POV-Ray : Newsgroups : povray.binaries.images : user_defined camera sample Server Time
21 Oct 2024 05:24:38 EDT (-0400)
  user_defined camera sample (Message 1 to 10 of 13)
Subject: user_defined camera sample
Date: 18 Feb 2003 14:38:09
Message: <sh255vomna91r0d9htauhkuhl3p2harpcv@4ax.com>
Here is an example of rendering with user_definned camera (patch). Essentially
it is camera type where rays sended from camera are defined using functions.
Using user_defined camera you can mimic all already existing camera types as
well as you can average (coordinates, not result) two views, select subviews,
etc, etc. Rays can be placed at any place in any direction. Camera's 'surface'
can have discontinuity areas (correct word?). In posted example there is only
one camera. Four subviews are simple joined using function{select(,,,)} with
other functions. They are as follow:
  top-left     - perspective camera with low angle - nearly orthogonal
  top-right    - rays starts from wall of cylinder but are 'angled' like in
                 perspective camera so rays are not parallel to plane
  bottom-left  - simple perspective camera
  bottom-right - averaging from spherical camera to orthogonal, from one
                 location to another
Animated version in p.b.a. Any comments ?
ABX
Download 'user_defined.png' (185 KB)
Preview of image 'user_defined.png'
Subject: Re: user_defined camera sample
Date: 18 Feb 2003 16:15:57
Message: <3e52a28d@news.povray.org>
hey abx
wow, this looks *very* cool. i really like the idea.
florian
Date: 19 Feb 2003 10:11:06
Message: <3e539e8a@news.povray.org>
Very interesting! Tell us more
John
Run Fast
Run Free
Run Linux
Date: 19 Feb 2003 10:27:00
Message: <gu775v0k57auvi9gupgj0oelamgkhdcbi7@4ax.com>
On Wed, 19 Feb 2003 15:02:54 -0000, "Doctor John" <jgu### [at] netscapenet>
I don't know what you want to know... For example using that camera you can:
- make cone, texture, unroll it to flat arc, then print, cut and glue 3d model
- create subviews
- "morph" cameras
- apply real deformation instead of normal{}
Probably controlling it won't be trivial thing.
ABX
Date: 19 Feb 2003 10:47:54
Message: <3e53a72a$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in
Umm, like where can I get the patch? .... or if it's not yet ready for
public release, what sort of time-scale will we be looking at?
John
Run Fast
Run Free
Run Linux
Date: 19 Feb 2003 11:00:41
Message: <u3a75vompb7egu4hv3vm1u4fhfs3k8e30p@4ax.com>
On Wed, 19 Feb 2003 15:45:31 -0000, "Doctor John" <jgu### [at] netscapenet>
I do not know :-( It's part of next MegaPOV. MegaPOV 1.1 will not be released
before sources of POV-Ray 3.51 because it is builded over 3.51. I do not know
when 3.51 will be available. If you really need user_defined camera patch for
your not started 'Old Technology' image I can mail you necessary changes :-)
ABX
Date: 19 Feb 2003 17:01:21
Message: <Xns9327EA89E9017seed7@povray.org>
Very interesting!
What happens if you use focal blurr?
Ingo
Date: 20 Feb 2003 15:38:59
Message: <3e553ce3@news.povray.org>
Thanks for the offer, but don't worry; I'll wait until everyone else gets
it. Besides its a bit late for me to start playing with new effects.
John
Run Fast
Run Free
Run Linux
Date: 25 Feb 2003 09:57:43
Message: <3e5b8467@news.povray.org>
Cool,
did you made any experiment to render "stereogram", I join one that was done
with 4 different render(4different cameras), and additionnal select, cut &
paste work with paintshop.
It is why i give up to render an animated scene with this technique.
Could it be possible to do it in one shot with your user defined camer?
Chaps.
"ABX" <abx### [at] abxartpl> wrote in message
news:sh255vomna91r0d9htauhkuhl3p2harpcv@4ax.com...
Essentially
functions.
as
subviews,
'surface'
only
with
in
>                  location to another
> ABX
Download 'noelste2.jpg' (28 KB)
Preview of image 'noelste2.jpg'
Date: 25 Feb 2003 10:24:37
Message: <6j1n5v4egh0agkktu47aagpdeu7isaq4j4@4ax.com>
"chaps" <cha### [at] yahoocom>:
> Cool,
Unfortunatelly I'm this kind who never play with stereograms because I'm not
able to see it (thought I did not tried it much). I'm not sure what kind of
pseudo 3D images you mean (I recall at least 3 types) but I suppose user_defined
can be enough. Actually I think that another feature will be better for this
purpose: taking view of cameras into pigment{camera_view{camera definition}} and
then combine those pigments in function driven post processing using depth
output. This can be done already.
ABX
