POV-Ray : Newsgroups : povray.binaries.images : waste of time! Server Time
13 Aug 2025 04:58:42 EDT (-0400)
  waste of time! (Message 1 to 10 of 66)
Subject: waste of time!
Date: 27 Jan 2008 20:25:01
Message: <web.479d2dce9dfdbbcc571699ff0@news.povray.org>
so, any free time in your hands?  want to put that quad core to stress with
povray 3.7beta?  If you're, try the little scene below.  With +AM2 +A0.04 +J1.0
1024X768 on a P4 2.66, it just brought my PC to a crawl for the whole weekend!
It all began with a challenge in a brazilian forum, when some guy claimed this
scene:
http://200.213.105.41/greysilica/exemplos/cjcopojateado.png
took him 48 hours to render with Blender internal renderer.
Surely something was wrong, or so I thought.  Well, in the region between the
bottom of second row cups and the top of first row cups, render time was about
11 minutes a line!  It is all about refractions, normals and fresnel
reflections.  40 hours total on a P4 2.66 with povray 3.6.1...
I'm sure it's possible to optimize it with some no_image, no_shadow trickery
with doubles and no_reflection in the main cups, but I didn't thought of it
beforehand!
global_settings { max_trace_level 40 }
background { rgb 1 }
#local cup =
lathe { bezier_spline
48, //nr points
/* 0*/ <0, 2.8571826>, <174.28571, 2.8571826>, <197.14286,2.8571826>,
/* 1*/ <197.14286, 2.8571826>, <197.14286, 2.8571826>, <211.42857,-2.8571174>,
<228.57143,14.285683>,
/* 2*/ <228.57143, 14.285683>, <245.71429, 31.428583>, <242.85714,85.714283>,
/* 3*/ <242.85714, 85.714283>, <242.85714, 85.714283>, <265.71429,80.000003>,
<291.42857,105.71428>,
/* 4*/ <291.42857, 105.71428>, <317.14286, 131.42857>, <308.57143,108.57143>,
<308.57143,185.71428>,
/* 5*/ <308.57143, 185.71428>, <308.57143, 262.85714>, <308.57143,742.85714>,
/* 6*/ <308.57143, 742.85714>, <308.57143, 742.85714>, <317.14286,737.14285>,
<308.57143,754.28571>,
/* 7*/ <308.57143, 754.28571>, <300, 771.42857>, <288.57143,780>,
<280,768.57143>,
/* 8*/ <280, 768.57143>, <271.42857, 757.14285>, <294.28571,165.71428>,
<277.14286,148.57143>,
/* 9*/ <277.14286, 148.57143>, <260, 131.42857>, <231.42857,131.42857>,
<217.14286,105.71428>,
/* 10*/ <217.14286, 105.71428>, <202.85714, 80.000003>, <205.71429,54.285713>,
<185.71429,45.714283>,
/* 11*/ <185.71429, 45.714283>, <165.71429, 37.142883>, <2.8571429,2.8571826>,
<0,2.8571826>
sturm
scale y*.8
scale 1/1000
interior { ior 1.5 }
hollow
#macro tex( col )
pigment { rgb col }
normal { bumps .1 scale .002 }
finish { ambient .01 diffuse .4 brilliance 1.2
specular .97 roughness .02
metallic .1
reflection { .2,.9 metallic .1 fresnel on exponent 1 }
conserve_energy
union {
plane { y 0 pigment { rgb 1 } finish { ambient .2 diffuse .6 } }
object { cup translate 0 tex( <.7,.8,1,.8,.1> ) }
object { cup translate z*.7 tex( <.9,.86,.4,.8,.1> ) }
object { cup translate z*(.7+1.3) tex( <1,.96,.84,.8,.1> ) }
object { cup translate x*.7 tex(<1,1,1,.8,.1> ) }
object { cup translate x*.7+z*.7 tex(<.96,1,.67,.8,.1> )}
object { cup translate x*.7+z*.7*2 tex(<.7,1,.7,.8,.1> ) }
object { cup translate -x*.7 tex(<1,.6,.6,.1,.8> ) }
object { cup translate -x*.7+z*(.0+1.3) tex(<.5,.5,.8,.1,.8> ) }
object { cup translate -x*.7*2+z*(-.7+1.3) tex(<.7,1,.94,.1,.8> ) }
light_source { 1.6*(4-z*8) 1.2 }
rotate -x*30
translate z*2.6-y/3+x*.1
light_source { -z*8 .7 shadowless }
camera { angle 55
//aperture .04 blur_samples 60 confidence 1 focal_point y/3+z*2
Download 'multiple_cups.png' (588 KB)
Preview of image 'multiple_cups.png'
Subject: Re: waste of time!
Date: 27 Jan 2008 20:52:17
Message: <479d3551$1@news.povray.org>
Hmm strange, why is it letting you pass a 4D vector to 'rgb'? Is the
fourth term filter or transmit? Does rgb really behave as rgbft?
Date: 27 Jan 2008 20:57:48
Message: <479d369c$1@news.povray.org>
Wait, that's a 5D vector...
Date: 27 Jan 2008 21:07:11
Message: <479d38cf$1@news.povray.org>
z*2.6-y/3+x*.1 instead of <0.1, -1/3, 2.6>? This isn't the obfuscated
code contest, you know :)
I'm trying to modify the scene so that the camera gets rotated, instead
of the whole scene. And taking that lightsource outside the union. My
final goal is a camera rotate y*360*clock that looks good. It's not
turning out so easy...
Date: 28 Jan 2008 05:15:00
Message: <web.479da9f5b082306e37391bc50@news.povray.org>
Nice!
Whew!
I couldn't do that. I'm lacking patience. :)
And it would last more than 40 hours with my PC. ;)
How much time would it need, when these cups would be filled with different
juices?
The final result isn't a waste of time!!
Regards
                 bluetree
Date: 28 Jan 2008 08:37:49
Message: <479ddaad$1@news.povray.org>
Very nice way to waste time...
Blender image has perhaps better lights, but I like a lot your cups.
Paolo
> scene:
> beforehand!
> #local cup =
> 48, //nr points
> <280,768.57143>,
> <0,2.8571826>
> sturm
> scale y*.8
> scale 1/1000
> hollow
> #macro tex( col )
> pigment { rgb col }
> metallic .1
> conserve_energy
> #end
> union {
> rotate -x*30
> camera { angle 55
Date: 28 Jan 2008 10:11:14
Message: <479df092$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/27 20:20:
> scene:
> beforehand!
You have multiple reflections and refractions. That mean that you have tons of
rays to compute. Add the aa and the small bumps, you need lot of subsampling =
lot of time.
Try adding adc_bailout 0.01 in the global_settings.
It will cause a small decrease in quality that can go unnoticed, but will
accelerate things as the ray tracing will often stop much earlier.
The strongest reason for the people to retain the right to keep and bear
arms is, as a last resort, to protect themselves against tyranny in
government.
Thomas Jefferson
Date: 28 Jan 2008 10:51:40
Message: <479dfa0c@news.povray.org>
seemingly, yes.  It gives a "suspicious" warning at the console output.
It's rgbft.  I think I should've put some more transmit and a little less
filter.  Hmm, I suppose 1 filter and 1 transmit do not work right:  the
color became quite bizarre when I tried...  I also think the original
image had a lot more diffuse and ambient as well...
Download 'us-ascii' (1 KB)
Date: 28 Jan 2008 10:53:36
Message: <479dfa80$1@news.povray.org>
> less filter.  Hmm, I suppose 1 filter and 1 transmit do not work right:
>  the color became quite bizarre when I tried...  I also think the
> original image had a lot more diffuse and ambient as well...
I heard (filter + transmit) should be <= 1 for things to look correctly.
Date: 28 Jan 2008 10:54:19
Message: <479dfaab@news.povray.org>
> tons of rays to compute. Add the aa and the small bumps, you need lot of
> subsampling = lot of time.
> will accelerate things as the ray tracing will often stop much earlier.
He also has focal blur (commented out on the scene, but looks like the
image has it).
