![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
On 10/05/2018 06:33, Kenneth wrote:
>> which got me thinking, not hedge - building. could your system be used
>> to "drape" a suitably scaled building shaped like in the attached
>> image*? 30+ floors, ideally.
> (I had to brush-up on my miniscule knowledge of Hilbert curves!)
> Is this what you have in mind, as the general idea?
that must be some brush. :-) very cool image, in essence what I have
in mind. more below.
> This test image doesn't actually use height_fields for the vertical building
> faces; in fact, it's just a POV-Ray + Photoshop mock-up!
you use HFs to get balconies and such?
> Like you, I've been thinking about how to use my HF idea to make buildings with
> 'indented' sections. Not particularly in the shape of Hilbert curves, but the
> same general idea. *In theory*, it should be easy. The trick is to 'slice and
> dice' (and then rotate) the many vertically-oriented HF faces so that they all
> match up with no seams-- AND so that only full window sections are used. That
> particular problem is apparent in this mock-up image: some of the windows are
> cut off prematurely at the various building edges.
cannot comment really since I've no idea of details, but am curious to
learn more. can I read slicing + dicing as using a tile-based method?
> But it should be easy to do; I just haven't gotten to that stage yet. (Real life
> keeps intruding.) Even a Hilbert-curve variety looks do-able; the equations for
> that could be used in some way to do the proper slicing/dicing of the HFs.
again, curious to find out a little more about the tool(s) in use.
On 10/05/2018 07:50, Thomas de Groot wrote:
> [shudder]
> I do not want to imagine what it would be like to live in a building
> like that! ;-)
oh dear. :-)
it may get worse. the setting I have in mind is in part inspired by
your scene with the house by/in the water. ;-)
think science fiction. the building is not really that, it is the whole
city. if the grid unit is 1km and the construction is, say, 400m wide
and 1600m tall, there's enough room for everything:
fishing/shipping/light industry, public + civil service stuff, internal
transport systems, and residential. it stands just offshore, in shallow
waters.
jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, and in two different ways.
The INITIAL 1X1-unit (horizontal) height_field is made from some Photoshop
artwork-- which is derived from a building-face photo I snatched from the
internet. (LOTS of those!) The photo will generally show a good number of
windows.
That photo (and its HF derivitive) are first trimmed to be a repeating tile,
with a certain number of window units (which actually varies from photo to
photo, depending on the photo itself and on my own whim.)
The initial height_field is then repeated (or 'assembled') into a much more
expansive HF-- lots of repetitive tiles, and all still horizontal. (The actual
windows photo is then applied to this as a repeating pigment, in a likewise
way.)
This is the main HF 'template' -- which is then flipped vertically (as a
building face), then trimmed down to any particular width and height that I want
for a particular building shape. For a typical 'boxy' building, it's just a
matter of making four of those building faces and rotating/translating them
correctly-- with the caveat that the chosen face widths should not 'slice
though' any actual windows.
For a building with *indents* in the faces -- like the Hilbert example (OR
protrusions)-- the HF template needs to be 'sliced' into smaller widths for
those sections. My 'Hilbert Towers' example image looks like it would need 28(?)
different faces-- but could make use of identical repetitions to reduce that.
Well, to a limited extent. So far, I've used the HFs only to get *recessed*
windows, and also some slightly protruding shapes (like window lintels and the
occasional air-conditioner that sticks out a window.) I think actual balconies
would require a different(?) approach-- only because of the balcony railings.
They don't look right as part of the HF.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
On 10/05/2018 22:16, Kenneth wrote:
> This is the main HF 'template' ...
a lot of detail, thanks. there's one thing I'd like to clarify straight
away, before "cogitating" and reply.
suppose you had used the method described to make the HilbertTower
image, the template would be a "strip", ie the windows/facade for a
single floor, and would have been applied 20 or so times? thanks.
jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
(Sorry that I'm not responding as quickly as I'd like; not much free time
lately.)
It *could* be done that way-- floor by floor-- but the basic window photo tiles
I use are typically 3 or 4 window-units wide, and the the same in height. It
depends on the photo, or if there's some interesting subtle variation in it.
Some photos have lots more windows. But the underlying scene code does apply the
windows floor-by-floor (and in single-window widths, if that makes sense to
you.)
One small detail I left out: the horizontal rooftops. They have to be
constructed in a different way, because the final building is just a
multi-height_field 'shell' with no innards (and no top!) I haven't arrived at a
good method for that yet ;-) For a simple 4-sided 'box' building, the roof could
likewise be a thin box; but a 'Hilbert-style' building (i.e., one with indents)
would need something more complex.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> lately.)
Hi Kenneth,
jr has asked me to ask you, to drop him an email on the subject. As he
has lost access to the newsgroups.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thomas de Groot <tho### [at] degroot org> wrote:
> [shudder]
> like that! ;-)
It's a very exclusive residence: a retirement home for mathematicians :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> [shudder]
>> like that! ;-)
That would be Hilbert's hotel, then. "Always room for one more."
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> [shudder]
>>> like that! ;-)
LOL. Am I glad that I am not a mathematician ;-)
I have seen apartment buildings like that. When you live, say, on the
fifth floor and on the inner court, you live a dismal life with hardly
any daylight. :-/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Stephen <mca### [at] aol com> wrote:
> Hi Kenneth,
Just tried to contact him, but his email address is showing up here on the web
interface as
jr <cre### [at] gmailcom>
I'm seeing ### after cre and they don't work. Apparently those hash marks are
substituting for something else. :-( Maybe it's a web-interface vs. newsreader
difference?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Just ran across a very interesting video about the Hilbert Curve.
https://www.youtube.com/watch?v=3s7h2MHQtxc
This actually suggests that since a Hilbert curve is a continuous function that
can fill 2D (3d?) that it can be implemented as a pigment pattern.
Perhaps others with more free time can imagine other interesting uses. :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
