Op 15/08/2020 om 08:22 schreef Thomas de Groot:
> Right! I shall try on my side to see if there is a difference when
> radiosity data is saved in the scene.
Did a test: not better, maybe even worse!
Download 'continueissue_grey_2.jpg' (24 KB)
Preview of image 'continueissue_grey_2.jpg'
Op 15/08/2020 om 08:51 schreef Thomas de Groot:
Question: /where/ is the radiosity data file saved??? I am unable to
find it anywhere...
I assumed it was into the same folder as the scene.
Op 15/08/2020 om 09:09 schreef Thomas de Groot:
> find it anywhere...
Well... Not sure what happens but somehow /reading/ (+RFI) makes the
render to fail when restarting. I do not completely understand the use
of RF from the explanation in the wiki.
I tested this time in version 3.7.1 with identical results as 3.8.
>> find it anywhere...
Thanks for digging. Remembering now something like radiosity's save and
load got moved to flag/ini control (v3.7 to v3.8 ?) while the photon
load and save did not.
Aside: I got no errors (or saved radiosity file) using save_file,
load_file in the radiosity block which, in the moment, allowed me to
think the changes and state were the other way around.
Aside 2: There is the +hr and vain pretrace radiosity stuff too. For
exact image compares when running radiosity I've always had to drop back
to one thread.
I'm not a big radiosity user, but I'll play a little with the flags
while my coffee brews and post if I figure more out.
Bill P.
OK. I found to create/save radiosity results I had to use "+rfRad.sav
+rfo". To use the samples I had to use "+rfRad.sav +rfi".
Further, as shown in the top row of the attached image the "+rfRad.sav
+rfo" result on the left is not identical to the "+rfRad.sav +rfi"
results in the middle. Any two +rfo, +rfi renders are identical.
The perhaps helpful news, when comparing a complete "+rfRad.sav +rfi"
render on the left bottom to one which had be stopped and continued
every two render block rows in the bottom middle, the results are
closer. The issue is still there, but the effect is not as pronounced.
This is with your radiosity block - always sample is off. It looks as if
even loading radiosity samples some radiosity calculation / smaller
number of rays are shot. Didn't explore whether there was some way to
better suppress some/all of these and so get a closer match on continuation.
If you're using radiosity and think you might stop and start your
render, using save radiosity samples is for that render is better, but
not a complete fix/workaround.
Bill P.
Download 'continueradsavbetter.jpg' (389 KB)
Preview of image 'continueradsavbetter.jpg'
Op 15/08/2020 om 13:02 schreef William F Pokorny:
Ah! So it is the .sav extension that is mandatory. I used .inc but that
did not work apparently. The wiki is silent about this and I think it
should be mentioned there and wherever the .sav is needed. The use of
+rfo and +rf1 in this context also needs some more explanation.
OK. Having done a bit of experimentation of my own now, I see that using
"+rfRad.sav +rfo" for the first run, and then "+rfRad.sav +rfo +rfi" for
all continuations, results in a - visually - seamless render (see
attachment where I continued several times randomly). VERY good indeed!
Thanks Bill, for this insight.
> continuation.
Indeed, but as I said above, visually, the render /looks/ faultless and
this is a workable solution.
Thanks again indeed for your help, Bill. I am glad we brought this
little bug to light.
Download 'continueissue_grey_3.jpg' (55 KB)
Preview of image 'continueissue_grey_3.jpg'
And so we reach the final scene.
The two isosurfaces (see p.t.scene-files) are superposed.
Download 'into the wild_final2.png' (887 KB)
Preview of image 'into the wild_final2.png'
Thomas de Groot wrote on 02/09/2020 08:31:
Really a great image!
Paolo
That looks really good. I certainly like the 'fuzzy vegetation' effect; well
done! And thanks for posting the code.
Op 02/09/2020 om 20:08 schreef Kenneth:
Thanks indeed, Paolo and Kenneth.
The fuzzy vegetation code was a chance hit :-) and it is as fast (or as
slow) to render as the rocky part. Overall, while I like isosurfaces to
build landscapes, I am reluctant to use them because of their slow
render speed, although I do not complain for this particular one. But if
you want to complete the landscapes with vegetation, dwellings, roads
and such, the testing time becomes prohibitive indeed.
