POV-Ray : Newsgroups : povray.binaries.images : A Quiet Lane Server Time
18 Nov 2025 04:12:43 EST (-0500)
  A Quiet Lane (Message 1 to 10 of 40)
Subject: A Quiet Lane
Date: 4 Feb 2021 03:06:29
Message: <601bab05@news.povray.org>
Finally, after about four months.
The scene is inspired by late nineteenth century paintings of the Late
Romantic school and Genre pieces.
This is about the first scene were I made /really/ use of pigment
patterns (road, thatched roofs, dirt on walls) and the Displacement tool
in Poseray (thatched roofs). Those will be tools I shall come back too
frequently.
Download 'a quiet lane_final.jpg' (353 KB)
Preview of image 'a quiet lane_final.jpg'
Subject: Re: A Quiet Lane
Date: 4 Feb 2021 05:21:49
Message: <601bcabd$1@news.povray.org>
> frequently.
oh... there you go. nice!
Date: 4 Feb 2021 07:05:01
Message: <web.601be255c0f5ba296396ca3e0@news.povray.org>
> frequently.
> Thomas
Wow! :-)
Pascal
Date: 4 Feb 2021 07:55:00
Message: <web.601bede0c0f5ba296adeaecb0@news.povray.org>
> frequently.
> Thomas
Great ! The perspective is very welcoming and background trees are quite
detailed.
Date: 4 Feb 2021 07:56:04
Message: <601beee4@news.povray.org>
> frequently.
Excellent! I very much like the feel of it.
I hope it's OK that I've borrowed your image to test an idea? Namely,
using the extended AA jitter capabilities of the povr branch for a bloom
post process feature.
It's something like what Sam Benge was playing with 6 or 7 years back -
except less "luminous" oriented. The aim is a filter to take the edge
off rendered images; Something which makes the result look less
rendered/perfect/clean.
Attached a result. I expect it can be better tuned, but I'm happy that
it looks workable on the first attempt. It is not cheap as post process
features go. Twenty minutes or so on my two core i3(1). As currently
implemented it's a two stage, nine render total process. All POV-Ray
(povr).
Bill P.
(1) The sampling could be done against the original scene - but that's
more expensive. However, it would be an approach more true at the edges
of the image.
Download 'bigjitterbloompost.jpg' (195 KB)
Preview of image 'bigjitterbloompost.jpg'
Date: 4 Feb 2021 08:10:00
Message: <web.601bf142c0f5ba296adeaecb0@news.povray.org>
> > frequently.
> (povr).
> Bill P.
> of the image.
A bloom can be useful. What's nice is that there is no artefact, but currently
everything is blurred. Could there be some contrast or value threshold to make
it  less destructive?
Date: 4 Feb 2021 09:35:07
Message: <web.601c05edc0f5ba2987570eab0@news.povray.org>
> frequently.
Wow, this is really impressive Thomas, nicely done sir! Nice lighting, it's such
a pleasing composition and mood. And I see the cat made it into the shot :)
Cheers,
Rob
Date: 4 Feb 2021 13:02:30
Message: <601c36b6$1@news.povray.org>
This initial implementation blooms into everything - so it's going to
blur to some degree, if you use the filter. You can lesson the bloom
strength - make things sharper, but then the bloom effect itself fades.
An enhancement that could be tried I suppose, would be to leave "dark"
to some criterea regions untouched. Not sure how "natural" it would
look. More complicated things always possible - but then it might be
rendering large and scaling down say is a better way to go. At some
point if you don't want a bloom filter, you are into something else.
On the time to run this filer... I remembered after posting I was using
a development, '-O optimization only', build. It'll be faster with a
normal performance compile/link - but still expensive.
Bill P.
Date: 4 Feb 2021 16:55:00
Message: <web.601c6ccdc0f5ba2974b337b70@news.povray.org>
> frequently.
> Thomas
Well done, Thomas.
You were really inspired here!
I wouldn't mind living there.
Ton
Date: 5 Feb 2021 02:28:54
Message: <601cf3b6$1@news.povray.org>
Op 04/02/2021 om 13:56 schreef William F Pokorny:
>> tool in Poseray (thatched roofs). Those will be tools I shall come
>> back too frequently.
Thanks!
You are welcome; be my guest.
Ah, yes! Luminous bloom! Something I have long intended to use indeed
> (povr).
Not (yet) convinced. Like Mr says, looks to much like blur here and
I have the intention to do also a stochastic render of the scene. I
/think/ that would give a better result. It probably will take some
extra render time; the present render already took about 12 hours,
especially the upper half of the image obviously because of the trees.
> Bill P.
> of the image.
