POV-Ray : Newsgroups : povray.binaries.images : Steam Fog: First WIP Server Time
28 Sep 2024 19:37:38 EDT (-0400)
  Steam Fog: First WIP (Message 1 to 10 of 57)
Subject: Steam Fog: First WIP
Date: 22 Feb 2019 14:04:21
Message: <5c7047b5@news.povray.org>
Hi to the crowd,
this image has still a lot of flaws (sun colour and reflections, the
swan model itself, textures of the cattails) and may be limitations to
media by POV. media seems to be handling color_maps or density_maps
different than pigment or texture having no interpolation between the
map entries but shap edges. This is what I derived in a first attempt.
Rendering time was a little bit longer (3 weeks).
Best regards
Michael
Download 'thelonelyswan.jpg' (420 KB)
Preview of image 'thelonelyswan.jpg'
Subject: Re: Steam Fog: First WIP
Date: 23 Feb 2019 02:42:24
Message: <5c70f960$1@news.povray.org>
On 22-2-2019 20:04, MichaelJF wrote:
> Hi to the crowd,
Phew... Michael! That is no easy matter to model! But you seem to be on
the right track already. Well done so far.
I do not understand your comment about the sharp edges using density
maps. In my experience they work pretty much like colour or texture
maps. May it be a question of scaling which troubles you? That is
something where density maps do differ I understand. Maybe a little
piece of code can clarify the matter. I am currently putting order in my
collection of media tests, so maybe I can help.
No kidding? 3 (three) weeks render time?! Wow!
Date: 23 Feb 2019 04:09:47
Message: <5c710ddb@news.povray.org>
Hi(gh)!
On 22.02.19 20:04, MichaelJF wrote:
> Hi to the crowd,
Just my mustard ;-):
The rising fog should be turbulated more, now it looks like small
straight columns of mist... and what about using Chris Colefax's
lensflare macro?
See you in Khyberspace!
Yadgar
Date: 24 Feb 2019 13:05:01
Message: <web.5c72dc1168f7cc2a3c1c78400@news.povray.org>
MichaelJF <mi-### [at] t-onlinede> wrote:
> Hi to the crowd,
> Best regards
> Michael
this smells like a fantastic image!
Norbert
Date: 24 Feb 2019 14:20:39
Message: <5c72ee87@news.povray.org>
Am 23.02.2019 um 08:42 schrieb Thomas de Groot:
>> Hi to the crowd,
Hi Thomas,
this time a didn't click accidentally into the image while converting it
to jpg with the GIMP, but with purpose. In the marked area you can see
the sharp edges I mean. The code was
#if(SteamFog)
    #declare DensBoden1= density {
       agate
       agate_turb 1
       density_map {
          [ 0 rgb <1,1,1>/5 ]
          //[ 0.02 rgb <1,1,1> ]
          [ 0.03 rgb <0,0,0> ]
          [ 1 rgb <0,0,0> ]
    #declare DensBoden3= density {
       agate
       agate_turb 1
       density_map {
          [ 0 rgb <1,1,1>/5 ]
          [ 0.02 rgb <0,0,0> ]
          [ 1 rgb <0,0,0> ]
       scale <5,50,5>
       //warp { turbulence <0.5,0.1,0.5> }
       //rotate <0,90,0>
    #declare DensLuft = density {
       rgb <0,0,0>
    box { <-150,0.001,-15>,<150.01,1,150> pigment { rgbt 1 } hollow
       interior {
          media {
             scattering { 2, White/5 }
             //absorption <0,0.25,1>
             //intervals 25
             samples 64
             density {
                gradient y
                density_map {
                   [ 0 DensBoden1 ]
                   [ 0.5 DensBoden1 ]
                   [ 0.6 DensLuft ]
                   [ 1 DensLuft ]
                scale <1,2,1> translate <0,-0.5,0> // avoid repetition
at height 1
                warp { turbulence <0.01,0.4,0.01> }
          media {
             //intervals 25
             samples 64
             density {
                gradient y
                density_map {
                   [ 0 DensBoden3 ]
                   [ 0.5 DensBoden3 ]
                   [ 0.6 DensLuft ]
                   [ 1 DensLuft ]
at height 1
                warp { turbulence <0.01,0.3,0.01> }
          #if(GlobalFog)
             media { scattering {2, White/5 } density { rgb 0.001 } }
    #if(GlobalFog)
       box { <-100,1.001,-5.9>,<100,25,130> pigment { rgbt 1} hollow
          interior {
             media { scattering {2, White/5 } density { rgb 0.0001 } }
GlobalFog was activated. May be I have overlooked some thing or the other.
Best regards
Michael
Download 'thelonelyswan_problemzone.jpg' (421 KB)
Preview of image 'thelonelyswan_problemzone.jpg'
Date: 24 Feb 2019 14:36:33
Message: <5c72f241$1@news.povray.org>
Am 24.02.2019 um 19:01 schrieb Norbert Kern:
>> Hi to the crowd,
>> Best regards
>> Michael
> Norbert
Many thanks Norbert,
I will work at this project further, but don't expect results soon,
since the rendering is very time consuming.
Best regards
Michael
Date: 24 Feb 2019 14:43:07
Message: <5c72f3cb$1@news.povray.org>
Am 23.02.2019 um 10:12 schrieb Jörg "Yadgar" Bleimann:
> Hi(gh)!
>> Hi to the crowd,
> lensflare macro?
> Yadgar
Hi Yagdar,
the rising turbulence is just my problem (see the code I posted some
minutes earlier). I cannot see a reason to add lens flare to the image.
Especially since we have no conversion of the lens flare macros by chris
colefax to POV 3.7. They did not work with 3.7 so far. I played around
with them to solve this issue a while ago, but failed unfortunatelly.
Best regards
Michael
Date: 25 Feb 2019 02:29:40
Message: <5c739964$1@news.povray.org>
>>> Hi to the crowd,
>>> to media by POV. media seems to be handling color_maps or
>>> density_maps different than pigment or texture having no
>>> interpolation between the map entries but shap edges. This is what I
>>> derived in a first attempt. Rendering time was a little bit longer (3
>>> weeks).
>> on the right track already. Well done so far.
>> my collection of media tests, so maybe I can help.
> Hi Thomas,
OoooK. I see it now. I shall play with your code. Maybe I get a bright
idea ;-)
Date: 25 Feb 2019 06:20:01
Message: <web.5c73ce4e68f7cc2af4e3bc70@news.povray.org>
> Hi to the crowd,
> Best regards
> Michael
Your light source don't look like from your sun
Date: 25 Feb 2019 13:45:08
Message: <5c7437b4$1@news.povray.org>
Am 25.02.2019 um 12:15 schrieb And:
>> Hi to the crowd,
>> Best regards
>> Michael
Hi And,
thanks. I was not clear enough. This is the first flaw I mentioned. To
be exact: sun colour and the colour of the emitting media doesn't match
so far. More or less, in this WIP the sun is just a dummy to hint at my
final intention.
Best regards
Michael
