POV-Ray : Newsgroups : povray.binaries.images : Help! - texture problem Server Time
22 Feb 2026 08:12:22 EST (-0500)
  Help! - texture problem (Message 1 to 10 of 16)
Subject: Help! - texture problem
Date: 30 Jun 2006 10:45:01
Message: <web.44a5389df94cf7555504269e0@news.povray.org>
I have a problem. I want to generate discs with overlaping textures. But all
what I get are discrete discs despite trying many settings for transmit or
filter. The disc definition is as follows -
//__________________________________
disc {
        0,y,1
                        cylindrical
                        color_map {
                                [0.0  rgb 0.5 transmit 0 filter 0]
                                [0.3  rgb 1.0 transmit 0 filter 0]
                                [0.9  rgb 0.0 transmit 0 filter 0]
                                [1.0  rgb 0.0 transmit 0 filter 0]
                finish {ambient 1 diffuse 0}
//___________________________________
There are no lights, no radiosity, only these discs and a background with
rgb
0.5.
How can I get 'merged' discs?
Please help!
Norbert Kern
Download 'problem.jpg' (62 KB)
Preview of image 'problem.jpg'
Subject: Re: Help! - texture problem
Date: 30 Jun 2006 10:52:01
Message: <44a53a91$1@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
news:web.44a5389df94cf7555504269e0@news.povray.org...
But all
transmit or
> disc {
>         0,y,1
>         texture {
>                 pigment {
>                         cylindrical
>                         color_map {
how do you expect to have transparency with a transmit-value of 0 ? :-/
try:
disc {
         0,y,1
                         cylindrical
                         color_map {
                                 [0.0  rgb 0.5 transmit 1]
                                 [0.3  rgb 1.0 transmit 0]
                                 [0.9  rgb 0.0 transmit 0]
                                 [1.0  rgb 0.0 transmit 0]
cu!
Date: 30 Jun 2006 11:11:47
Message: <44a53f33$1@news.povray.org>
Norbert Kern wrote:
> Hi,
You don't want transmit or filter. You want disc*disc or max(disc, disc)
or min(disc, disc). To do any of that, you'll need to make each pattern
you would like to overlap into a function.
  -Shay
Date: 30 Jun 2006 16:30:00
Message: <web.44a5890d9c5d7299a5591a630@news.povray.org>
thanx, but your tip doesn't solve the problem.
Of course I tried several values for transmit and filter.
Norbert Kern
Download 'problem2.jpg' (59 KB)
Preview of image 'problem2.jpg'
Date: 30 Jun 2006 16:35:01
Message: <web.44a58a5f9c5d7299a5591a630@news.povray.org>
interesting, but in the end I want to do it with more than 1000000 discs.
IIRC you can add so many patterns in a single function.
Norbert Kern
Date: 30 Jun 2006 18:41:27
Message: <44a5a897$1@news.povray.org>
could you give the entire source ?
cu!
Date: 30 Jun 2006 19:14:26
Message: <44a5b052$1@news.povray.org>
Norbert Kern wrote:
> Hi,
> disc {
>         0,y,1
>         texture {
>                 pigment {
>                         cylindrical
>                         color_map {
> rgb
> 0.5.
> Please help!
I guess I am not sure what you want.
some thing like this gets?
[0.0  rgb 0.5 transmit  1 filter 0]
[0.3  rgb 1.0 transmit .5 filter 0]
[0.9  rgb 0.0 transmit .5 filter 0]
[1.0  rgb 0.0 transmit .5 filter 0]
Date: 1 Jul 2006 00:35:00
Message: <web.44a5fb529c5d72994c493f840@news.povray.org>
> cu!
this piece of code shows the problem -
global_settings {
        assumed_gamma 2.2
        max_trace_level 150
        noise_generator 2
#declare hfscalx = 80;
#declare hfscalz = 60;
        orthographic
        location <0,100,0>
        look_at  <0,0,0>
        right hfscalx*x
        up hfscalz*z
background {color rgb 0.5}
//plane {y, -1 texture {pigment {color rgb 0.5} finish {ambient 1 diffuse
0}}}
#declare thingy =
disc {
        0,y,1
                        cylindrical
                        color_map {
        scale 4
        hollow double_illuminate
#declare areal = plane {y,0}
#declare r1 = seed(1);
#declare n = 0;
#while (n < 200)
        #declare X = rand(r1)*hfscalx*2;
        #declare Z = rand(r1)*hfscalz*2;
        #declare Norm = <0,0,0>;
        #declare Start = <X-hfscalx,100,Z-hfscalz>;
        #declare Inter = trace (areal,Start,-y,Norm);
        #if (vlength (Norm) != 0)
                object {
                        thingy
                        scale (0.7+0.6*rand(r1))
                        translate <Inter.x,0,Inter.z>
                #declare n = n+1;
//______________________________________________
Date: 1 Jul 2006 00:45:00
Message: <web.44a5fcc99c5d72994c493f840@news.povray.org>
I'm sorry, doen't help.
Transmit seems only to let fade out the pigment without any transparency
I posted source code in my last answer within this thread, Jim.
Norbert Kern
Date: 1 Jul 2006 01:46:45
Message: <44a60c45@news.povray.org>
Okay, I ran that code. It shows what I got when I tested the code you
first showed.  Attached is my own version.
Upper left is your original texture with no filter, no transmission.
Lower left is the texture with .5 filter on all pigments and 0 transmission.
Upper right is 0 filter and .5 transmission on all pigments.
Lower right shows the texture with 0 filter and the transmission varied
from 1 at the outer edge of each disc to 0 at the center.
Given this reference I am wondering which effects are favourable and
which are not for your final effect.
Alternatively maybe you could mock up the effect you want in an image
editor.  It is what you mean by "merged discs" and "transparency" that I
am not understanding I guess.
Are you trying for craters btw?
Download 'img.test.0069.jpg' (39 KB)
Preview of image 'img.test.0069.jpg'
