POV-Ray : Newsgroups : povray.binaries.images : POVghanistan/POVEarth: now with Melody's smooth triangles macros! Server Time
18 Dec 2025 04:05:56 EST (-0500)
  POVghanistan/POVEarth: now with Melody's smooth triangles macros! (Message 1 to 10 of 12)
Subject: POVghanistan/POVEarth: now with Melody's smooth triangles macros!
Date: 6 Dec 2019 13:26:57
Message: <5dea9d71$1@news.povray.org>
Hi(gh)!
I succeeded in implementing Melody's macros to my POVEarth/POVghanistan
script, so I can provide you with a first test rendering... but as
generating smooth triangles and consecutively entire mesh2 objects
entirely with POV-Ray SDL is abysmally sloooooooooow, I had to scale the
altitude data resolution from originally 3600 by 3600 down to 100 by 100
measuring points - and even this took 37 minutes. Generating the mesh2
in the original resolution would take a whopping 33.3 days!
This has to be accelerated, of course - and I'll do this by converting
both Melody's code for generating the normals and my code for generating
the mesh2 object to C or C++. When this works, I'll start generating
pre-calculated mesh2s from ASTER ASCII data tiles for the whole land
surface of Earth and provide them for download on my webspace! So
finally after 14 years (remember my posting from September 11, 2005?),
the POVEarth project starts to gain momentum...
See you in Khyberspace!
Yadgar
Download '2019-12-06 povghanistan test render, 100x100 matrix.jpg' (28 KB)
Preview of image '2019-12-06 povghanistan test render, 100x100 matrix.jpg'
Subject: Re: POVghanistan/POVEarth: now with Melody's smooth triangles macros!
Date: 6 Dec 2019 16:15:00
Message: <web.5deac3c234e1c5cf9da690110@news.povray.org>
=?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> Hi(gh)!
> Yadgar
ay cool. and learned something. I suspected like a billion points or something
... heh 33.days.
Hawaii was only 14 height_fields, setup internally took 10 secs.
14 1201x1201 tga images -
found DEMs of the world abysmally lacking, when supposedly we have 3.4 meters
data ... now that has to be ... ever calculate it? a lot of data!
I saw compiled .hgt files,  it seems the DEM project is outdated, but still
lives.
https://gis.stackexchange.com/questions/43743/extracting-elevation-from-hgt-file
yes,
loops in script too slow? compile with code::blocks.
Date: 6 Dec 2019 16:55:01
Message: <web.5deacd6034e1c5cf9da690110@news.povray.org>
"big-endian" order with the most significant byte first, directly readable by
systems such as Sun SPARC, Silicon Graphics and Macintosh computers using
PowerPC processors. DEC Alpha, most PCs and Macintosh computers built after 2006
use Intel ("little-endian")
that was the deal it seemed ... when I made mozart.wav files from sheet music
integers. never understood it, used endian code prewritten, but did 4
variations.
byte-swapping, argh.
does anyone grok that stuff?
Date: 6 Dec 2019 17:25:01
Message: <web.5dead4a534e1c5cf9da690110@news.povray.org>
"Melody" <nomail@nomail> wrote:
> "big-endian"  / Intel ("little-endian")
I still have the wavform maker,
u can listen to computer generated Mozart while trying to grok byte swapping
code. another code::blocks project I did.
Date: 6 Dec 2019 17:37:21
Message: <5dead821@news.povray.org>
Hi(gh)!
> ... heh 33.days.
I think pre-calculating the mesh2 using C++ will speed things up at
least three orders of magnitude!
> lives.
I have the whole ASTER elevation data set (3601 by 3601 measuring points
per square degree!) locally on my external hard disk... and if I get the
C++ solution running, I'll start uploading pre-calculated mesh2s
generated from the original ASCII tiles for each data tile onto my webspace!
> yes,
Compiling? A POV-Ray script? Please explain...
Yadgar
Date: 6 Dec 2019 18:05:00
Message: <web.5deadd8034e1c5cffeeb22ff0@news.povray.org>
hi,
> "big-endian" order with the most significant byte first, ...
(hoping that's not a rhetorical question.  :-))
I like the library to "do stuff", so use 'htonl()' etc whenever possible.  see
man section 3.
regards, jr.
Date: 6 Dec 2019 19:15:00
Message: <web.5deaeeb534e1c5cf9da690110@news.povray.org>
> Yadgar
I mean - for instance, compile the logic of conversion,
data to tga, a means povray can accept quickly as a height_field.
Another way to get .hgt data, (had to translate)
http://webglbasic.com/index.php/hgt-konverter
"It can then be converted to HTML, OBJ, or PLANE based on color and height."
then of course, if you have .obj file,
use poseray to make a POV model for you.
Date: 6 Dec 2019 19:35:00
Message: <web.5deaf28734e1c5cf9da690110@news.povray.org>
> man section 3.
> regards, jr.
 htonl() and ntohl()
found it thanx
Date: 8 Dec 2019 18:10:00
Message: <web.5ded82c434e1c5cf4eec112d0@news.povray.org>
> per square degree!)
I'm thinking that there ought to be a way to compress a lot of that in order to
save space and possibly make render time faster as well.
I mean, just consider a case where an entire tile was dead flat.  You could
render that with
plane {}, 2 triangle {}s, or a box {}
Scroll down to "Data Compression" to see what I mean, more generally.
http://www.ams.org/publicoutreach/feature-column/fcarc-svd
Maybe just make sure that the elevation data is saved in a compressed image
format like jpg or something that simple...
I mean, especially if certain areas are shifting sand, or you can get away with
a more generic representation of certain mountains, etc.
(I wonder if a DEM tile could be Fourier transformed, and then the results used
to mathematically create an internal image on the fly, or make a grid of Bezier
patches using the Fourier data for the Bernstein polynomial coefficients....)
Date: 9 Dec 2019 02:15:01
Message: <web.5dedf37434e1c5cf9da690110@news.povray.org>
> > per square degree!)
according to DEMPOV Hawaii is 1201x1201 per degree,
spatialResolution 3 3 1 is still 90 meters res, it seems. and u have 30 meters.
so what file format is 3601? hgt?
see just need to write it,
your format to pov mesh2 with normals and to image.
and compile it.
send me a sample. heh
