POV-Ray : Newsgroups : povray.binaries.images : Invaders from outer space Server Time
19 Mar 2026 04:31:09 EDT (-0400)
  Invaders from outer space (Message 1 to 8 of 8)
Subject: Invaders from outer space
Date: 9 Mar 2007 23:00:00
Message: <web.45f22b4c91f16f5dc9d1b24c0@news.povray.org>
This is a image using a particular tecnique used over POV
Basically, is place some primitives, give properties nearly to perfect
mirrors and render it at high trace rate, then look, zoom, change,
re-render... until obtain a aceptable image
To raise the image look, I use a few of post-process in photoshop. I posted
original image and postprocessed to POV purish
sry for my english
Download 'invaders.jpg' (46 KB)
Preview of image 'invaders.jpg'
Subject: Re: Invaders from outer space
Date: 9 Mar 2007 23:10:01
Message: <web.45f22e516b6ce5a1c9d1b24c0@news.povray.org>
Original image, source code in p.b.s.
Download '0015.png' (392 KB)
Preview of image '0015.png'
Date: 10 Mar 2007 15:08:13
Message: <45f3102d@news.povray.org>
Looks interesting. Is it just a sphere and some disks?
One of the first things I tried with POV-Ray was to see what
it would do when the camera was placed between to mirrors ;)
It looked a bit dull in the distance so I gave the finish
ambient > 0 to fade into some sort of white glow.
Download 'conref.jpg' (38 KB) Download 'conref-external.jpg' (22 KB)
Preview of image 'conref.jpg'
Preview of image 'conref-external.jpg'
Date: 10 Mar 2007 15:43:52
Message: <45f31888$1@news.povray.org>
Oh, ignore that, I just noticed you posted the source in p.t.s-f ;)
I was surprised to see you did't use normals in your textures, so
all the structure you see is actually just caused by reflections.
Actually, you can get quite funny effects in your image when
using normals. Try applying
   normal {bumps 0.02 scale 0.03}
to the mirror texture or
   normal {bumps 0.2 scale 0.01}
to the first of the three sphere objects ;)
Date: 13 Mar 2007 00:50:01
Message: <web.45f63ab56b6ce5a15cbfbb400@news.povray.org>
I like it!  Nice work.  This would make an interesting science-fiction book
cover.
Ken W.
Date: 13 Mar 2007 12:10:01
Message: <web.45f6dab06b6ce5a1c3ecc9c0@news.povray.org>
I tested your suggest, really curious effect.
But add normals reduce the zooming posibilities of the source, later I
upload other image made with same code but other zoom
Date: 15 Mar 2007 17:48:04
Message: <45f9cd24@news.povray.org>
Revisiting that old scene I just had to play with it some more,
so here is a triangular room made using three mirrors:
Download 'conref2-800.jpg' (89 KB)
Preview of image 'conref2-800.jpg'
Date: 15 Mar 2007 19:00:01
Message: <web.45f9dd3d6b6ce5a1bc8faf520@news.povray.org>
Good image, I like it
