.
> But I suspect it wouldn't give very distinguishable results.
> -Jeff
Sorry Warp, wrong image.
Download 'namesake.png' (360 KB)
Preview of image 'namesake.png'
Date: 17 Nov 2008 14:38:37
Message: <4921c83d@news.povray.org>
IMO that looks much better than the original.
Date: 17 Nov 2008 18:45:00
Message: <web.49220159625722e149b4acd50@news.povray.org>
> > I put the scene file in the binaries at
> > <web.4920b79c1a0225801695baba0@news.povray.org>
> So the only requirements for the technique to work in every case are that the
> font be monospace and that each letter touch all four edges at some point?
> Do you mind if I work on the scene and upload it in macro form to the Object
> Collection?
> -Mike
Go right ahead.
I don't know if what you say is the defining rule. I consider it more of an art
than a science.
You might try doing a CSG on each individual blocks rather than a CSG on all
blocks at once. The advantage being that a CSG on all five blocks would put
more constraints on the shapes.
That is I could've probably obtained a shadow of a "G" without using a CSG
intersection on the letter "G" itself, but rather had the shadow be a
combination of 5 different shadows. Will try to upload an example when able.
-Jeff
Date: 20 Nov 2008 08:32:13
Message: <op.ukw6jwk56b35ac@your-727a0a4e7c.vipowernet.net>
The key was keeping the outer radius of curvature of the corner curves to
no more than the width of a straight line.  This meant asymmetrical curves
for the R and W, but I think they're better-looking for it.  (Or is that
"less clumsy-looking"?)
<Insert witty .sig here>
Download 'r_call_wood-b.jpg' (46 KB) Download 'r_call_wood-asym.png' (6 KB)
Preview of image 'r_call_wood-b.jpg'
Preview of image 'r_call_wood-asym.png'
Date: 3 Dec 2008 14:10:00
Message: <web.4936d972625722e1f91b32f80@news.povray.org>
The font looks nicer, too.
-Mike
Date: 27 Oct 2009 19:25:01
Message: <web.4ae7803e625722e1dd4b45e50@news.povray.org>
I would like to continue with this exercise. A couple of questions:
1) In this last image, did you use a font file or design your own letters using
CSG?
2) How would I go about creating a block for the letters S,O and I? Is it
possible?
Mike
Date: 30 Oct 2009 01:15:07
Message: <web.4aea75b0625722e130c8dcd90@news.povray.org>
> CSG?
> possible?
> Mike
I started a thread at WhatTheFont to see if an actual font like this has been
created. If not, then I will create it myself.
http://www.myfonts.com/WhatTheFont/forum/viewthread.php?threadid=236091&notify=1
Mike
Date: 31 Oct 2009 11:10:00
Message: <web.4aec52f1625722e185e192a70@news.povray.org>
I'm working on a complete font based on the letters you created. I've got
capital A-Z. Not sure if I'm going to stop there or continue with the lower
case, numbers, punctuation, etc..
Mike
Download 'cube_font_preview.png' (103 KB)
Preview of image 'cube_font_preview.png'
Date: 31 Oct 2009 11:34:04
Message: <4aec58ec$1@news.povray.org>
> Mike
The Metro Gothic Fat font also looks similar.
http://www.identifont.com/show?54J
It would be tricky to use in a lot of cases, since there are often
little bits that extend beyond the 1x1 unit box.
Mike
Date: 31 Oct 2009 18:29:57
Message: <4aecba65$1@news.povray.org>
>>> curves to
>>> curves
>> lower
>> Mike
> Mike
Accents on uppercase characters are not little
things..."ÀÂÄÃÈÉÊËÎÏĨÔÖÕÛÜŨŶŸÑ" (only those that I can easily
type)
Then, there is the cedil that extend under. "Çç"
Then, there are several lowercase characters that also extend down. "gjpqy"
