POV-Ray : Newsgroups : povray.binaries.images : UV-coordinate pigment - 1 attachment Server Time
7 May 2024 22:43:14 EDT (-0400)
  UV-coordinate pigment - 1 attachment (Message 1 to 3 of 3)
Subject: UV-coordinate pigment - 1 attachment
Date: 26 Mar 2003 07:40:08
Message: <Xns934A8B380763Dtorolavkhotmailcom@204.213.191.226>
Of course I had to try ABX' suggestion to make one's
own XYZ to UV mapping functions:
http://news.povray.org/povray.advanced-users/30962/
And after having played around for a while with that
technique, I thought that maybe one could define a
pigment that shows the uv-coordinates "projected"
onto the surface of the shape one are working with.
The attached image shows the result.
A macro; UVcoordPigment() builds this pigment.
Here is how it was called:
object {
  ParametricMesh( ... )
    uv_mapping
    UVcoordPigment()
Any suggestions or comments ?
Tor Olav
Download 'B-Splines03_09_03.jpg' (103 KB)
Preview of image 'B-Splines03_09_03.jpg'
Subject: Re: UV-coordinate pigment - 1 attachment
Date: 26 Mar 2003 08:11:00
Message: <bf938v0ve50rka8b3sovjbtbdmjhl7qike@4ax.com>
On 26 Mar 2003 07:40:08 -0500, Tor Olav Kristensen <tor_olav_kCURLYAhotmail.com>
I have used that idea in my 'random' isosurface maze:
http://news.povray.org/search/advanced/?s=maze&g=povray.binaries.images
Interesting, you mean red is u, green is v and blue is nothing ?
Since it is mesh, isn't that already posible with 'traditional' uv_mapping ?
ABX
Date: 26 Mar 2003 08:36:58
Message: <Xns934A94E359AD1torolavkhotmailcom@204.213.191.226>
ABX <abx### [at] abxartpl> wrote in
news:bf938v0ve50rka8b3sovjbtbdmjhl7qike@4ax.com:
I did not realise that back then. Hmmm... Maybe I could
use this in some of my own isosurfaces.
Yes.
> uv_mapping ?
It _is_ traditional UV-mapping. Maybe I was a little
unclear about that: No user defined functions are used
to build or map the pigment. It is POV-ray itselt that
does the mapping. My macro just builds the pigment.
(The ParametricMesh() macro defines, as usual, the UV
coordinates for each mesh triangle vertice.)
Tor Olav
