POV-Ray : Newsgroups : povray.binaries.images : Tracing an object through a soft-edged mask; or objects as airbrush 'spray' Server Time
22 Mar 2026 11:18:16 EDT (-0400)
  Tracing an object through a soft-edged mask; or objects as airbrush 'spray' (Message 24 to 33 of 33)
Subject: Re: Tracing an object through a soft-edged mask; or objects as airbrush 'sp=
Date: 14 May 2008 12:10:34
Message: <482b0efa$1@news.povray.org>
Thomas de Groot nous illumina en ce 2008-05-14 04:09 -->
> "Kenneth" <kdw### [at] earthlinknet> schreef in bericht
> news:web.4829b56bdace545278dcad930@news.povray.org...
>> "Zeger Knaepen" <zeg### [at] povplacecom> wrote:
>>> Cool, but you don't need the height_field, just use eval_pigment.  That
>>> way,
>>> you can use any pigment as a mask..
>> Aha, I knew *someone* out there would find a way to improve it (in this
>> case,
>> both you and Thomas.) I'll have to try this--I've never used eval before.
>> Thanks for the code example.
> In Zeger's example, I would replace .gray by .red (or .green or .blue).
> Parsing will be much faster, for the same result.
> Thomas
It's the way to do it whenever the pigment is monochrome. Only take one of the 3
identical colour channels instead of averaging them.
You know you've been raytracing too long when you've ever "lost" a Julia fractal
because you're not quite sure how to align things in four dimensions.
Dylan Beattie
Date: 14 May 2008 12:50:01
Message: <web.482b173d8a21c37b78dcad930@news.povray.org>
That's interesting.  Due, no doubt, to the extra calculations POV has to perform
in turning a full RGB pigment into .gray.
A  more accurate way of getting the pigment pattern's colors into grayscale
would be to substitute a PATTERN for the PIGMENT; it's already in grayscale.
I.e., pattern{bozo...} And--as far as I can tell from section 3.5.11.16 of the
docs--such patterns have 16-bit resolution.
KW
Date: 14 May 2008 13:47:48
Message: <482b25c4$1@news.povray.org>
Hash: SHA1
	No, they actually have full 64 bits float resolution. But so do the
pigments.
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFIKyXDd0kWM4JG3k8RAkhdAJ9nO6BXCLy0g1FZN0gwWDwngjaS0wCeJRsv
EX7lXMQ3buZkUeEzprvH4C8=
=ib+I
-----END PGP SIGNATURE-----
Subject: Re: Tracing an object through a soft-edged mask; or objects as airbrush 'spray'
Date: 14 May 2008 17:20:45
Message: <482b57ad@news.povray.org>
scott napsal(a):
>> This is traced in the usual way, but the y-values that are found are
>> not used
>> to place objects anywhere; rather, they are used to statistically(?)
>> determine
>> whether an object is made or not made at any particular x/z
>> location...a sort
>> of 'chance' determination, with a HF height of 0 being a zero% chance
>> that an
>> object is made, up to 1 being a 100% chance.
> I use this method currently too, in a game to place trees and things
> around the level.  *But*, when you have large areas of low-density, and
> you want to plant thousands of items, it starts to get slow (because
> there are so many "misses").  I am wondering if there is a faster way to
> do it?
As a mathematician, I can say for sure there is:
to sample in one dimension:
-integrate the density function from -inf to x.
	if the function is piecewise continuous (like all interpolations) the
integral is defined
	if the function is windowed (zero outside a finite interval) the
integral is finite
	for heightfields this means summing some data along a line and
interpolating the sums.
-find the inverse function of this integral.
	if the density function is nonnegative this is always possible
	computing the inverse function of a piecewise polynomial function
consists of finding the correct polynomial (e.g. by binary search) and
finding the solution (e.g. by Newton algorithm or (much more slowly) by
binary search).
-sample the integral range uniformly
	this is always possible for finite ranges
-evaluate the inverse function at each sample
for multiple dimensions
-integrate the density function in all but one dimension, with the one
dimension as a parameter.
-sample this function according to the rules for one dimension
-sample the corresponding slice according to the rules for one or more
dimensions.
It's not easy but it might be plausible :-)
You know you've been raytracing too long when...
you ever saw a beautiful scenery and regretted not to take your 6"
reflective ball and a digital camera, thinking "this would have been a
perfect light probe"
		-Johnny D
Johnny D
Date: 15 May 2008 03:26:00
Message: <482be588$1@news.povray.org>
> I came up with some sort of tile-based object load
> balancing, which basically places a grid over the mask, assigns
> object counts to each tile based on relative probabilities, and
> then places objects for each tile separately.
Sounds good - I didn't think of that.
> The best results could be obtained with
> an interpolated zoomed down copy of the input mask,
Which funnily enough, in realtime 3D graphics, you usually have access to,
as they are used by the GPU when drawing your bitmap at small scales.  I'll
give it a shot - thanks.
Subject: Re: Tracing an object through a soft-edged mask; out of memory
Date: 16 May 2008 10:20:01
Message: <web.482d974628652b6ace5ce3790@news.povray.org>
> Yes, the following piece of code, using eval_pigment, gets me a fatal parse
> error: out of memory, while the same code by Kenneth, does not. tested with
> version 3.7 beta 25.
  First off, quite a clever idea, props Kenneth.
  Secondly, I haven't yet tried it, but I believe both parse time and memory
usage could be much improved by declaring a function from the pigment once and
then calling the function to get the appropriate value.  This would avoid
declaring the pigment function (which is what eval_pigment does) over and over
again for the same pigment, and replace a repeated macro call with a function
call, which should be much faster.
So for example, before the loop:
#declare Pig_F = function { pigment { Mask } }
Then, instead of eval_pigment:
// For Greyscale images
#declare Intersection = Pig_F(Position.x, Position.y, Position.z).red;
or
// For RGB images
#declare Intersection = Pig_F(Position.x, Position.y, Position.z).gray ;
-The Mildly Infamous Blue Herring
Date: 16 May 2008 14:45:01
Message: <web.482dd3c2dace545278dcad930@news.povray.org>
For the fun of it, I re-coded my original method to trace the height_field in a
step-by-step linear fashion, rather than randomly. (The statistical process
still uses rand, though.) And for added fun, I let the found y-values of the HF
determine (somewhat) the scale of the small spheres; the result looks a bit like
halftone printing. (In that process, the printed dots vary in size.) The photo
is of Sophia Loren in the film EL CID--a beautiful film to study
for its lighting and image composition, BTW.
The only value that needs changing here is foobar; it determines the "scanning
resolution" of the traces (and automatically scales the spheres.) It can be any
value at all; it doesn't depend on the pixel resolution of the image_map. I.e.,
the trace rays don't *need* to hit a HF triangle vertex / image_map pixel in
order to return a valid height value; they can hit the triangles
anywhere.
One of the reasons I decided to try this linear tracing scheme was that it might
have some relevance to the time-saving 'tiling' idea that's been mentioned (re:
eliminating unnecessary traces from the large dark areas of the image_map/HF.)
I'm working up an overall tiling scheme, and will be back with it ASAP.
Meanwhile, here's the linear-tracing code. I'm not totally sure what values
counter_x and counter_z should start with--1 or 0. Either one *works* but it
should be a logically correct value. Sorry, my brain is tired...
#declare mask =
     height_field {jpeg "sophia_image.jpeg"}
#declare S1 = seed(6455);
#declare counter_x = 0; // one or zero?
#declare counter_z = 0; // one or zero?
#declare foobar = 200; // You can think of this as the "scanning resolution."
union{
// two NESTED #while loops...
#while (counter_z <= foobar) // number of horizontal rows
#while (counter_x <= foobar) // number of trace rays in each row; reset after
                             // each row is completed.
#declare intersexion =
trace(mask, <counter_x/foobar,10,counter_z/foobar>, <0,-1,0>);
#if(rand(S1) <= intersexion.y)
// MAKE object
 sphere{0,1
  scale (.5/foobar)*(.3 + .7*intersexion.y)
        translate <intersexion.x,0,intersexion.z>
#else
// make NO object
#declare counter_x = counter_x + 1;
#end // of INNER #while loop
#declare counter_x = 0; // one or zero? Resets this for each new row
#declare counter_z = counter_z + 1; // to start a new row of traces
#end // of OUTER #while loop
        texture {....}
Download 'sophia_render.jpg' (341 KB)
Preview of image 'sophia_render.jpg'
Date: 16 May 2008 14:53:16
Message: <482dd81c@news.povray.org>
Kenneth napsal(a):
> anywhere.
It looks like a griddler
Date: 16 May 2008 15:05:00
Message: <web.482dd9e68a21c37b78dcad930@news.povray.org>
Hmm. I was assuming that eval_pigment could evaluate a PATTERN in place of a
PIGMENT.  That may be wrong.
I.e., if I did this...
#local Mask=pattern {granite poly_wave 2}
instead of
#local Mask=pigment {granite poly_wave 2}
would eval_pigment{Mask....)  still work even though Mask is no longer a
3-component pigment now, but a scalar quantity?
Ken W.
Date: 17 May 2008 03:29:02
Message: <482e893e$1@news.povray.org>
"Blue Herring" <bhe### [at] tinfoilcatcom> schreef in bericht
news:web.482d974628652b6ace5ce3790@news.povray.org...
> memory
> and
> over
> function
Ah! Clever! I shall try this. Thanks!
