POV-Ray : Newsgroups : povray.binaries.images : Apparent circular pattern of scratches Server Time
16 Aug 2025 17:28:31 EDT (-0400)
  Apparent circular pattern of scratches (Message 1 to 10 of 17)
Subject: Apparent circular pattern of scratches
Date: 25 Jan 2019 07:21:57
Message: <5c4aff65@news.povray.org>
See at same subject in povray.advanced-users.
OK. This is the best I can do presently.
Download 'circular scratches_test.png' (457 KB)
Preview of image 'circular scratches_test.png'
Subject: Re: Apparent circular pattern of scratches
Date: 25 Jan 2019 07:34:59
Message: <5c4b0273@news.povray.org>
While increasing the bump_size.
Download 'circular scratches_test.png' (719 KB)
Date: 25 Jan 2019 08:31:15
Message: <XnsA9E293B70E4FFseed7@news.povray.org>
Comming along nicely.
It still has a bit of 'leathery' quality to it, less metallic. Maybe it's
the size/width of the scratches that give that impression,
ingo
Date: 25 Jan 2019 13:30:00
Message: <web.5c4b557e5e3f4450765e06870@news.povray.org>
Which is indeed very nice.  :)
> ingo
Yes, I would say that probably the real test would be something like a
transparent piece of plastic or a dark plastic/glass, where there are in reality
a lot of scratches, but optically, only a few of these are ever really visible
at any given time - depending on the viewing angle.
So, sparser, finer scratches, and perhaps an animation where the object is
rotated a bit to see how a changing incident light angle affects the look.
Still, this has developed to a usable form for a lot of scenes in a very short
time.   Great work!   :)
Date: 25 Jan 2019 13:47:59
Message: <5c4b59df$1@news.povray.org>
Am 25.01.2019 um 19:29 schrieb Bald Eagle:
>> ingo
I think one important feature overlooked so far may be that the
scratches are presumably rough (in all directions, not only in cross
section), while the remainder of the surface is rather smooth; so you'd
either need different finish properties for the scratches (with larger
highlights), or you'd have to somehow add a bit of noise to the scratches.
Date: 26 Jan 2019 02:26:58
Message: <5c4c0bc2$1@news.povray.org>
>>> it's
>>> ingo
>> in reality
>> visible
>> object is
>> look.
Gentlemen, you are perfectly correct regarding these suggestions. We now
enter the domain of subtlety and craftiness indeed. Let's see what we
all come up with.
Date: 26 Jan 2019 03:56:25
Message: <5c4c20b9@news.povray.org>
Proof of concept using different finishes for surface and scratches.
Still in flux...
Download 'circular scratches_test.png' (506 KB)
Date: 26 Jan 2019 07:10:38
Message: <5c4c4e3e@news.povray.org>
... and fulling following "The Teachings of Clipka" (Scroll 24F, Chapter
"On Metals and their Finish").
Download 'circular scratches_test.png' (519 KB)
Date: 26 Jan 2019 08:10:48
Message: <XnsA9E3903F11149seed7@news.povray.org>
> Still in flux...
The scratches are based on the random sticks? If so, try uses extremely
stretched boxes as sticks to get a sharper 'impression'.
Maybe use a gradient 'depth map' texture on the sticks, the scratichg edge
rgb 1 and going to rgb 0 to the other edges. Vary the rgb 1 on the sharp
edge for depth variation.
Render it with orthocam and a light at the camera location.
ingo
Date: 26 Jan 2019 09:15:01
Message: <web.5c4c6ae05e3f44501fbfafc10@news.povray.org>
Hello,
here is my attempt, using a layered texture and an imagefile for the scratches
(similar to what Thomas posted here -
http://news.povray.org/povray.advanced-users/message/%3C5c4970bb%40news.povray.org%3E/#%3C5c4970bb%40news.povray.org%3E
material {
                pigment {color srgb <0.9284,0.9016,0.8678>}
  normal {
                        average
                        normal_map {
                                [1      bump_map {png "scratches"}
                                        bump_size -1
                                        bump_size -1
                                        rotate x*90
                                        bump_size -1
                                        rotate z*90
                        accuracy 0.003
                finish {
                        ambient 0
                        diffuse 0.1
                        specular 1
                        roughness 0.0003
                 phong 0.5
                        phong_size 10
                        brilliance 3
                        reflection {0.6, 1 fresnel on metallic}
                        conserve_energy
  pigment {color srgbf <0.96,0.965,0.975,0.99/0.8>*0.8}
  finish {
          ambient 0
          diffuse 0.05
          reflection {0, 1 fresnel on}
          conserve_energy
          specular albedo 0.5
                        roughness 0.001
                        brilliance 7
        interior {ior 3.64}
        scale 1
 Reorient_Trans (z, 1)
Norbert
Download 'scratch finish on metallic surfacea.jpg' (684 KB)
Preview of image 'scratch finish on metallic surfacea.jpg'
