POV-Ray : Newsgroups : povray.binaries.images : Old media blob issue leading to a look at sturm / polysolve. Server Time
10 Jun 2024 07:26:17 EDT (-0400)
  Old media blob issue leading to a look at sturm / polysolve. (Message 15 to 24 of 24)
Subject: Re: Old media blob issue leading to a look at sturm / polysolve.
Date: 21 May 2018 10:39:20
Message: <5b02da18$1@news.povray.org>
On 05/20/2018 05:09 PM, clipka wrote:
> Am 20.05.2018 um 18:10 schrieb William F Pokorny:
>> My position is still the difference isn't large enough to be of concern,
>> but if so, maybe we should more strongly consider going to >0.0 or some
>> very small values for all shapes. Doing it only in blob.cpp doesn't make
>> sense to me.
> I guess the reason I changed it only for blobs was because there I
> identified it as a problem - and I might not have been familiar enough
> with the shapes stuff to know that the other shapes have a similar
> mechanism.
> After all, why would one expect such a mechanism if there's the "global"
> MIN_ISECT_DEPTH?
Understand. Only recently are the root filtering and bounding mechanisms
coming into some focus for me & I'm certain I still don't understand it
all. There are too, the two, higher level bounding mechanism which are
tangled in the root/intersection handling. I'm starting to get the
brain-itch the current bounding is not always optimal for 'root finding.'
> Technically, I'm pretty sure the mechanism should be disabled for SSLT
> rays in all shapes.
OK. Agree from what I see. Work toward >0.0 I guess - though I have this
feeling there is likely an effective good performance 'limit' ahead of
 >0.0.
>> Aside: MIN_ISECT_DEPTH doesn't exist before 3.7. Is it's creation
>> related to the SSLT implementation?
> No, it was already there before I joined the team. The only relation to
> SSLT is that it gets in the way there.
> My best guess would be that someone tried to pull the DEPTH_TOLERANCE
> mechanism out of all the shapes, and stopped with the work half-finished.
> BTW, one thing that has been bugging me all along about the
> DEPTH_TOLERANCE and MIN_ISECT_DEPTH mechanisms (and other near-zero
> tests in POV-Ray) is that they're using absolute values, rather than
> adapting to the overall scale of stuff. That should be possible, right?
Sure, but... Not presently in POV-Ray is my 'anytime soon' answer. Too
many magic values or defined values like EPSILON used for differing -or
effectively differing - purposes. Remember, for example, one of the
recent changes I made to the regula-falsi method used within polysolve()
was to use universally the ray value domain instead of a mix of
polynomial values and ray values for relative & absolute error stops.
Root / intersection work is sometimes done in a normalized space(1) and
sometimes not, etc. The pool of issues, questions and possibilities in
which I'm mentally drowning is already deep - and I'm far from seeing to
the bottom. We can often scale scenes up for better result because
POV-Ray code has long been numerically biased to 0+ (1e-3 to 1e7) (2).
Near term think we should work toward something zero centered (1e-7 to
1e7).
Would like to first get to where we've got a more accurate polysolve()
against which any changes to other solvers / specialized shape solvers
can be tested. After which we can perhaps work to get all the solvers &
solver variant code buried in shape code to double / 'DBL' accuracy.
Underneath everything solver / intersection wise is double accuracy
which is only 15 decimal digits. The best double value step
(DBL_EPSILON) off 1.0 is 2.22045e-16. Plus we use fastmath which
degrades that accuracy.
Aside: I coded up a 128bit polysolve() but it was very slow (+10x) and
the compiler feature doesn't look to be supported broadly enough as a
standard to be part of POV-Ray. A near term interesting idea to me - one
Dick Balaska, I think, touched upon recently in another thread -  is
coding up a version of polysolve() we'd ship using 'long double'. Long
double is guaranteed at only 64bits (double), but in practice today
folks would mostly get 80bits over 64bits - and sometimes more. It would
need to be an option to the default 64 bit double as it would certainly
be slower - but being generally hardware backed, performance should be
<< the +10x degrade I see for 128bits on my Intel processor. Would be -
for most - an improvement to 18 decimal digits and an epsilon step of
1.0842e-19 off 1.0. Worthwhile...?
Bill P.
(1) Normalizing & the inverse, transforms & the inverse all degrade
accuracy too.
(2) From the days of single floats - where the scale up would have
worked less well at hiding numerical issues (ie coincident surface
noise) because the non-normalized / global accuracy was then something
like 6 decimal digits or 1e-3 to + 1e3.
Date: 21 May 2018 16:35:08
Message: <5b032d7c@news.povray.org>
Am 21.05.2018 um 16:39 schrieb William F Pokorny:
I think that's a path worthwhile exploring further. My suggestion would
be to use a macro - say "PRECISION_FLOAT" - to define a type to be used
in places where precision matters even more than usual, so that we can
get binaries with different performance characteristics out of the same
source code: That macro could simply be defined as `double` for the
status quo, `long double` for a portable attempt at achieving more
precision without losing too much speed, a compiler-specific type such
as `__float128` on gcc, or even a type provided by a 3rd party library
such as GMP or MPFR.
POV-Ray has never used single-precision floats. I doubt even DKBTrace
ever did: At least as of version 2.01, even on the Atari it already used
double-precision floats.
As a matter of fact, the IBM-PC configuration for DKBTrace 2.01 (*)
actually defined DBL as `long double` when a coprocessor was present.
DKBTrace 2.12 (**) additionally set EPSILON to 1.0e-15 instead of 1.0e-5
in that case (provided the compiler used wasn't Turbo-C, presumably
because it would define `long double` as 64-bit). This was carried on at
least until POV-Ray v2.2, but must have been gotten lost between v2.2
for DOS and v3.6 for Windows. (My guess would be that the Windows
version never had it.)
(* See here:
https://groups.google.com/forum/#!topic/comp.sources.amiga/icNQTp_txHE)
(** See here: http://cd.textfiles.com/somuch/smsharew/CPROG/)
Date: 21 May 2018 17:13:30
Message: <5b03367a$1@news.povray.org>
Am 21.05.2018 um 22:35 schrieb clipka:
Make that `PRECISE_FLOAT`; fits better with a series of similar types
already in use, `PreciseColourChannel`, `PreciseRGBColour` etc., which
are used for colour-ish data where `float` is not enough, most notably
the SSLT code. (Obviously, there the data type of choice is `double`,
and does suffice.)
Date: 22 May 2018 07:37:01
Message: <5b0400dd@news.povray.org>
Taking you to mean never in the 'solvers'.
> (* See here:
Thanks. I've never dug as far back. True too I was speculating about how
many might have actually been running early POV-Ray. Me taking the early
as v1.0 "#define DBL double to be a mechanism those without FPUs and
early small bus sizes were running with "define DBL float" instead. Not
that I was running POV-RAY or even aware of POV-Ray that early.
Don't remember exactly, but I didn't have a personal machine with an
actual FPU until the late 90s. First 64 bit machine early 2000s I guess.
My very first personally owned machine was an 8bit z80 based custom
built thing...
Bill P.
Date: 22 May 2018 07:45:30
Message: <5b0402da$1@news.povray.org>
> and does suffice.)
OK. Will go for PRECISE_FLOAT and plan to define it in
./base/configbase.h along with DBL and SNGL.
Further - for now - I plan to use it only in polysolve() and its
sub-functions with conversions from and to DBL on entry and exit as I
implemented the 128bit polysolve().
Bill P.
Date: 27 May 2018 12:19:14
Message: <5b0ada82@news.povray.org>
On 03/30/2018 08:21 AM, William F Pokorny wrote:
Sturm / polysove() investigation. Coefficients wrongly seen as zeroes.
In this chapter we venture up into the Solve_Polynomial() function which
calls polysove(), solve_quadratic(), solve_cubic() and solve_quartic().
Consider this code added back in 1994 and part of POV-Ray v3.0.
      * Determine the "real" order of the polynomial, i.e.
      * eliminate small leading coefficients.
     i = 0;
     while ((i < n) && (fabs(c0[i]) < SMALL_ENOUGH))
         i++;
     n -= i;
     c = &c0[i];
My last commit deletes it! Having so large a SMALL_ENOUGH (1e-10) and
any fixed value given equation order varies as does distance along the
ray where the equations not normalized is a bad idea(1).
Perhaps reason enough that when any even order polynomial with no roots
is reduced to an odd order polynomial it turns into a polynomial with
roots. All odd order polynomials have at least one root.
In the attached image we have two examples - neither using sturm /
polysolve - where the code above goes bad.
In the top row we've got the shipped primativ.pov scene and specifically
a poly shape which is not explicitly bounded. It creates 4th order
equations so should use solve_quartic(). However the code up top
sometimes strips the leading coefficient and in this case we go from a
quartic which has no roots to an odd third order cubic which has one.
This is the vertical bar artifact in the upper left.
In the bottom row we have the shipped subsurface.pov scene. The
differences on the bottom right (at 4x actual difference values) happen
again where the code at top drops a single leading coefficient. In this
case for pixels and rays where I've examine actual roots, subsurface
related rays go from 4th order equations with >=2 roots with one of
those roots inside the blob interval being kept, to a 3rd order equation
with a single root outside the active blob interval. In other words we
are missing subsurface roots/intersections where we see differences.
Notes:
- The subsurface effect here is visible with no difference multiplier
and many times larger than the returned root threshold differences
recently discussed.
- Because the ray-surface equations are based upon scene geometry the
'zeroes-not-zeroes-dropped' issue here is often scene-object or axis
aligned in some fashion. I'm reminded of a rounded box canyon subsurface
scene Robert McGregor posted where I noticed one box face having a
strange look. Someone joked it was perhaps a door to Narnia or similar
after nobody had an idea what caused the effect. I'm thinking perhaps
the code above - or the still present order reduction by ratio code -
played a part...
NOTE! This update corrupts some previous scenes while fixing some
previous bad ones. Some planned but not yet defined or implemented
equation tuning on ray DX,DY,DZ values is to come.
Updates at:
https://github.com/wfpokorny/povray/tree/fix/polynomialsolverAccuracy
Performance and specific commit details below.
Bill P.
(1) - Yes, this strongly suggests order reduction based upon the largest
two coefficients is also a bad idea. However leaving that feature in
place for now as some primitives require this type of reduction to
function at all. Perhaps in these cases push the reductions out of the
solvers and into the shape code.
Performance info:
------------ /usr/bin/time povray -j -wt1 -fn -p -d -c lemonSturm.pov
0)  master    30.22user 0.04system 0:30.89elapsed
16) 21387e2   14.88user 0.02system 0:15.51elapsed    -50.76%
17) 80860cd   --- NA --- (1e-15 constant calc fix)
(PRECISE_FLOAT)
18) aa6a0a6   --- Bad Result(a) ---                           (float)
               14.95user 0.02system 0:15.56elapsed     +0.47%  (double)
               25.12user 0.02system 0:25.73elapsed    +68.82%  (long double)
               282.97user 0.13system 4:44.13elapsed +1801.68%  (__float128)
19) 4e16623   14.94user 0.01system 0:15.56elapsed      ----   -50.56%
(a) - Not exhaustively evaluated, but some shapes render OK at 'float'
though those which did were slower (+150% ballpark). Unsure why so slow,
but don't plan to dig further. Sturm / polysolve is for those looking to
be more accurate, not less.
17) Correcting two double 1e-15 constant calculations.
In recent commits started setting two 1e-15 values with the calculation:
= 1/std::numeric_limits<DBL>::digits10;
when I meant to code:
= 1/pow(10,std::numeric_limits<DBL>::digits10);
Both forms bad practice in not being specific as to the types for the
explicit values. The first returns integer 0, later cast to double and I
got away with it in all but my full set of test cases. Corrected:
= (DBL)1.0/pow((DBL)10.0,std::numeric_limits<DBL>::digits10);
18) Implementing suggested PRECISE_FLOAT macro mechanism for polysolve().
Primarily enabling 'long double' support for the polysolve() / 'sturm'
solver given 'long double' is part of the C+11 standard and gets most
users 80 bits or more as opposed to 64. Further, the additional bits are
almost always hardware backed making for reasonable performance.
With GNU g++ 64 bit environments '__float128' is a valid setting with no
additional library required - though it's very slow. Other extended
accuracy floats such as 'double double' enabled, via the PRECISE_
mechanisms, but they involve additional libraries and settings. See code.
Note! With this update the polysolve sturm chain is no longer pruned
with a default 1e-10 value, but rather a value appropriate for the
floating point type. Means better accuracy for some previously bad root
results and less accuracy for others. Coming updates will better tune
the chain equation pruning.
19) Removing leading, near zero coefficient reduction in Solve_Polynomial().
Leading coefficients of < SMALL_ENOUGH (1e-10) were being dropped
reducing the order of the incoming polynomial when the near zero values
had meaning with respect to roots. Led to both false roots and missed roots.
Download 'notzeroesdropped.png' (326 KB)
Preview of image 'notzeroesdropped.png'
Date: 12 Jul 2018 07:34:56
Message: <5b473ce0$1@news.povray.org>
Sturm / polysove() investigation. Other solvers. Root polishing.
I've continue to look at the root solvers over the past month. At a good
place to write another post about findings and changes.
A couple preliminaries before the main topic.
First, while most results are better, the polynomialsolverAccuracy
branch still lacks planned updates. For example, scenes with lathes and
sphere_sweeps using orthographic cameras currently render with more
artifacts, not less.
Second, this set of commits updates the solve_quadratic function in a
way both more accurate and faster.
The main topic is root finding tolerance and scaling.
All the solvers find roots / surface intersections to some tolerance.
They do this in a coordinate space which has been normalized with
respect all scene transforms. Additionally, objects like blobs
internally normalized to internal 'unit' coordinate spaces.
Suppose in the solver coordinate space a ray/surface equation has a root
essentially at the ray origin - at distance 0.0 - as happens with self
shadowing rays. All solvers due their tolerances have the potential to
allow such near-zero roots to drift into the >0.0 value space as
ray-surface intersections. This numerical reality is why objects filter
roots to a minimum returned intersection depth larger than zero(1).
Further, this minimum returned intersection depth must account for the
translation of every root and its tolerance back into the original
coordinate space. A wrongly positive 1e-8 root in solver space is a much
more positive 1e-4 root after a scale up by 10000. The solvers each have
different tolerances. There are many shape custom 'solvers' in use
beyond those I've been working upon and differing internal
normalizations. Why we've got many differing returned depth values. Why
blob's have long used a minimum returned intersection depth of 1e-2
while a sphere, for example, uses 1e-6.
It's the case that even blob's large 1e-2 filtering value is inadequate
given solve_quartic()'s tolerance is relatively large. Continuing to use
Gail Shaw's blob scene from 2005 to demonstrate, the attached image was
rendered with the current 3.8 master branch without sturm - so using
solve_quartic(). The original scene render is on the left. On the right
is the same scene scaled up by 10000. The vertical bars showing up on
the right happen due slightly ~=0.0 roots drifting positive in
solve_quartic(). The wrongly positive roots are then scaled up to a
value greater than the current 1e-2 small root/intersection depth
filter. Not being filtered, the roots corrupt results.
While zero crossing roots due tolerance are the most serious tolerance
multiplied by scale issue, roots well positive can drift quite a lot too
in the global space where the scale up is large.
The improvement adopted for the solve_quartic() and polysolve()/sturm
solvers - where 'scaled tolerance' issues have been seen - was to add a
Newton-Raphson root polishing step to each. With blobs this looks to
allow a returned depth on the order of 4e-8 over 1e-2 for a 1e-7 to 1e7
global working range at DBL = 'double'.
Aside for thought: Might we be able to determine when we are evaluating
a self-shadowing or same-shape-terminating ray-surface equation? If so,
it should be we can use the knowledge we have a root 'at 0.0' to always
deflate / reduce the order of these polynomials prior to finding roots.
Updates at:
Bill P.
(1) - The idea of going as small as >0.0 in each shape's implementation
fly is not presently possible. Trying instead a new much smaller
MIN_ISECT_DEPTH_RETURNED value - see commit comments.
Performance info:
19) 4e16623   14.94user 0.01system 0:15.56elapsed   -50.56%
20) 0d66160   15.22user 0.03system 0:15.80elapsed    +1.87%
               (hilbert_curve linear sphere_sweep
                scene with new solve_quadratic())     (-7.5%)
21) 761dd0b   15.05user 0.04system 0:15.71elapsed    -1.12%
22) 552b625   (quartic polish non-sturm lemon scene) (+0.82%)
23) 63e0456   15.16user 0.02system 0:15.76elapsed    +1.20%
24) ec28851   NA Code documentation only.
25) 8962513   15.43user 0.02system 0:16.05elapsed    +1.78%  -48.94%
               (quartic polish non-sturm lemon scene) (+1.02% +2.70%)
20) New zero coefficient stripping and solve_quadratic implementation.
General effort to implement better 'effective zero' coefficient
handling. Created new POV_DBL_EPSILON macro value which is 2x the C++
standards <float type>_EPSILON value and updated PRECISE_EPSILON to be
2x the single bit epsilon as well.
Zero filtering in polysolve now looks at all polynomial coefficients and
either sets 'effective zeros' to exactly 0.0 or strips them if they are
The much more accurate near zero coefficients drove the need for a
better solve_quadratic implementation included with this commit. Note it
supports the PRECISE_FLOAT options like polysolve.
Zero filtering in solve_quadratic, solve_cubic and solve_quartic now
standardized both in implementation and use of POV_DBL_EPSILON.
21) Created new constexpr DBL variable MIN_ISECT_DEPTH_RETURNED.
Near term need to use a value not MIN_ISECT_DEPTH in blob.cpp to test
Jérôme's github pull request #358. Longer term aim is to drive all
returned intersection depths from shape code to
MIN_ISECT_DEPTH_RETURNED. The value is automatically derived from DBL
setting and at double resolves to about 4.44089e-08. On the order of the
square root of POV_DBL_EPSILON.
Moving blob.cpp's inside test value INSIDE_TOLERANCE to POV_DBL_EPSILON
over previous recent re-calculation. Over time plan is to move EPSILONs
best nearer a double's step to POV_DBL_EPSILON.
Cleaning up doxygen documentation added during recent solver related
updates.
22) Adding root polishing step to solve_quartic function.
Newton-Raphson step added to polish initial roots found by the
solve_quartic function. The core solve_quartic tolerance allows roots to
drift from <=0.0 to >0.0 values with the latter causing artifacts and
additional root filtering. This the reason for the long too large 1e-2
intersection depth value in blob.cpp now reduced to
As part of this change created a new FUDGE_FACTOR4(1e-8) constant DBL
value to replace previous use of SMALL_ENOUGH(1e-10) within
solve_quartic. Looks like the value had been smaller to make roots more
accurate, but at the cost of missing roots in some difficult equation
cases. With the root polishing can move back to a larger value so as to
always get roots. Yes, this better addresses most of what the already
remove difficult_coeffs() function and bump into polysolve was trying to do.
23) Adding root polishing step to polysolve function.
24) Cleaning up a few comments and doxygen documentation.
25) Moving to more conservative root polishing implementations.
Download 'tolerancestory.png' (97 KB)
Preview of image 'tolerancestory.png'
Date: 25 Nov 2018 11:18:25
Message: <5bfacb51$1@news.povray.org>
On 3/30/18 8:21 AM, William F Pokorny wrote:
> In continuing to look at media I returned to a 'blob-media' issue Gail
> Shaw originally posted back in 2005.
A long time since I posted here on the progress I guess... Still hacking
- just proving hard to get everything dependent on polysolve to
something mostly 'fixed.'
Yesterday, Johannes (j13r) posted in newusers a scene where he was
trying to create a scene using torus shapes and media to create
something like solar flares on the surface of a disk. A slightly
modified version without lights makes for a pretty good poster for
current media issues compared to my current working branch with better
solvers/shape code, my current version of the change proposed in:
https://github.com/POV-Ray/povray/pull/358 and the internal small
tolerance at 1e-6 instead of 1e-3.
The current v3.8 on the left, my patched branch in the middle and the
differences (artifacts) shown on the right. The scene was modified for
no lights and run with the flags: +w600 +h300 Corona.pov -j +p +a in
both cases.
Bill P.
Download 'coronaa_to_coronab.jpg' (21 KB)
Preview of image 'coronaa_to_coronab.jpg'
Date: 28 Nov 2018 08:23:45
Message: <5bfe96e1@news.povray.org>
Am 25.11.2018 um 17:18 schrieb William F Pokorny:
I admire and appreciate your perseverance in this matter.
Date: 11 Mar 2019 10:41:20
Message: <5c867390@news.povray.org>
> Shaw originally posted back in 2005. The bright spots at the very edge
> are indeed caused by the 'intersection depth < small_tolerance' or
> missed intersection issue as Slime guessed at the time.
Sturm / polysove(), solvers investigation. End of this thread.
Almost exactly a year ago started to dig into numerical issues. It's a
good time to take a break. Before I do, five more commits to close out
this thread with updates representing a reasonably complete set of
improvements. I have in mind still many possible solver improvements and
code improvements beyond these. I could spend the rest of my lifetime at
it. I'm instead going to get back to some scene work near term.
First commit a set of changes I've been sitting on since last fall which
to my testing makes most everything better solver-side wise. The one
user oriented change was adding a sturm option to sphere_sweep where
that sturm means a two pass sort of sturm. The sturm control tests a fix
for a class of issues most often seen with orthogonal cameras to an in
plane sweep as might be done for human signatures or presentation like
images.
Second commit is my version of Jerome's pull request #358 which needs
some of the changes in the first commit. Note this update causes scenes
with photons to be somewhat slower due more photons being deposited.
Third commit addresses what might be called 2.5 issues with the shadow
cache for both artifacts and performance. The update causes a shift in
certain shadow artifacts. I suspect the state of the shadow cache might
have come about as a way to hide (it didn't completely and causes other
issues) certain shadowing issues - but guessing. The also cleans up
SMALL_TOLERANCE and SHADOW_TOLERANCE uses in the shadow cache / trace
shadow code. The values have been equivalent for 25+ years so the
tangling had not mattered to result.
Fourth commit mostly a completion of the second and third eliminating
SMALL_TOLERANCE in addition to MIN_ISECT_DIST. This partly follows up on
a question Jerome asked either in #358 or some related issue. Namely,
why not zero or near it for the Intersect_BBox_Dir calls in object.cpp.
Larger values do indeed cause artifacts with secondary rays as
especially noticeable in scenes with media. It's one of many causes for
media speckles. Pull #358 as originally submitted moved from a
MIN_ISECT_DIST value of 1e-4 to SMALL_TOLERANCE of 1e-3 making the
inherent problem worse. SMALL_TOLERANCE had also been adopted a few
other places in the code. In those cases moved to gkDBL_epsilon or
gkMinIsectDepthReturned as appropriate.
Fifth commit changes Cone_Tolerance(1e-9) in cone.cpp to
gkMinIsectDepthReturned(4.4e-8). Found to be necessary during testing
due pull #358 changes.
Solvers in much better shape to my testing (2000+ cases now) but, so
long as we run more or less directly on the floating point hardware for
best speed, there will always be floating point accuracy issues cropping up.
All shapes where I made modifications test better and scale better, but
I'll mention the sphere_sweeps still has substantial issues with media
(even at 1x scale) and scaling. Due - reasons - one being the necessary
updates are not easy. Rays perpendicular to a sweeps directions will
sometimes show MORE artifacts due tightening up on solver accuracy(1) -
this is where the new sturm (double sturm) control must be used.
The two attached images shows a kind of media scaling set I've generally
adopted as it seems to be a pretty good way to test the numerical
soundness of a shape's code - especially the secondary rays. One image
is blobs for sturms the other for the updated solve_quartic code. Middle
row being the updated and essentially speckle-less new result. Seventh
column over is the 1x scene. Scales from the left at 1e6x to the right
at 1e-7x.
Updates at (2):
Bill P.
(1) - As mentioned previously some of the solvers had been de-tuned
(solve_quadratic and sturm) to help lathes and sphere_sweeps - I guess.
The solve_quartic solvers was tuned - perhaps by accident given the
previous use of SMALL_ENOUGH - to be more accurate at the expense of
finding roots. In that latter case now tuned to find the most roots
possible with root polishing. Argh! I'd need to write a book to describe
anything close to all the details addressed and still open. For the
record significant solver related conversation can be found in the
github pull request comments at: https://github.com/POV-Ray/povray/pull/358.
(2) - The last set of changes in master forced some branch merges
instead of the usual re-basing. The solver branch, for one, had to be
merged to maintain compile-ability on checkout of previous branch commits.
Performance info:
------------ /usr/bin/time povray -j -wt1 -fn -p -d -cc lemonSturm.pov
26) 75ddd88   17.53user 0.02system 0:18.11elapsed    +13.61%
               (quartic non-sturm lemon scene)        (+3.10%)
27) 4ea0c37   NA (slowdown due photons. benchmark +3.5%)
28) ff6cd8d   14.41user 0.02system 0:15.01elapsed    (-17.80%)
29) ef9538b   NA
30) 38b434d   NA
Further making constant names consistent with recommened coding style. In
polynomialsolver.cpp results in the following name changes.
FUDGE_FACTOR2 now kSolveQuarticV1_Factor2
FUDGE_FACTOR3 now kSolveQuarticV1_Factor3
FUDGE_FACTOR4 now kSolveQuarticV2_Factor4
TWO_M_PI_3 now kSolveCubic_2MultPiDiv3
FOUR_M_PI_3 now kSolveCubic_4MultPiDiv3
MAX_ITERATIONS now kMaxIterations
SBISECT_MULT_ROOT_THRESHOLD now kSbisectMultRootThreshold
REGULA_FALSA_THRESHOLD now kRegulaFalsaThreshold
RELERROR now kRelativeError
SMALL_ENOUGH now kSolveQuadratic_SmallEnough
26) Initial, reasonably complete, update to common solvers.
Working on possible further improvements, but those likely quite far out
in time. In total dozens of issues addressed. New solver call structure.
Solvers themselves more accurate and aligned better with common
practice. Additional root polishing. Corresponding updates to shape code
while working to extend scaling range for shapes. Changes encompass
updates needed to support a commit to follow which covers pull request
#358 and its associated issues.
Generally sturm option now much faster. Also true due improvements to
the fixed solvers that the sturm option is less often necessary.
The sphere_sweep now supports a sturm option. Here sturm runs the
sturmian solver in a two pass approach which, for certain scenes, will
work where the previous single pass sturmian solver did not. Unlike
other updated shapes, the sphere_sweeps scaling accuracy range was not
much improved due a decision to leave other parse time optimizations for
run time performance in place.
27) My implementation of Jerome's pull request #358.
Fix for issues #121, #125 and several related newsgroup reports as well.
Mostly it restores 3.6 behavior with respect to intersection depths
filtered.
Note! Scenes using photons will often run slower and look somewhat
different due additional photons being deposited. This includes our
benchmark scene.
28) Shadow cache fixes. SHADOW_TOLERANCE vs SMALL_TOLERANCE cleanup.
SHADOW_TOLERANCE not used for cached results leading to artifacts though
sometimes hiding others.
Shadow cache not invalidated on misses causing sometimes significant
performance hit.
SMALL_TOLERANCE being used instead of SHADOW_TOLERANCE in some trace
shadow related comparisons. Values had long (25+ years) been cleaned up
ahead of SMALL_TOLERANCE removal.
Note! This the last commit where SMALL_TOLERANCE will exists.
29) Mostly details completing the previous two commits.
Eliminating SMALL_TOLERANCE in addition to MIN_ISECT_DIST. This partly
follows up on a question Jerome asked either in #358 or some related
issue. Namely, why not zero or near it for the Intersect_BBox_Dir calls
in object.cpp. Larger values do indeed cause artifacts with secondary
rays as especially noticeable in scenes with media. It's one of many
causes for media speckles. Pull #358 as originally submitted moved from
a MIN_ISECT_DIST value of 1e-4 to SMALL_TOLERANCE of 1e-3 making the
30) In cone.cpp changing Cone_Tolerance to gkMinIsectDepthReturned.
During testing found the Cone_Tolerance in cone.cpp, which had been
changed from 1e-6 to 1e-9 v3.6 to v3.7, was too small for some photon
scenes. Secondary rays starting on the surface (at zero but numerically
not) were not getting filtered with the pull request 358 like changes
(MIN_ISECT_DIST to 0.0). Moved to new gkMinIsectDepthReturned (4.4e-8)
used now in many other shapes and OK for test scenes I have.
Download 'blobsturmstory.png' (78 KB) Download 'blobnosturmstory.png' (74 KB)
Preview of image 'blobsturmstory.png'
Preview of image 'blobnosturmstory.png'
