POV-Ray : Newsgroups : povray.binaries.images : challenge: surface connecting cubic_splines Server Time
24 Jun 2026 19:54:21 EDT (-0400)
  challenge: surface connecting cubic_splines (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: challenge: surface connecting cubic_splines
Date: 11 Aug 2018 13:20:05
Message: <web.5b6f19dae21a6a89458c7afe0@news.povray.org>
"B. Gimeno" <nomail@nomail> wrote:
> Thank you both for the notes. You have shown me an unknown path for me.
>The negative part is that a part of my macro will not be limited to the generation
> of rectangular meshes.
No worries - see below:
> Tesellations of hexagonal, triangular symmetry and many
> other motifs can be chosen, which with cylinders, spheres and triangles is
> relatively easy to implement.
I just took a bicubic_patch scene I had and  "squished" it into a triangle by
multiplying each row of 4 control points by 1, then 2/3, then 1/3, then 0.
That gives me a triangle-shaped bicubic patch.
That ought to work fine - but I'm thinking that the other control points might
need to be "weighted" to offset the squeezing effect of 4 coincident control
points in the first row, and the narrowing of the patch in rows 2 and 3.
But that's a smoothing issue - build it first, then smooth it.   :)
> An old version of my macro is right now in p.b.text-files.
Yes, I finally found that - thank you!  :)
It will be interesting to look through what you've done and learn a thing or two
myself.
.... now I'm thinking about making a circular bicubic patch....   :D
Date: 11 Aug 2018 13:42:31
Message: <5b6f2007$1@news.povray.org>
IIRC Moray could make circular (cylindrical) bicubic patches.
It might be worth downloading and having a look at.
Regards
Date: 11 Aug 2018 15:45:00
Message: <web.5b6f3c14e21a6a89458c7afe0@news.povray.org>
I was speaking of circular, as in disc / disk - shaped.
I think I have Moray on my other laptop - I used it to start modeling The Secret
Passage scene.  :)
But this is what I came up with - not a perfect circle, which is why I wanted to
pursue the 3x3 patch to have more exactly-specified corner points.  Trying to
reverse-interpolate where a point will be based on the control points....
bleh.
Download 'bicubicdisc.png' (224 KB)
Preview of image 'bicubicdisc.png'
Date: 11 Aug 2018 17:04:05
Message: <5b6f4f45$1@news.povray.org>
Oops!
Discworld - Ringworld, what's the difference? :)
> Passage scene.  :)
I remember that. I liked it. :)
Not bad at all. :D
> Trying to
> bleh.
<Walks away whistling.>
Regards
Date: 11 Aug 2018 17:38:40
Message: <5b6f5760$1@news.povray.org>
>> wanted to
> Not bad at all. :D
Thoughts!
I've found that when working with bezier patches. I have to tune them by
eye.
How about bringing in the outliers in a tad through the radial?
Regards
Date: 11 Aug 2018 21:15:01
Message: <web.5b6f893ae21a6a89458c7afe0@news.povray.org>
> > Not bad at all. :D
Thanks :)  My initial guesses on how to do this turned out to be very close.
Closer than I expected.
> Thoughts!
> eye.
I used a torus to guide me, and had to introduce a number of fudge factors in my
control point matrix.  Crap that will look like heiroglyphics to me if I ever
open the file a month from now   ;)
Maybe I'll add some comments ... tomorrow.   :D
But here it is - as close as I bother making it, and the grid of control points
to show how --- uncircular, and unintuitive that is.
These Coons patches are beginning to look much more interesting...
Download 'bicubicdisc.png' (185 KB)
Date: 11 Aug 2018 21:40:01
Message: <web.5b6f8f3be21a6a89458c7afe0@news.povray.org>
Raising the internal 4 control points gives a Y-paraboloid, and then I inverted
the right two, and got this.
I kinda want to 3D print it and use it as an ice cream spoon.
Download 'bicubicdisc.png' (195 KB)
Date: 16 Aug 2018 07:03:05
Message: <5b7559e9$1@news.povray.org>
These shapes are so attractive.
I would use it as part of a wind chime, made of crystal glass.
Regards
Date: 17 Aug 2018 12:39:04
Message: <5b76fa28@news.povray.org>
Using a rational bezier patch (well, no need for the rational part here,
all the same weight everywhere)
Rendered with hgpovray38 (for the bezier patch and grid camera)
Download 'hull.pov.txt' (4 KB) Download 'hull0.png' (357 KB) Download 'hull5.png' (390 KB)
Preview of image 'hull0.png'
Preview of image 'hull5.png'
Date: 30 Aug 2018 14:22:15
Message: <5b8835d7$1@news.povray.org>
And in a country far far away, someone would have a look at
meshmaker.inc and the Coons macro !
It is there, in all its glory, just waiting to be seen.
