On 08/08/2018 22:12, Alain wrote:
> Le 18-08-07 à 11:20, Stephen a écrit :
>> Thanks Alain, I seldom use area lights and this is the first time I
>> have used adaptive.
>> When you said samples is that what the offline help names Size_1 &
>> Size_2, in the line;
>> AXIS_1_VECTOR, AXIS_2_VECTOR, Size_1, Size_2?
> Yes, Size_1 and Size_2.
> AXIS_1_VECTOR and AXIS_2_VECTOR set the extent of the area_light.
> Size_1 and Size_2 set the number of components, or samples, in the
> area_light.
> When using orient, the pairs need to be of the same size. The
> AXIS_n_VECTORs need to have the same length and be perpendicular.
> And, you need Size_1 = Size_2.
> When using adaptive, always start with adaptive 0 and only increase if
> you really need to.
Thanks for the advice Alain
Regards
On 8/8/2018 10:08 AM, Mike Horvath wrote:
> However, I had to double the height of the shadow squares in order to
> block out the sun. See the parameter `RWorld_Shadow_Square_Width`. I'm
> not sure why this was necessary, as the original height was equal to the
> sun's diameter, and should have fully blocked its light.
I am dumb. Instead of specifying the area light's axis vectors in the
form of:
x * foo, y * foo
I was instead simply using:
foo, foo
which is the same as:
<foo,foo,foo>, <foo,foo,foo>
which is too long.
I fixed that and things are fine now. Doing another really big render at
the moment. It might take over a day to render.
Mike
On 8/8/2018 5:35 PM, Stephen wrote:
> On 08/08/2018 22:02, Mike Horvath wrote:
>> On 8/8/2018 1:05 PM, Stephen wrote:
>>> On 08/08/2018 15:08, Mike Horvath wrote:
>>>> Okay, I uploaded my scene to here:
http://lib.povray.org/searchcollection/index2.php?objectName=Ringworld&version=2.0&contributorTag=SharkD
>>>> I also attached my latest render to this post. The shadow squares'
>>>> widths now match what was apparently stated in the books. The
>>>> shadowed regions on the ring look much better now.
>>>> to block out the sun. See the parameter
>>>> `RWorld_Shadow_Square_Width`. I'm not sure why this was necessary,
>>>> as the original height was equal to the sun's diameter, and should
>>> Do the two area_light vectors <Axis_1> and <Axis_2> extend beyond the
>>> star's volume?
>> 1. the axis lengths are equal to the sun's diameter
Oops! I screwed up here. See my other post. They're fixed now.
>> 2. the area light is circular and oriented
>> 3. the sun's diameter should be equal to the shadow squares' height
>> according to Niven's website
> Just a check list.
> I just noticed that the data I was looking at was from the game. Oops.
Here's a scan from the game:
https://img.fireden.net/tg/image/1464/06/1464060167901.jpg
The shadow squares seem much smaller than they should be.
>> 4. an array of point lights in the shape of a sphere does not suffer
>> from the issues I'm experiencing
> How do you do that without them clustering at the poles?
I don't. They do cluster! I should investigate a "good enough" sphere
packing formula.
>>>> Oh well.
>>> I like the image especially the shadows cast by the shadow squares in
>>> the solar wind. :)
>> Thanks!
>>> Unfortunately I don't have CIE.inc or lightsys.inc installed. :(
>> I use them in nearly everything. Not sure why. Probably just habit.
> Probably a good habit to have.
Here's a partial render.
I would like to make the edge of the sun a bit sharper, and also make
the sun smaller while keeping the haze generally the same. Here is the
sphere I use for this:
#declare RWorld_Corona_Radius = 95000*4;
#declare RWorld_Corona_Object = sphere
0, RWorld_Corona_Radius
hollow
material
texture
pigment {rgbt 1}
interior
media
scattering {1, RWorld_Light_Point_Color/2000}
density
function {1/(x*x + y*y + z*z)/RWorld_Corona_Radius}
density_map
[0.0 rgb 0]
[1.0 rgb 1]
scale RWorld_Corona_Radius
Any idea on how I can accomplish this?
Download 'sdsadasdsa.png' (273 KB)
Preview of image 'sdsadasdsa.png'
> hollow
> material
> texture
> pigment {rgbt 1}
> interior
> media
> density
> density_map
> [0.0 rgb 0]
> [1.0 rgb 1]
I would suggest to play with the settings of the density_map. Not
tested, but something like:
density_map {
[0.00 rgb 0.0]
[0.90 rgb 0.9]
[0.90 rgb 1.0]
> density_map {
> [0.00 rgb 0.0]
> [0.90 rgb 0.9]
> [0.90 rgb 1.0]
Yeah, I thought of that too, but haven't been successful.
I also tried changing the formula so that x y and z are cubed instead of
squared, but it turned the whole image black!
Meh.
Mike
On 08/08/2018 12:08, Thomas de Groot wrote:
> I often need to take stock again and again of the gigantic distances and
> sizes we are dealing with in a planetary system. It is something quite
> difficult to grasp, and rendering things like the Ringworld makes us
> forget them, reducing them to simple rings to be taken into our hands ;-)
Translating from the mind's eye to reality is always a problem with
planetary scales.
I wonder if it is possible to use a log rather than a linear scale along
the axis.
Regards
>> density_map {
>> [0.00 rgb 0.0]
>> [0.90 rgb 0.9]
>> [0.90 rgb 1.0]
> Meh.
> Mike
I tested this and it looks acceptable to me:
#local MyScale = 10;
sphere {
0, 1
hollow
texture {pigment {rgbt 1}}
interior {
media {
emission 3/MyScale
density{
spherical
density_map {
[0.10 rgb <0.0, 0, 0.0>]
[0.95 rgb <1.0, 1.0, 1.0>*0.2]
[0.95 rgb <1.0, 1.0, 1.0>]
scale MyScale
Instead of 'spherical', you may need something else more appropriate. I
have problems with the function you use for the density map.
>> and sizes we are dealing with in a planetary system. It is something
>> quite difficult to grasp, and rendering things like the Ringworld
>> makes us forget them, reducing them to simple rings to be taken into
>> our hands ;-)
> planetary scales.
Indeed. It is not just a matter of scaling up or scaling down the model.
More is involved.
> the axis.
I'll leave that to my betters, but it might be an interesting and
worthwhile experiment.
the sun smaller
Draw out the graph of the density you want, and then add those functions
together. Make use of select() if you have to.
I think there is a way to use splines in functions as well.
