POV-Ray : Newsgroups : povray.binaries.images : Into the Wild Server Time
17 May 2024 16:56:52 EDT (-0400)
  Into the Wild (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Into the Wild
Date: 13 Aug 2020 02:31:39
Message: <5f34de4b$1@news.povray.org>
Op 12/08/2020 om 09:39 schreef Ton:
> What you could try to do is render the whole scene non-stop with +ec0.25, so it
> doesn't take so long, and see whether that difference still shows up. That way
> you are sure it is the +c.
Yes, I was going to do that indeed. See also my answer to Bill.
Date: 13 Aug 2020 03:59:12
Message: <5f34f2d0@news.povray.org>
This is the other issue I mentioned above. Here the isosurface simulates
vegetation. At the bars'levels, I stopped the render and restarted with
+c. A boundary is visible from the exact point of start onwards.
No media used here; just the isosurface.
The green image with a complex slope texture.
The grey image with a simple pigment. I restarted three times there too;
can you see them? ;-)
Download 'continueissue.jpg' (87 KB) Download 'continueissue_grey.jpg' (62 KB)
Preview of image 'continueissue.jpg'
Preview of image 'continueissue_grey.jpg'
Date: 13 Aug 2020 07:47:32
Message: <5f352854$1@news.povray.org>
I do indeed. Aside from the continuity on continuations issue those
results look pretty good for quick vegetation, frosted vegetation. :-)
I await the test scene.
Bill P.
Date: 14 Aug 2020 02:20:24
Message: <5f362d28$1@news.povray.org>
Op 13/08/2020 om 13:47 schreef William F Pokorny:
>> simulates vegetation. At the bars'levels, I stopped the render and
>> restarted with +c. A boundary is visible from the exact point of start
>> onwards.
>> too; can you see them? ;-)
My original image seems to be definitely due to an uncontrolled change
to the code by me. I was misled by this present issue apparently.
Yes, this makes up for an interesting vegetation indeed. However, it is
not fast of course.
Posted the scene in p.t.scene-files.
Date: 14 Aug 2020 07:34:41
Message: <5f3676d1$1@news.povray.org>
> not fast of course.
Thank you.
Is it easy to post one or both of the simpler isosurface fuzzy
vegetation scenes too. I was thinking I would start there over the
complete scene.
Trying your scene currently in v3.8 master and the first thing I notice
is the radiosity blocks on continuation appear to be generated just
short, below the position where the render re-starts. Do you see
something similar?
Aside: Suppose I would have expected those looking to continue renders
to save radiosity results (photon results) to a file? Maybe I'm not
running the right flags with your scene. I didn't look at it that
closely as yet...
See the scene is using f_bicorn() which I dumped from povr so I have
that too in the way of a quick 'is it the shadow cache bugs.' More if/as
I figure more out.
Bill P.
Date: 14 Aug 2020 07:48:20
Message: <5f367a04$1@news.povray.org>
Ignore this bit. Just clicked this is me running my development povr2
and not a correctly configured povr. I was picking up the wrong
functions.inc which has f_bicorn in it.
Bill P.
Date: 14 Aug 2020 09:18:17
Message: <5f368f19$1@news.povray.org>
> complete scene.
Hold off. I now have something simpler running in povr showing
differences on continuations, but seeing other issues too. Perhaps
jitter related. Need to sort it out, but but render turns fast so
hopefully can get to some better understanding.
Bill P.
Date: 14 Aug 2020 10:16:35
Message: <5f369cc3$1@news.povray.org>
OK. You found a continuation bug with radiosity (non saved).
Using my current povr and after turning jitter off somewhat easy to see
you can use continuation when using just lights, but not with radiosity.
The top row in the attached image is a foliage like isosurface sphere
which matches perfectly up to the first continuation. I stopped and
restarted roughly every render block row. I used a multiplier of 15 for
the isosurface image differences.
In the second row of the image I used a regular sphere, but used a
multiplier of 60 for the image differences. The issue is there with all
shapes, it's just harder to see on something like a sphere.
If I get fired up maybe I'll try saving radiosity samples (couldn't get
it to work trying quickly...). An outside chance that might fix it, but
given the circular patterns we see on the sphere, I suspect there is
some sort of offset in the sampling pattern on continuation. A bug no
matter saved samples or not - good find.
Bill P.
Download 'continuestory.jpg' (279 KB)
Preview of image 'continuestory.jpg'
Date: 15 Aug 2020 02:20:02
Message: <5f377e92@news.povray.org>
Op 14/08/2020 om 13:34 schreef William F Pokorny:
> complete scene.
Late but sorry, I should have been more explicit. Both isosurfaces
Isoveg and Isorock are there at the bottom of the scene; just
comment/uncomment the one you need.
> something similar?
Yes, but I assume that depends on the pretrace_end size. Change that to,
e.g. 0.004, and the gap is much smaller, controlled by that size value.
> closely as yet...
Well, I never save radiosity data (in contrast to photon data of course)
so I would not know.
> I figure more out.
> Bill P.
Date: 15 Aug 2020 02:22:32
Message: <5f377f28$1@news.povray.org>
Op 14/08/2020 om 16:16 schreef William F Pokorny:
Right! I shall try on my side to see if there is a difference when
radiosity data is saved in the scene.
