POV-Ray : Newsgroups : povray.binaries.images : Steam Fog: First WIP Server Time
30 Apr 2024 02:01:06 EDT (-0400)
  Steam Fog: First WIP (Message 11 to 20 of 57)
Subject: Re: Steam Fog: First WIP
Date: 25 Feb 2019 16:55:01
Message: <web.5c74640268f7cc2a765e06870@news.povray.org>
MichaelJF <mi-### [at] t-onlinede> wrote:
> Rendering time was a little bit longer (3 weeks).
Eek.
What's the black circle in the lower left part of the render?
This is a great rising steam / mist effect  :)   You should do a mug of hot
coffee or something as a smaller test render.  :D
I see where you're going with the blurred background - but it looks... flat.
I'm not sure if adding a wee bit of emission to it would help, or switching the
palette from rgb to srgb, or changing the gamma would help...
But for a test render, 1. you have the patience of a saint and 2. it's looking
really good
Date: 25 Feb 2019 23:15:01
Message: <web.5c74bce568f7cc2a218a64860@news.povray.org>
> Am 25.02.2019 um 12:15 schrieb And:
> >> Hi to the crowd,
> >> this image has still a lot of flaws (sun colour and reflections, the
> >> swan model itself, textures of the cattails) and may be limitations to
> >> media by POV. media seems to be handling color_maps or density_maps
> >> different than pigment or texture having no interpolation between the
> >> map entries but shap edges. This is what I derived in a first attempt.
> >> Best regards
> >> Michael
> > Your light source don't look like from your sun
> Hi And,
> thanks. I was not clear enough. This is the first flaw I mentioned. To
> be exact: sun colour and the colour of the emitting media doesn't match
> so far. More or less, in this WIP the sun is just a dummy to hint at my
> final intention.
> Best regards
> Michael
Uh huh, do you know how I'm aware of the problem? Because the tree is not with
its back to the light.
Date: 26 Feb 2019 05:15:36
Message: <5c7511c8@news.povray.org>
On 24-2-2019 20:20, MichaelJF wrote:
> Hi Thomas,
> this time a didn't click accidentally into the image while converting it
> to jpg with the GIMP, but with purpose. In the marked area you can see
> the sharp edges I mean. The code was
> #if(SteamFog)
>     #declare DensBoden1= density {
>        agate
>        agate_turb 1
>        density_map {
>           [ 0 rgb <1,1,1>/5 ]
>           //[ 0.02 rgb <1,1,1> ]
>           [ 0.03 rgb <0,0,0> ]
>           [ 1 rgb <0,0,0> ]
>     #declare DensBoden3= density {
>        agate
>        agate_turb 1
>        density_map {
>           [ 0 rgb <1,1,1>/5 ]
>           [ 0.02 rgb <0,0,0> ]
>           [ 1 rgb <0,0,0> ]
>        scale <5,50,5>
>        //warp { turbulence <0.5,0.1,0.5> }
>        //rotate <0,90,0>
>     #declare DensLuft = density {
>        rgb <0,0,0>
>     box { <-150,0.001,-15>,<150.01,1,150> pigment { rgbt 1 } hollow
>        interior {
>           media {
>              scattering { 2, White/5 }
>              //absorption <0,0.25,1>
>              //intervals 25
>              samples 64
>              density {
>                 gradient y
>                 density_map {
>                    [ 0 DensBoden1 ]
>                    [ 0.5 DensBoden1 ]
>                    [ 0.6 DensLuft ]
>                    [ 1 DensLuft ]
>                 scale <1,2,1> translate <0,-0.5,0> // avoid repetition
> at height 1
>                 warp { turbulence <0.01,0.4,0.01> }
>           media {
>              //intervals 25
>              samples 64
>              density {
>                 gradient y
>                 density_map {
>                    [ 0 DensBoden3 ]
>                    [ 0.5 DensBoden3 ]
>                    [ 0.6 DensLuft ]
>                    [ 1 DensLuft ]
> at height 1
>                 warp { turbulence <0.01,0.3,0.01> }
>           #if(GlobalFog)
>              media { scattering {2, White/5 } density { rgb 0.001 } }
>           #end
>     #if(GlobalFog)
>        box { <-100,1.001,-5.9>,<100,25,130> pigment { rgbt 1} hollow
>           interior {
>              media { scattering {2, White/5 } density { rgb 0.0001 } }
>     #end
> #end
> GlobalFog was activated. May be I have overlooked some thing or the other.
My first tests of your code confirms me that the sharp edge is the
result of the container boundary, not of any different behaviour of density.
I want to test different options yet.
Date: 26 Feb 2019 13:12:31
Message: <5c75818f$1@news.povray.org>
Am 26.02.2019 um 05:13 schrieb And:
>>>> Hi to the crowd,
>>>> Best regards
>>>> Michael
>> Hi And,
>> final intention.
>> Best regards
>> Michael
Hi And,
there are only two light_sources within the scene. The emitting media
representing the sun and a second miles behind it, but in the same
direction (in front of the camera). The backside illumination of the
trees comes from the reflections of the overall present scattering media
and the use of radiosity.
Best regards
Michael
Date: 26 Feb 2019 13:22:32
Message: <5c7583e8$1@news.povray.org>
Am 25.02.2019 um 22:54 schrieb Bald Eagle:
> Eek.
> really good
Thanks Bald Eagle,
the black spot is an accident while convertig the image to jpg with the
GIMP. I accidentally clicked into the image with an active pen and
noticed it after the posting.
I will look at my mug tomorrow, but I think it is a steam different to
the one I observed at the moselle last may completely. Anyway, this
would not solve the issue with the rendering time, because the media
will scale with the scene.
Best regards
Michael
Date: 26 Feb 2019 13:35:00
Message: <web.5c7585d068f7cc2abcd610c90@news.povray.org>
hi,
> Hi to the crowd,
as has been said already, that is _some_ image in the making.  (almost expected
a mansion at the end of the "boating lake" :-)).
agree that the (sun) colour isn't quite right, too .. vibrant, the overall
"feel" is too warm to expect to see vapour rising into cool/colder air.  also,
still just IMO, the sun is a touch high.
regards, jr.
Date: 26 Feb 2019 13:48:41
Message: <5c758a09$1@news.povray.org>
Am 26.02.2019 um 11:15 schrieb Thomas de Groot:
>> Hi Thomas,
>> it to jpg with the GIMP, but with purpose. In the marked area you can
>> see the sharp edges I mean. The code was
>> #if(SteamFog)
>>        agate
>>        agate_turb 1
>>        density_map {
>>           [ 0 rgb <1,1,1>/5 ]
>>           [ 1 rgb <0,0,0> ]
>>        agate
>>        agate_turb 1
>>        density_map {
>>           [ 0 rgb <1,1,1>/5 ]
>>           [ 1 rgb <0,0,0> ]
>>        scale <5,50,5>
>>        //rotate <0,90,0>
>>        rgb <0,0,0>
>>        interior {
>>           media {
>>              //intervals 25
>>              samples 64
>>              density {
>>                 gradient y
>>                 density_map {
>>                    [ 0 DensBoden1 ]
>>                    [ 0.5 DensBoden1 ]
>>                    [ 0.6 DensLuft ]
>>                    [ 1 DensLuft ]
repetition
>> at height 1
>>           media {
>>              //intervals 25
>>              samples 64
>>              density {
>>                 gradient y
>>                 density_map {
>>                    [ 0 DensBoden3 ]
>>                    [ 0.5 DensBoden3 ]
>>                    [ 0.6 DensLuft ]
>>                    [ 1 DensLuft ]
repetition
>> at height 1
>>           #if(GlobalFog)
>>           #end
>>     #if(GlobalFog)
>>           interior {
>>     #end
>> #end
>> other.
> density.
Hm,
the problem seems to be within the second media statement (the first
produces some ground noise only). The container boundary is at level y=1
(y is up here). The transition between DensBoden3 and DensLuft(=nothing)
is between 0.5 and 0.6 scaled to 1 and 1.2 but then translated to 0.5
and 0.7 which is beneath the container boundary for sure.
Many thanks
Michael
Date: 27 Feb 2019 02:24:01
Message: <5c763b11$1@news.povray.org>
>>> Hi Thomas,
>>> #if(SteamFog)
>>>        agate
>>>        agate_turb 1
>>>        density_map {
>>>           [ 0 rgb <1,1,1>/5 ]
>>>           [ 1 rgb <0,0,0> ]
>>>        agate
>>>        agate_turb 1
>>>        density_map {
>>>           [ 0 rgb <1,1,1>/5 ]
>>>           [ 1 rgb <0,0,0> ]
>>>        scale <5,50,5>
>>>        //rotate <0,90,0>
>>>        rgb <0,0,0>
>>>        interior {
>>>           media {
>>>              //intervals 25
>>>              samples 64
>>>              density {
>>>                 gradient y
>>>                 density_map {
>>>                    [ 0 DensBoden1 ]
>>>                    [ 0.5 DensBoden1 ]
>>>                    [ 0.6 DensLuft ]
>>>                    [ 1 DensLuft ]
>>> repetition at height 1
>>>           media {
>>>              //intervals 25
>>>              samples 64
>>>              density {
>>>                 gradient y
>>>                 density_map {
>>>                    [ 0 DensBoden3 ]
>>>                    [ 0.5 DensBoden3 ]
>>>                    [ 0.6 DensLuft ]
>>>                    [ 1 DensLuft ]
>>>           #if(GlobalFog)
>>>           #end
>>>     #if(GlobalFog)
>>>           interior {
>>>     #end
>>> #end
>>> other.
>> density.
> Hm,
I have yet to test the second media I confess. ;-)
Something interesting to do [hint] is to put the density scale /after/
the warp{turbulence}. Makes things a bit complicated but worth the
experiment.
Date: 27 Feb 2019 03:10:11
Message: <5c7645e3@news.povray.org>
> Hm,
Ok. I think I got it. The solution seems to be really simple. In both
media's density maps change:
         density_map {
           [ 0 DensBoden1 ]
           [ 0.45 DensBoden1 ]  //original: 0.5
           [ 0.55 DensLuft ]    //original: 0.6
           [ 1 DensLuft ]
         density_map {
           [ 0 DensBoden3 ]
           [ 0.45 DensBoden3 ]  //original: 0.5
           [ 1 DensLuft ]
That is all. If you want to increase the diffuseness, you can always
increase the distance between the two values, e.g. 0.35 --> 0.55. But I
would advise not to go higher than approximately 0.55.
Date: 27 Feb 2019 03:55:07
Message: <5c76506b@news.povray.org>
A small test image with the corrected settings. What appears to be the
horizon is in reality the semitransparent bounding box, the camera being
situated just a tiny bit above it. The mist strands do not touch that
upper boundary but be aware that their extension upward is controlled by
the warp{turbulence} of 0.4 for the y-direction. So, it is a bit tricky
to find the correct values for the density map without the strands
piercing the container.
Samples may be a bit low as there are some artifacts visible but I
wouldn't change it as in your scene they would be hidden by the water
texture.
I have used here a somewhat denser scattering colour and also scattering
mode 5 which I often prefer, here with excentricity 0.5.
For this small scene, render time was about 30 minutes.
Download 'media mist_test.png' (245 KB)
Preview of image 'media mist_test.png'
