On 9/7/2017 9:33 PM, Norbert Kern wrote:
> I like the brass texture too.
> In fact I tried to reproduce it - here is my attempt...
i used your rmf definition then tweaked the normal map for this version ...
normal {
average
normal_map {
[1 bumps scale 0.175 bump_size 0.15]
[1 bumps scale 0.35 bump_size 0.15]
[1 function { RMF(x, y, z) } scale 0.1 bump_size 0.125 slope_map
{ [0 <0,1>] [0.25 <1,0>] [1 <1,0>] }]
accuracy 1e-3
scale 0.05
... i think it looks like cast brass that's been worked a bit.
Download 'rollysphere.png' (697 KB)
Preview of image 'rollysphere.png'
i also played some more with irid ...
irid { 0.1 thickness 0.25 turbulence 1 }
it's subtle but you can see it in a several places
Yes, very good indeed.
Yes, it looks patinated.
Personally I love metal materials, but it's difficult to predict their behavior
in several scene setups.
Metals depend on their environment, reflections are more important than diffuse
settings. Metals show sharp contrasts between shadows and highlights.
Therefore I prefer hdr lighting or at least a combination of a normal
lightsource and hdr.
Here I took the nice rolly_sphere together with a more polished silvery metal
material:
#declare mtex =
pigment {color rgb <1,0.952,0.818>}
normal {facets coords 0.024 scale 0.1}
finish {
brilliance 2
specular 0.5
roughness 0.01
metallic
reflection {0.8 metallic}
ambient 0
diffuse 0.05
conserve_energy
#declare dtex =
pigment {color rgb 1}
normal {bumps 0.2 sine_wave scale 0.01}
finish {
brilliance 1
specular 0.3
roughness 0.03
reflection {0, 0.8 fresnel on}
ambient 0
diffuse 0.15
conserve_energy
#declare unnamed_material_ =
material {
pigment_pattern {
average
pigment_map {
[1 wrinkles scale 0.02]
[1 wrinkles scale 0.063]
[1 wrinkles scale 0.2]
texture_map {
[0.5 mtex]
[1 dtex]
interior {ior 2.5}
scale 10
Norbert
Download 'rolly_sphere_pov_scene2.jpg' (267 KB)
Preview of image 'rolly_sphere_pov_scene2.jpg'
Am 12.09.2017 um 13:53 schrieb Norbert Kern:
> material:
Holy moly!
That looks... quite good.
clipka <ano### [at] anonymousorg> wrote:
> Holy moly!
Ok for a quick test render...
Norbert
>> Holy moly!
More than that! It is /quite/ good.
>>> Holy moly!
Yes, it is not bad. :-)
Regards
Stephen wrote on 13/09/2017 09:06:
>>>> Holy moly!
It seems very /real/
Paolo
> >> nope ... it's procedural. the underlying pigment is a single color with
> >> a touch of irid ( also changed irid_wavelength in global_settings to
> >> that color ) for the normal i used f_ridged_mf
> > Perhaps you want to correct my mistakes?
> lol ... i see no mistakes in fact i think you've improved it!
> > normal {
> > average
> > normal_map {
> > [1 bumps
> > scale 0.0175
> > bump_size 0.2
> > [1 bumps
> > scale 0.35
> > bump_size 0.2
> > [1 function {(f_ridged_mf ((4+x)/0.3, y/0.3, z/0.3, 0.5, 2.7, 4,
> > 1, 1.5, 0)-1.8)*0.5}
> > scale 0.35
> > bump_size 0.3
> > slope_map {
> > [0 <0,1>]
> > [0.25 <1,0>]
> > [1 <1,0>]
> > accuracy 0.003
> excellent variant ... I think I'll give it a go in my scene
It's improved only in the small sharp dented marks to me, but from afar I still
prefer the setting of your turbulence, making it look more like it has been
somewhat applied, or polished, looks more like it has a history of being
crafted, yet, combining the two would be perfect both for distant and close ups!
I hop I will be able to get a hand on the final code version so that if you guys
agree, I can share it here:
https://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Render/POV-Ray/Sample_Materials
Along the other great POV textures?
