POV-Ray : Newsgroups : povray.binaries.images : Corrosion Server Time
17 Aug 2025 14:50:48 EDT (-0400)
  Corrosion (Message 1 to 10 of 11)
Subject: Corrosion
Date: 16 Nov 2006 08:25:00
Message: <web.455c66735841d0c5c150d4c10@news.povray.org>
Was toying with doing some macro-generated meshes.  Uses HDRI-based
lighting.
For full size and the full series of 5 wallpapers (5 different lighting
environments):
1/5) http://www.deviantart.com/deviation/43139721/
2/5) http://www.deviantart.com/deviation/43139745/
3/5) http://www.deviantart.com/deviation/43139767/
4/5) http://www.deviantart.com/deviation/43139787/
5/5) http://www.deviantart.com/deviation/43139810/
-tgq
Download 'corrosion.01 (medium).jpg' (26 KB)
Preview of image 'corrosion.01 (medium).jpg'
Subject: Re: Corrosion
Date: 16 Nov 2006 08:41:35
Message: <455c6a8f@news.povray.org>
An interesting idea! Hmm, make the corrosion looking rougher, maybe
(crand?). And distribute it more unequal, not so many small spots all over,
but somewhere some bigger ones, somewhere some smaller ones. Unequal just.
Some side heavier, some side lesser.
I am very interested to see how it goes on!
Greetings,
Sven
"Trevor G Quayle" <Tin### [at] hotmailcom> schrieb im Newsbeitrag
news:web.455c66735841d0c5c150d4c10@news.povray.org...
> lighting.
> environments):
> -tgq
Date: 16 Nov 2006 09:45:01
Message: <web.455c73cfed830b83c150d4c10@news.povray.org>
> Greetings,
> Sven
Thanks.  Its just an automatically generated mesh with surface deformation
based on a given pattern (granite is used here).  The rust texture itself is
not the best and needs a little work.  I'll post the code when I can get it
cleaned up a bit if you'd like to have a look.
-tgq
Date: 16 Nov 2006 14:39:07
Message: <455cbe5b@news.povray.org>
Looks very good..... it would be nice to see this surface used in a
"real-life" scene.
Are the macros used your own? Did you import the original mesh? Id like
to see this kind of deformation implemented into the official release of
POV.
~Sam
Date: 16 Nov 2006 15:10:01
Message: <web.455cc47ded830b83c150d4c10@news.povray.org>
> "real-life" scene.
> POV.
> ~Sam
Thanks!
The macros are my own.  The lighting is an HDRI-based lighting macro I've
been fiddling with for ages (and still promise to post at some point when
I'm thoroughly satisfied).  The mesh is generated internally by SDL. It
specifically is made to generate a torus.  Each point position is
calculated (depending on the determined mesh size) as well as the surface
normal for the undeformed point.  The point is them deformed in the
direction of the surface normal based on a deformation function (granite
was used here).  New surface normals are then recalculated based on the new
point location and the points in it's immediate proximity (i.e. four points:
up, down, right and left) to give a fairly good and smooth result.  Code for
the mesh will be posted soon.
I don't think it can be implemented in POV very easily as it is simply based
on mesh points whereas POV primitives are not meshes (except meshes of
course) and it also relies on the mesh being subdivided quite fine to get
decent results that aren't noticeably 'blocky'.
-tgq
Date: 16 Nov 2006 16:30:00
Message: <web.455cd7a8ed830b83c150d4c10@news.povray.org>
Posted in p.t.s-f.
-tgq
Date: 16 Nov 2006 17:50:55
Message: <455ceb4f@news.povray.org>
I'm under no belief that this can be done with primitives... but having
the capability to do this to simple meshes (cubes, etc.) would be very
helpful.
~Sam
Date: 16 Nov 2006 18:11:31
Message: <455cf023@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:455ceb4f@news.povray.org...
based
get
> helpful.
> ~Sam
didn't someone post a brick macro recently that created a rounded box as a
mesh and deformed it based on a pigment function?
Date: 16 Nov 2006 19:50:01
Message: <web.455d0684ed830b83113e81f30@news.povray.org>
Yup, that was me. I even started writing some macros for other mesh-based
primitives, working towards something like what Trevor has done (I think I
had eroded rock in mind). But, as always, I got side-lined by another
project...
This pic looks really good, by the way! :-) I'd like to see some more...
Bill
Date: 17 Nov 2006 08:45:12
Message: <455dbce8$1@news.povray.org>
> internally by SDL. It specifically is made to generate a torus.  Each
> point position is calculated (depending on the determined mesh size)
> as well as the surface normal for the undeformed point.  The point is
> them deformed in the direction of the surface normal based on a
> deformation function (granite was used here).  New surface normals
> are then recalculated based on the new point location and the points
> in it's immediate proximity (i.e. four points: up, down, right and
Note that this is pretty much what the hf_torus macro does which is included
with POV-Ray 3.5. It's always more satisfying to do things from scratch
though. :)
Rune
http://runevision.com
