POV-Ray : Newsgroups : povray.binaries.images : waste of time! Server Time
29 Mar 2026 09:35:43 EDT (-0400)
  waste of time! (Message 27 to 36 of 66)
Subject: Re: waste of time!
Date: 28 Jan 2008 15:25:00
Message: <web.479e394bb082306ef48316a30@news.povray.org>
Alain <ele### [at] netscapenet> wrote:
> Just rendered here with 3.7.
whoa!
> LOT faster with +am2 +a0.3 at 1360*1024 AMD Athlon TBird 1400MHz.
> Added adc_bailout 0.013.
> Render time: 1:48:15.
you just punched me in the face!  And I liked it... :P
> Only thing, your glasses look much darker.
yeah, too many pigment interactions from everywhere going on.
Many thanks for adc_bailout tip.  I actually looked it up from max_trace_level
in the documentation, but they give the hint not to mess with it...
I also saw what you said about fade_power and fade_distance in the interior.
But I was afraid of it getting much worse to render...
well, now that you're feeling bold and adventurous, try it with area_light and
photons. And post the result! :)
Date: 28 Jan 2008 16:00:49
Message: <479e4281$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/28 15:21:
> whoa!
adc_bailout is used to limit how deep the trace_level can go. If the
contribution of a surface drop under that value, you assume that the actual
result is "close enough" and stop checking any further.
Increasing it does reduce the quality of the render, but that reduction is often
not noticeable in *most* cases if you don't increase it to much. adc_bailout 0.1
is to big, adc_bailout 0.01 to 0.02 is usualy acceptable.
Experience hath shewn, that even under the best forms of government those
entrusted with power have, in time, and by slow operations, perverted it
into tyranny.
Thomas Jefferson
Date: 28 Jan 2008 19:25:00
Message: <web.479e7221b082306e3ffee9290@news.povray.org>
adc_bailout 0.111     // larger number = faster
"acceptable"?
see img @ 32 minutes 5 secs with area_light
lost 2 glasses for additional speed
> Alain
> into tyranny.
> Thomas Jefferson
Sadly all too obvious today. Superman where are you now.
Download 'glasses3.png' (131 KB)
Preview of image 'glasses3.png'
Date: 28 Jan 2008 21:00:00
Message: <web.479e8807b082306e6dd25c20@news.povray.org>
> "acceptable"?
hmm, 32 minutes at, what, 640x480?  and no supersampling antialiasing?  Besides,
there doesn't even seem to be any shadows...
I'll play with it, but first I need to come up with a better bezier curve... :)
Date: 28 Jan 2008 21:40:00
Message: <web.479e918eb082306e3ffee9290@news.povray.org>
that was [512x384, AA 0.3] from res menu / 750mhz single CPU
shadows are faint but visible
and my edits:code for previous img
(radiosity more fully explained)
#include "echo.inc"
global_settings {
  max_trace_level 10
  assumed_gamma 1.0
  // for HDR image file creation adc_bailout 1/1e6 = 0.000001
  // global setting adc_bailout keyword followed by float value to specify
  // the point at which a ray's contribution is considered insignificant
  // The default value is 1/255, or approximately 0.0039, since a change smaller
than that could not be visible in a 24 bit image.
  // Setting adc_bailout to 0 will disable ADC
#if (1)
  radiosity {
    // controls radiosity pre-trace gathering step
    pretrace_start 0.08 //default 0.08
    pretrace_end 0.01   // default 0.04
    //range 0.0 and 1.0 which specifies the size of the blocks in the
    // mosaic_preview as a percentage of the image size
    count 40 // The integer number of rays that are sent out whenever a new
radiosity value has to be calculated is given by count.
    // A value of 35 is the default, the maximum is 1600.
    // When this value is too low, the light level will tend to look a little
bit blotchy, as if the surfaces were
    // slightly warped. If this is not important to your scene (as in the case
that you have a bump map or if you have a strong texture)
    // then by all means use a lower number.
    // minimum number of old ambient values blended together to create a new
interpolated value. The total number blended will
    // vary depending on error_bound. All previous values that fit within the
specified error_bound will be used in the average.
    nearest_count 8
    // lower than 4, things can get pretty patchy. Must be no more than 20,
since that is the size of the array allocated.
    // default 5
    error_bound 1.5  // default 1.8 is good for a smooth general lighting
effect.
    // Lower values are more accurate, but will strongly increase the danger of
artifacts
    // and therefore require higher count. You can use values even lower than
0.1 but both render time and memory
    // use can become extremely high then.
    recursion_limit 3   // default 3
    // recursion levels are used to calculate the diffuse inter-reflection
    low_error_factor .5
    // The low_error_factor is a float tuning value which sets the amount that
the error bound is dropped during the preliminary image passes. If your low
error factor is 0.8 and your error bound is set to 0.4 it will really use an
error bound of 0.32 during the first passes and 0.4 on the final pass.
    // default 0.5
    gray_threshold 0.01
    // The gray_threshold float value grays it down a little, to make your scene
more believable. A value of .6 means to calculate the ambient
    // value as 60% of the equivalent gray value calculated, plus 40% of the
actual value calculated. At 0%, this feature does nothing. At 100%, you always
get white/gray ambient light, with no hue.
    // default 0.0
    minimum_reuse 0.0095
    // This sets a minimum bound for the reuse. If this value is too low, (which
it should be in theory) rendering gets slow, and inside corners can get a little
grainy.
    // If it is set too high, you do not get the natural darkening of
illumination near inside edges, since it reuses. At values higher than 2% you
start getting more just plain errors, like reusing the illumination of the open
table underneath the apple. Remember that this is a unit less ratio.
    // default 0.015.
    brightness 0.95 // default 1.0
    // specifies a float value
    // ambient_light in a non-Radiosity scene    //default <1,1,1>
    // Megapov 1.1
    // randomize on
    // Radiosity estimation affected by normals
    normal on
    media on
  }   #end
background { rgb 1 }
#local cup =
lathe { bezier_spline
48, //nr points
/* 0*/ <0, 2.8571826>, <174.28571, 2.8571826>, <197.14286,2.8571826>,
/* 1*/ <197.14286, 2.8571826>, <197.14286, 2.8571826>, <211.42857,-2.8571174>,
<228.57143,14.285683>,
/* 2*/ <228.57143, 14.285683>, <245.71429, 31.428583>, <242.85714,85.714283>,
/* 3*/ <242.85714, 85.714283>, <242.85714, 85.714283>, <265.71429,80.000003>,
<291.42857,105.71428>,
/* 4*/ <291.42857, 105.71428>, <317.14286, 131.42857>, <308.57143,108.57143>,
<308.57143,185.71428>,
/* 5*/ <308.57143, 185.71428>, <308.57143, 262.85714>, <308.57143,742.85714>,
/* 6*/ <308.57143, 742.85714>, <308.57143, 742.85714>, <317.14286,737.14285>,
<308.57143,754.28571>,
/* 7*/ <308.57143, 754.28571>, <300, 771.42857>, <288.57143,780>,
<280,768.57143>,
/* 8*/ <280, 768.57143>, <271.42857, 757.14285>, <294.28571,165.71428>,
<277.14286,148.57143>,
/* 9*/ <277.14286, 148.57143>, <260, 131.42857>, <231.42857,131.42857>,
<217.14286,105.71428>,
/* 10*/ <217.14286, 105.71428>, <202.85714, 80.000003>, <205.71429,54.285713>,
<185.71429,45.714283>,
/* 11*/ <185.71429, 45.714283>, <165.71429, 37.142883>, <2.8571429,2.8571826>,
<0,2.8571826>
sturm
scale y*.8
scale 1/1000
interior { ior 1.5 }
hollow
#macro tex( col )
  pigment { rgb col }
  normal { bumps .1 scale .002 }
  finish {
    ambient .01 diffuse .4 brilliance 1.2
    specular .97
    roughness .02
    metallic .1
    reflection { .2,.9 metallic .1 fresnel on exponent 1 }
    conserve_energy
union {
plane { y 0 pigment { rgb .6 } finish { ambient 0 diffuse 1 } }
//object { cup translate 0 tex( <.7,.8,1,.8,.1> ) }
object { cup translate z*.7 tex( <.9,.86,.4,.8,.1> ) }
object { cup translate z*(.7+1.3) tex( <1,.96,.84,.8,.1> ) }
//object { cup translate x*.7 tex(<1,1,1,.8,.1> ) }
object { cup translate x*.7+z*.7 tex(<.96,1,.67,.8,.1> )}
object { cup translate x*.7+z*.7*2 tex(<.7,1,.7,.8,.1> ) }
object { cup translate -x*.7 tex(<1,.4,.4,.95,.1> ) }
object { cup translate -x*.7+z*(.0+1.3) tex(<.3,.3,.9,.8,.1> ) }
object { cup translate -x*.7*2+z*(-.7+1.3) tex(<.7,1,.94,.8,.1> ) }
translate -z*0.8
light_source {
   <0,0,10>
   4.5
   area_light
   x,y,4,4
   circular orient jitter
   location <0,5,-9>
   look_at <-0.3,.6,0>
   angle 20
streamlined way to see a value in message pane:
echo(str) / echof(float) / echov(3d_vector)
%%%%%%%%%%%%%%%%%%%%%%%%%%%% echo.inc %%%%%%%%%%%%%%%%%%%%%%%%
#macro echo(Str)
    #if (1)
        #debug Str
#macro echof(f)
echo(concat("\n*********** ",str(f,2,5)," *********** "))
#macro echov(V)
echo(concat("\n********** <",str(V.x,2,5),",",str(V.y,2,5),",",str(V.z,2,5),">
Date: 28 Jan 2008 21:50:00
Message: <web.479e9430b082306e3ffee9290@news.povray.org>
I should add:
want to know that value before rendering is done?
do it twice:
echov(<1,1,1>)
echov(<1,1,1>)
strange kwirk in #debug
Date: 28 Jan 2008 22:40:01
Message: <web.479e9f59b082306e6dd25c20@news.povray.org>
AA 0.3 is not supersampling AA, which is the best.  command-line:  +AM2 +A0.04
or lower...
hmm, you put the standard radiosity there.  Given the white background, it
almost made the shadows disappear...
Date: 29 Jan 2008 00:10:01
Message: <web.479eb4d1b082306ec29b7d970@news.povray.org>
> or lower...
with command line +AM2 +A0.04 looking like 40 minutes for one cup
(hard pressed to see a difference without)
here: 12 minute cup (+AM2 +A0.04 NOT USED)
adjusted in this manner (except cup back to orig color filter 1)
object { cup translate -x*.7 tex(<1,.6,.6,1,.1> ) }
one cup 'til effects acheived:
plane { y 0 pigment { rgb .7 } finish { ambient 0 diffuse 1 } }
background { rgb .2 }
#declare lv = <-5,5,-5>; // <0,1,0> cant work here
#declare arraylen = 1;
#declare _x = vnormalize(vcross(y,lv))*arraylen;
#declare _y = vnormalize(vcross(lv,_x))*arraylen;
light_source {
   lv
   1
   area_light
   _x,_y,4,4
   location <0,5,-9>
   look_at <-0.3,.6,0>
   angle 20
Download 'glasses5.png' (38 KB)
Preview of image 'glasses5.png'
Date: 29 Jan 2008 03:35:01
Message: <web.479ee489b082306ec29b7d970@news.povray.org>
Type 2, adaptive and recursive, and a threshold of .04 has super-sampled the
bumps right out, with a render time diff of 3.5 hours.
I was thinking about resetting bailout to 24bit (from .111 to 1/256) next to see
if there is a visible difference, but if bumps should be kept, it should be
compared glasses5.png as opposed to this one, 6.
Maybe bigger bumps are needed with super-sampling? or removed from tex() for
additional speed.
hope I get to see it.
Download 'glasses6.png' (36 KB)
Preview of image 'glasses6.png'
Date: 29 Jan 2008 08:37:24
Message: <479f2c14@news.povray.org>
Jan Dvorak wrote:
> Nicolas Alvarez napsal(a):
>> I heard (filter + transmit) should be <= 1 for things to look correctly.
> f+t <= 1
> f   >  0
> t   >  0
> Did I forget something?
Reflection would also play into the equations.
The keyword "conserve_energy" can be useful.
