POV-Ray : Newsgroups : povray.binaries.images : Blurred reflection comparison Server Time
6 Mar 2026 22:01:45 EST (-0500)
  Blurred reflection comparison (Message 1 to 10 of 28)
Subject: Blurred reflection comparison
Date: 12 Feb 2018 08:08:55
Message: <5a8191e7$1@news.povray.org>
I still don't understand how I'm supposed to achieve the blurred
reflections possible in UberPOV by just using a little focal blur.
Compare the two attached images - especially the reflections in the
circled parts.
Mike
Download 'building_007_firecompany_reflection_01.jpg' (197 KB) Download 'building_007_firecompany_reflection_02.jpg' (200 KB)
Preview of image 'building_007_firecompany_reflection_01.jpg'
Preview of image 'building_007_firecompany_reflection_02.jpg'
Subject: Re: Blurred reflection comparison
Date: 12 Feb 2018 13:21:30
Message: <5a81db2a@news.povray.org>
Am 12.02.2018 um 14:08 schrieb Mike Horvath:
> circled parts.
Focal blur is just part of the equation.
You need:
(1) A way to randomize the reflection. A `normal` statement with a very
small scale does nicely.
(2) A way to force POV-Ray to shoot a high number of rays per pixel
where the randomized reflection is. A small bit of focal blur (with high
quality settings) does nicely.
Together this gives you nice blurred reflections at a (hopefully)
reasonable speed.
Date: 12 Feb 2018 16:27:14
Message: <5a8206b2$1@news.povray.org>
>> circled parts.
> You need:
> reasonable speed.
Is this random normal good?
#declare BlurAmount = 0.2*2; // Amount of blurring, double BlurAmount
since it's used in an average
#macro BlurredReflectionRandNormals(InPigment, InFinish, InNormal)
//	texture
		#declare S = seed(0);
		pigment { InPigment }
		finish { InFinish }
		normal
			average
			normal_map
				[1 bumps BlurAmount translate <rand(S),rand(S),rand(S)>*100 scale 0.001]
				[1 InNormal]
Date: 12 Feb 2018 17:05:51
Message: <5a820fbf$1@news.povray.org>
Am 12.02.2018 um 22:27 schrieb Mike Horvath:
>> You need:
>> reasonable speed.
It should do the job. Note that since you're only using one copy of the
bumps normal, there's no need to translate the texture by a random amount.
Also, I'm not sure whether the average normal_map construct will give
you the desired result, or whether you should instead use a sequence of
`normal` statements. See tutorial section 2.3.5.2.2, "Blending Normals".
Date: 12 Feb 2018 22:11:42
Message: <5a82576e@news.povray.org>
>>> You need:
>>> reasonable speed.
Very nice, thank you.
Mike
Date: 13 Feb 2018 00:12:43
Message: <5a8273cb$1@news.povray.org>
>>> You need:
>>> reasonable speed.
How do I control the amount of blurring? In my scene the textures are
maybe a little too blurred.
Mike
Date: 13 Feb 2018 01:56:22
Message: <5a828c16$1@news.povray.org>
Am 13.02.2018 um 06:12 schrieb Mike Horvath:
Reducing `BlurAmount` in your code should reduce the blurriness of the
reflections.
Reducing the camera's `aperture` setting should reduce any overall
blurriness of the image.
Date: 13 Feb 2018 19:31:28
Message: <5a838360$1@news.povray.org>
>>> circled parts.
>> You need:
>> reasonable speed.
> //    texture
>          finish { InFinish }
>          normal
>              average
>              normal_map
>                  [1 InNormal]
> #end
It's good in the sense that it will not cause any error.
BUT.. At parse time, it will compute the average between the two normals
into a single one that will get used. This result in only a single
reflected ray been taken into count.
I did try averaging many normals and it always give a sharp reflection.
To use the averaged normals blurred reflection, you need to average
whole textures.
Move the seed before the average.
Enclose the texture in a loop construct.
Place that loop within your average.
Date: 13 Feb 2018 23:50:38
Message: <5a83c01e$1@news.povray.org>
> reflections.
This is my latest macro. I used a sequential list of normals instead of
averaging them. It looks okay.
Mike
// this method is faster, but requires a focal blur and/or extra
antialiasing
#declare BlurAmount = 0.1;
#macro BlurredReflectionRegularNormals(InPigment, InFinish, InNormal)
//	texture
		finish { InFinish }
		normal { InNormal }
		normal {bumps BlurAmount scale 0.001}
Date: 15 Feb 2018 14:26:15
Message: <5a85ded7@news.povray.org>
Here's my latest town render. You can see the pixelation in the
reflections. I haven't been able to get rid of it using more focal blur
and anti-aliasing. I will keep trying.
Mike
Download 'wrapper_townview_10.jpg' (1057 KB)
Preview of image 'wrapper_townview_10.jpg'
