POV-Ray : Newsgroups : povray.binaries.images : Blast from the Past: Realistic Fire in POV-Ray 3.1 (originally by Heiko Rappich on 1998-10-21) Server Time
18 Dec 2025 14:59:08 EST (-0500)
  Blast from the Past: Realistic Fire in POV-Ray 3.1 (originally by Heiko Rappich on 1998-10-21) (Message 1 to 10 of 10)
Subject: Blast from the Past: Realistic Fire in POV-Ray 3.1 (originally by Heiko Rappich on 1998-10-21)
Date: 11 May 2019 20:21:51
Message: <5cd7671f@news.povray.org>
Hi(gh)!
And once more digging in the history of POV-Ray... and perhaps finding
something to adopt for own projects.
Heiko Rappich asked on 1998-10-21 how to create realistic flames with
POV-Ray 3.1 - he previously used the "halo" feature of 3.02 and wondered
why the media looks so transparent (first and second images attached here).
(and I wonder why the rendering in 3.1 looks so much darker and grainier
than the one done with 3.7... and how abysmally slow my old laptop is
compared to my hexacore main computer!)
The original thread can be found here:
http://news.povray.org/povray.binaries.scene-files/thread/%3C362E409A.6AEB3235%40t-online.de%3E/?ttop=426795&toff=1431
Then three fellow POVers came upw with suggestions, first Ken Tyler:
"Lower filter value of pigment" (third image attached)
Hendrik Knaepen (a relative of Zeger Knaepen?): "increase emission from
0.68 to 5" (fourth image attached).
Finally, Bob Hughes (yes, he already was around back then!): "adapt
emission color to flame color, replace spherical with onion media
pattern and decrease turbulence" (fifth image attached).
I rendered all "suggestion versions" with 3.1 on my laptop (did not try
them in 3.7 yet) - to me, Hendrik Knaepen's suggestion looks most
promising, I would lower the emission value to something like 3... what
do you think?
See you in Khyberspace!
Yadgar
Now playing: Action (Streetheart)
Download '1998-10-21 fire problem with pov-ray 3.1 (heiko.rappich) [rendered on 2019-05-12 by yadgar using pov-ray 3.1].png' (512 KB) Download '1998-10-21 fire problem with pov-ray 3.1 (heiko.rappich) [rendered by yadgar on 2019-05-12 using pov-ray 3.7].png' (247 KB) Download '2019-05-12 heiko rappich's fire problem with pov-ray 3.1, using ken tyler's suggestion (yadgar).png' (439 KB) Download '2019-05-12 heiko rappich's fire problem with pov-ray 3.1, using hendrik knaepen's suggestion (yadgar).png' (407 KB) Download '2019-05-12 heiko rappich's fire problem with pov-ray 3.1, using bob hughes' suggestions (yadgar).png' (314 KB)
Preview of image '1998-10-21 fire problem with pov-ray 3.1 (heiko.rappich) [rendered on 2019-05-12 by yadgar using pov-ray 3.1].png'
Preview of image '1998-10-21 fire problem with pov-ray 3.1 (heiko.rappich) [rendered by yadgar on 2019-05-12 using pov-ray 3.7].png'
Preview of image '2019-05-12 heiko rappich's fire problem with pov-ray 3.1, using ken tyler's suggestion (yadgar).png'
Preview of image '2019-05-12 heiko rappich's fire problem with pov-ray 3.1, using hendrik knaepen's suggestion (yadgar).png'
Preview of image '2019-05-12 heiko rappich's fire problem with pov-ray 3.1, using bob hughes' suggestions (yadgar).png'
Subject: Re: Blast from the Past: Realistic Fire in POV-Ray 3.1 (originally byHeiko Rappich on 1998-10-21)
Date: 12 May 2019 02:56:58
Message: <5cd7c3ba@news.povray.org>
On 12-5-2019 2:23, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> do you think?
I agree. To make the container less visible, I should also do something
to the density. Concentrate the fire towards the centre and dim it
towards the rim, using a spherical density map.
Date: 12 May 2019 03:40:02
Message: <5cd7cdd2$1@news.povray.org>
He's my brother, but I'm quite sure he never posted here. Must have been
me using his computer :)
Subject: Re: Blast from the Past: Realistic Fire in POV-Ray 3.1 (originallybyHeiko Rappich on 1998-10-21)
Date: 12 May 2019 03:43:55
Message: <5cd7cebb$1@news.povray.org>
>> from 0.68 to 5" (fourth image attached).
Also: don't use fully saturated colors for these very bright things,
like fire. So no rgb <1,.5,0> but rather rgb <1,.5,.01>
Subject: Re: Blast from the Past: Realistic Fire in POV-Ray 3.1 (originally by Heiko= Rappich on 1998-10-21)
Date: 12 May 2019 04:05:00
Message: <web.5cd7d2c66b0d398b3c1c78400@news.povray.org>
=?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> Hi(gh)!
> do you think?
> Yadgar
Hello,
obviously we've similar "projects", here is, what I did with this source.
First I assume, it's darker because of the old standard assumed_gamma 2.2.
The source doesn't make problems with 3.7 IIRC.
I changed a bit of the media code -
media {
        emission <1,0.8,0.3>*2.3
        intervals 1
        samples 50
        confidence 0.999
        variance 0.001
        density {
                spherical
                ramp_wave
                color_map {
                        [0      srgb <0,0,0>]
                        [0.2    srgb <1,0,0>]
                        [1      srgb <1,1,0>]
                turbulence 1.9
                frequency 2
                scale 3 warp {turbulence <1,8,1>} scale 1/3
                scale 0.7
Norbert
Download 'fire problem with pov-ray 3.1.jpg' (649 KB)
Preview of image 'fire problem with pov-ray 3.1.jpg'
Subject: Re: Blast from the Past: Realistic Fire in POV-Ray 3.1(originallybyHeiko Rappich on 1998-10-21)
Date: 13 May 2019 20:00:46
Message: <5cda052e$1@news.povray.org>
Hi(gh)!
You probably meant something like rgb <0.75, 0.5, 0.25>, as rgb <1, 0.5,
0.01> would not yield any significant reduction in saturation...
Yadgar
Now playing: Synthesist (Harald Großkopf)
Subject: Re: Blast from the Past: Realistic Fire in POV-Ray3.1(originallybyHeiko Rappich on 1998-10-21)
Date: 14 May 2019 10:40:16
Message: <5cdad350@news.povray.org>
that's a bit too little saturation I think, but you're correct,
<1,.5,.01> is still way too saturated. <1,.125,.06> looks a lot better imho.
I seem to remember I once made a kelvin-to-rgb converter, in javascript.
Can't seem to find it though, but a quick google gave me this:
http://www.tannerhelland.com/4435/convert-temperature-rgb-algorithm-code/
Download 'mediacolortest_yours.jpg' (37 KB) Download 'mediacolortest_mine.jpg' (42 KB) Download 'mediacolortest_better_imho.jpg' (45 KB)
Preview of image 'mediacolortest_yours.jpg'
Preview of image 'mediacolortest_mine.jpg'
Preview of image 'mediacolortest_better_imho.jpg'
Subject: Re: Blast from the Past: Realistic Fire in POV-Ray3.1(originallybyHeiko Rap=
Date: 14 May 2019 11:50:00
Message: <web.5cdae333b8ddb88393ab27150@news.povray.org>
Lightsys IV has kelvin-to-RGB conversion using POV SDL.  The relevant include
file is CIE.inc.
  http://www.ignorancia.org/index.php/technical/lightsys/
Subject: Re: Blast from the Past: Realistic Fire inPOV-Ray3.1(originallybyHeiko Rappich on 1998-10-21)
Date: 15 May 2019 02:59:01
Message: <5cdbb8b5@news.povray.org>
>> 0.5, 0.01> would not yield any significant reduction in saturation...
> imho.
I prefer the "original" (?) emission value of <1, 0.8, 0.3>*2.3. Note
however, that I used POV-version 3.8 for my image.
I guess that the background influences the look. Yours are all with a
black, featureless, background.
Download 'hr_fire.png' (267 KB)
Preview of image 'hr_fire.png'
Subject: Re: Blast from the Past: Realistic Fire inPOV-Ray3.1(originallybyHeiko Rapp=
Date: 15 May 2019 11:35:01
Message: <web.5cdc310f73cfe1493c1c78400@news.povray.org>
> Thomas
Hi Thomas,
the emission value is made of the suggestions in the old thread.
Original emission value is 0.62.
Norbert
