Stephen wrote on 03/05/2018 19:05:
> On 03/05/2018 16:50, jr wrote:
>> see message in p.b.utilities
> I have been playing with the spheresweep output. As I try to trace() a
> grass landscape with a path of flowers following a Hilbert Curve.
Both interesting concepts.
Paolo
I thought so. If I come up with anything I'll post an image.
Regards
This would work well with Kenneth's "sideways heightfield" city building concept
to make shrubs or a hedge maze.
And,
If there's a bustle in your hedgerow, don't be alarmed, now.
There is already an Ivy generator. But you could grow moss or lichen
over a building.
> And,
If there is. Then the bugs in my code could wear it. :)
Might even eat it. Because on several occasions they have eaten all my
RAM. :(
Which means I am restarting from step 2.
Loops, my version of the perpetual motion machine.
Regards
Still not happy with it. I'm sure there is something wrong with the
scene code. PovRay 3.7 does not release the memory. PovRay 3.8 does.
But I am moving on.
Regards
Download 'hilbertflowers_4c2a1m4_0000.png' (2338 KB)
Preview of image 'hilbertflowers_4c2a1m4_0000.png'
Am 08.05.2018 um 14:58 schrieb Stephen:
Doesn't have to be buggy scene code. POV-Ray v3.7 wasn't perfect.
POV-Ray v3.8 is...
... a bit better.
> POV-Ray v3.8 is...
Tada!
I don't read below the line. ;-)
There is something wrong with the code. There is a wayward "{" or "}"
somewhere. I have to comment a "}" out to get it working.
While I am at it and before I forget. Is there something in the Windoze
editor that gets confused when /* ... */ comments are nested?
Ctrl + ] doesn't always work as I expect.
But then that could be me. It so often is.
> .... a bit better.
Regards
Am 09.05.2018 um 14:27 schrieb Stephen:
While POV-Ray's parser allows comments to be nested, the 3rd party
editor component isn't designed to accomodate for that.
So for example,
/*a/*b*/c*/
to POV-Ray is a comment containing `a/*b*/c` (the portion `/*b*/` being
a nested comment), while to the editor it is a comment containing `a/*b`
(the `/*` being nothing special) followed by a separate `c*/` outside
the comment.
> So for example,
> /*a/*b*/c*/
> the comment.
Good, that eliminates one straw I was grasping at. :-)
Thanks for the quick reply.
Beautiful images.
Off-topic, I think the 'lemon slice' in your grenadine photo would look much
nicer if it used subsurface scattering (SSLT). That slice looks like a good
candidate for it.
